InFocus X10 vs. BenQ W5000
Direct competitors, for sure, with similar pricing. Both DLP's with the same old 1.2:1 zoom lens, but the BenQ does have lens shift, which means it can be shelf mounted - a plus for many. The BenQ W5000 definitely wins the black level performance battle, but suffers from a bit too much image noise, which BenQ is "working on solving".
Tough call here. If BenQ ever straightens out the image noise issue, I would give it the advantage - as it stands, it's a pick and choose, the lessor of two evils (black levels vs. image noise). Both are very good choices, though. Don't let me scare you off.
Πηγή: http://www.projectorreviews.com/infocus/X10/proscons.php
hmmmmmmm :nounder:
hmmmmmmm :nounder:
