JVC DLA-X500R
Browser
10,575
Overview
The JVC DLA-X500R Sets New Standards with 4K e-shift3
The DLA-X500R delivers stunning picture detail at an unprecedented value thanks to JVC's exclusive 4K e-shift3 technology which accepts Native 4K 60P through the 4K enabled HDMI inputs and up-converts existing 1080P sources to 4K. The three discrete DILA devices in the DLA-X500R produce a stable image with no flicker and a class leading 60,000:1 Native Contrast Ratio for peak whites and deep blacks.
For 2014, JVC adds an Intelligent Lens Aperture which results in a Dynamic Contrast Ratio of 600,000:1. While the DLA-X500R looks fantastic right out of the box, you can optimize it to your room by using the on-screen gamma control, 7-Axis Color Management System, High Precision Pixel Alignment and more.
The Competitive Advantage
  • Improved 60,000:1 Native Contrast Ratio
  • New Intelligent Lens Aperture for Dynamic Contrast Ratio of 600,000:1
  • New 4K e-shift3 provides 3840x2160 projected image
  • New Native 4K HDMI inputs that accept
    • 3840x2160 at 24P, 25P, 30P and 60P
    • 4096x2160 at 24P
  • New Clear Black Processing improves local area contrast
  • New Upgraded Clear Motion Drive works in 2D, 3D and 4K
  • Improved Multi Pixel Control (MPC) with New Auto Mode
    • MPC improves 2K to 4K up-conversion
  • New 6th Generation 1920x1080 DILA devices
    • 40% smaller pixel gap
    • Improved brightness and contrast ratio
  • Supports 3D content and display using Active Shutter 3D
    • Accepts Frame Sequential, Side-by-Side, and Top-Bottom
    • 3D Anamorphic Capable
    • 3D Crosstalk Cancellation
    • 2D to 3D Conversion System
    • 3D Parallax Adjustment
    • Optional RF Active Shutter 3D Glasses (PK-AG3G) and RF 3D Emitter (PK-EM2G)
  • New Smartphone App for operational control, image adjustment and more
  • Lens Memory with 5 user adjustable presets
  • Motorized 2X Zoom Lens (1.4:1 – 2.8:1)
  • Exclusive Real Color Imaging Technology
  • 7-Axis Color Management System (R,G,B,C,M,Y,Orange)
  • Customized Gamma Control
  • 230 Watt NSH Lamp, 1300 Lumens
  • Inputs & Outputs
    • Dual 4K/60P HDMI Inputs with Deep Color and CEC
    • 3D Compatible (Blu-ray, Side-by-Side, Top-and-Bottom)
    • RS-232C
    • RJ45 LAN Connection
    • 12V Trigger
    • 3D Synchro
  • Ultra Quiet Operation (21db/Low Lamp)
  • 2 Year Warranty
http://procision.jvc.com/product.jsp?modelId=MODL029315&pathId=140&page=10
Κι αυτος θα ειναι εδω σε λιγες μερες.
6ης γενιας πανελς
Βελτιωμενο contrast
Νεο wire grid polarizer
Tα νεα πανελ εχουν 40% λιγοτερο κενο αναμεσα στα πιξελ που σημαινει σχεδον 10% περισσοτερο light efficiency
4K eshift 3
User selectable intelligent lense aperture. Δεν ειναι δυναμικη ιριδα ετσι οπως το περιγραφουν, ειμαι περιεργος να το δω....
Μενει να τον δουμε κι αυτον απο κοντα.....
takisot
Μέλος Δ.Σ.
27,933
Παλλήνη
To "intelligent" και το "600.000/1" εμενα, δυναμική ίριδα μου δείχνουν πάντως..
" Intelligent Lens Aperture which results in a Dynamic Contrast Ratio of 600,000:1."
spcav
18 August 2006
16,673
Προφανως δυναμική ιριδα ειναι.
http://www.hdtvtest.co.uk/news/jvc-x700-201310213386.htm
''Black level reached a depth hitherto unseen on any digital home cinema projector, surpassing even the outstanding blacks delivered by previous JVC DILA projectors. The company’s new Intelligent Lens Aperture tech probably helped a lot in this aspect: despite clarifying with JVC that dynamic iris was indeed in operation, we didn’t notice any brightness fluctuation from the few clips we sampled.''
takisot
Μέλος Δ.Σ.
27,933
Παλλήνη
Από specs πάντως, το μηχανάκι "σκοτώνει"..
Άντε να παραλάβει ο Σύριος μπας και το δούμε από κοντα :p
vadergr
17 August 2007
27,569
Μεταμορφωση
Re: Απάντηση: JVC DLA-X500R
Ο κυριος δεν ασχολείται με mid range 3xx/5xx , απο 7xx και άνω ... :p
spcav
18 August 2006
16,673
Σιγα μην παραλαβει το ποταπο 500αρι....:p
edit Με προλαβε ο αποπάνω :p
35,671
Απίστευτα πράγματα γράφονται στα specs για το ρημαδο4Κ!! Πραγματικά απίστευτα. Δεν περίμενα από την JVC τέτοιες αρλούμπες. ΔΕΝ έβγαλε πάνελ 4Κ...οκ. ΔΕΝ τρέχει τίποτα. Μην προσπαθεί να παραπλανήσει γράφοντας αμπελοφιλοσοφίες για HDMI input native 4K και upconvert του 1080 σε 4Κ. 2Κ είναι τα πάνελ της. Το τι σήματα δέχεται, τι κάνει σοφτγουερικά κ.λ.π. είναι αδιάφορο. Σαν την Έπσον που ανακάλυψε εσχάτως τις φωτεινότητες των χρωμάτων για να χτυπήσει τους Data DLP με μεγάλο λευκό μέρος στο χρωματικό τροχό και το λάνσαρε σαν παγκόσμια πατέντα για τα πάντα όλα......ΗΜΑΡΤΟΝ!!!!
Browser
10,575
Καμμια αντιρρηση. Κι εγω αυτο καταλαβαινω. Αυτο το user selectable με μπερδευει......
spcav
18 August 2006
16,673
Μπορει να εννοει απλως και το on / off η ακόμα και την ρυθμιση / steps στο εντελως off (οπως οι μεχρι σημερα δλδ)
Browser
10,575
Πωλείται 55-'αρης άστρωτος μαζί με 2 ζευγάρια Rayban...:earmuffs:
Παρακαλω να μεταφερθει στις αγγελιες. Η μαλλον αστο. Μπαμπη , παρε με τηλεφωνο -bye-
23,876
εντάξει μωρέ, για τους πρώτους κ@#$%#%νους που θα βάλουν να δουν κανά κατεβασμένο κλιπάκι 4Κ, τουλάχιστον να μην τους βγάλει κανά "Signal Not Supported" :flipout:
vas_papavas
21 December 2010
8,849
Αμα σπάει σε κομμάτια θέλω τα rayban. Ελπίζω να είναι από την pilot σειρά.
Browser
10,575
Με κανά pc φαντάζομαι. Κάτι κάρτες γραφικών που βλέπω στο πλαίσιο κάτι τρελά λεφτά δεν βγάζουν 4Κ;
Α, ενταξει. Καταλαβα ποιον εννοεις :flipout::flipout:
35,671
Το βασικό είναι να γράφει: Σήμα ασανσέρ, παίρνουμε το σήμα και το ανεβοκατεβάζουμε σε διάφορες αναλύσεις μέχρι που τα πίξελ να ζαλιστούν και να βλέπετε ξερά από το τρέξιμο!!:Banane0:
