jaibreak for iphones 1.1.3 is ready...
nikolis9
2 November 2007
889
The iPhone dev team has achieved 1.1.3 jailbreak on both the iPhone AND the iPod Touch. The jailbreak solution has NOT been released to the public, and according to them will not be until February when the SDK releases, that way Apple doesn't get to see the method, and break it before the SDK releases - jailbreak + SDK = awesome app functionality, for that free price we've all come to love for iPhone applications (but always remember - if you like an app, DONATE TO THE DEV!!!!!).
Once the jailbreak is made public, make sure you toss some fundage over to the dev team for their work. (Their site is down right now or I'd link - will add link when its back up). Rock n' roll, folks, the cat and mouse game continues.
nikolis9
2 November 2007
889
what news:
3 observations:
1. this deletes all your 3rd party apps and JUST installs Installer.
2. EDGE setting wont stick at all, meaning i can type in optus.wap and it'll crash the settings.app
3. HyperCard still works!
nssa
3 November 2006
119
Δηλαδη αν εχουμε unlock 1.1.1 μπορούμε να πάμε σε 1.1.3 και να λειτουργεί και το τηλέφωνο?
Μιχάλης Πικούνης
285
Αν το δοκιμάσει κανείς ας μας πει εντυπώσεις - πχ δουλεύει η κάρτα sim (οχι turbosim κλπ), χάνονται οι εφαρμογές που είναι εγκατεστημένες;
nikolis9
2 November 2007
889
i post also this from Hackintosh
OK FOR ALL THE PEOPLE THAT KEEP ASKING THE SAME QEUSTIONS!!!!
Q: Does the *sim still work after the jailbreak?
A: YES, It will work regardless of your bootloader (3.9/4.6)
Q: Is it normal that the install freezes half way in installer?
A: YES, it is not freezing it is a very big install and takes awhile.
Q: Why is the 1.1.3 soft upgrade not showing up in installer?
A: Refresh your sources and go to recently added.
Q: Can i go back to "FACTORY SETTINGS" Afterwards?
A: YES
Q: Does this jailbreak include a baseband upgrade?
A: NO
Q: Does this jailbreak delete all my data?
A: Your Music, contacts, call log, sms, notes, wallpaper, and so on will remain. This jailbreak does get rid of all of your 3rd party apps.
ACTUAL EXPERIENCE: It went great i have a 1.1.2 otb usa iphone and everything came out great. Just follow and read the steps carefully and make sure you be very patient and give it atleast 20 min.
Hope this helps Thanks. ...
stbtuok
29 December 2007
71
Ευχαριστώ πολύ
Παρότι είμαι σχετικά ανίδεος, ήταν εύκολο και δουλεύει κανονικά το Ι Phone μου
VAG.NIK
18 August 2006
3,073
Ευχαριστώ πολύ
όταν σε παίρνουν τηλέφωνο, ακούς κανονικά τον ήχο; οι πληροφορίες μου λένε ότι δεν ακούγεται, παρά το ότι ακούγεται το κλικ στην οθόνη ή ο ήχος μηνύματος ...
PMCCX
30 August 2006
188
Λοιπον ακολουθησα τον παραπανω οδηγο ΟΛΑ ΔΟΥΛΕΥΟΥΝ ΟΚ ΕΚΤΟΣ ΤΟ ΟΤΙ ΔΕΝ ΑΚΟΥΓΕΤΑΙ Ο ΗΧΟΣ ΚΛΗΣΗΣ!!!
Ειμαι στην 1.1.3. και modem 04.01.13_G
Πριν το update ειχα την 1.1.1 (jailbreak) και modem 04.01.13_G
PMCCX
30 August 2006
188
Εαν φτιαξετε ομως ενα ringtone στο garageband, insert στο itunes,και απο εκει στο τηλ τοτε ολα οκ!!!!!
Thx nikolis9 για τον οδηγο.
VAG.NIK
18 August 2006
3,073
Απάντηση: Re: jaibreak for iphones 1.1.3 is ready...
τι ακριβώς είναι το garageband; πού το βρίσκουμε;
