δεν μπορω να απαντησω στον dragonlord φαινεται οτι δεν μπορουμε να επικοινωνησουμε πολιτισμενα επειδη δεν μπορει να δεχτει μια διαφορετικη αποψη για τον προβολεα που θελει να παρει...
αρα συνεχιζω συμφωνα με το ονομα του thread
InFocus X10 vs. BenQ W5000 vs. Sony 10 vs. ..........
OBSERVATIONS:vpl hw10
Contrast/Black Levels: As mentioned, the unit is rated at 30000:1 on/off contrast, more than the previous VW40 (with iris). Originally I measured the unit at 16995:1, but then realizing I made an error. After remeasuring it, I got 24353:1 on/off! Kudos to Sony for impressive contrast on a lower cost SXRD. ANSI was quite good as well. I got about 342:1…amongst the best for this generally technology that I have measured. The black levels on the HW10 were quite good, rivaling that of the JVC DLA-RS1X. Plus, with the near elimination of bright corners, the affect is quite impressive.
Light Output: The HW10 is rated at 800 lumens. Now here is something that many manufacturers hype up and don’t deliver. Of course, I always rate them at D65 so rarely do they fully output the rated specs. BUT, the Sony, at D65 still put out a max light output of 616 lumens. This is a definite improvement as well, and allows this to work in rooms with larger screens (or those with some ambient light). Excellent.
Colors: As I mentioned before, this was near perfect out of the box. I was able to get it slightly dialed in better, but even without that adjustment, this is a big benefit to the HW10 vs. some of its competition. Again, kudos.
Sharpness: Is it ever! Seriously, this was an area that stood out for me immediately. It is very sharp and probably the best I have seen as compared to other similar technologies. I have to check my facts, but I am pretty sure it is in part to the new panels which are digitally drive (I will try and confirm). In any event, love this part a lot.
συμφωνα με τις μετρησεις του Jason Turk απο avs
