Λαμπάτος για ipod!!
=silent=
2 August 2006
11,095
Homeless
Αμα ο κοσμος ειναι χαζος ας παει να το αγορασει. Δηλαδη ειναι δυνατον να πας να αγορασεις λαμπατο ενισχητη για να ακους mp3??? Ε ημαρτον ρε παιδια
Mihalis S.
3,497
Δεν είχα χρόνο να το διαβάσω αλλά είναι λαμπάτος πραγματικός ή απλά εφετζίδικος;
GeonX
2,755
Αχ βρε σεις δεν διαβάζετε και τη κατηγόρια σας…(πσσστ πλάκα κάνω…)
Αντιγράφω από παλιότερο thread για το ίδιο μηχάνημα…
http://www.avclub.gr/forum/showthread.php?t=694
http://www.fat-man.co.uk/docs/product/itube_1.htm#
Want to be able to listen to your iPod in style? Want that luscious warm analogue sound combined with the ease of use of digital technology?
We present the Fatman iTube Valve Dock.
This unit features a docking station that is compatible with all iPods (except Shuffle).
You can control the iPod functions via the remote control – allowing you to sit back and relax whilst enjoying your favourite music and movies (yes, you can watch the movies and images on your TV too !)
In addition to this we have developed a matching valve amplifier. This provides the classic audio characteristics of valves, improving the listening experience and adding value to your iPod system.
The amplifier can also take alternative sound sources to allow for more audio options as well as a video output to connect video enabled iPods to your TV!
FEATURES
iTube Vacuum Tube Amplifier
iTube Docking Station
Brush / Glove for cleaning
Power cable
Audio cable to connect Docking Station and Amplifier
Banana Plug speaker cables
Aux source audio cable for connecting CD player etc
Video cable to connect from docking station to TV
Spec...
Pwer Output 13Wx2
Frequency Response 20Hz – 20KHz (±1.5Db)
Harmonic Distortion 0.5%
Signal-To-Noise Ratio 86Db
Input Impedance 100K
Output Impedance 4ohm, 8ohm
Valve Type 2x6N1(ECC85) 1x6E2(EM87)
Power Supply AC100~120V/50~60Hz AC220~240V/50~60Hz
Dimensions:
Amp (LxWxH) 260x145x130mm
Dock (WxDxH) 155x130x123mm
Weight 4.3KGs
τιμη £299
 Νίκος
Mιας και άνοιξε νέο θέμα για τις λάμπες θυμίζω
GeonX said:
τιμη £299 ....
Δίνοντας κάτι παραπάνω (1000$ το σετ) όμως παίρνεις το iTube SE15 της PsiberAudio
Και επειδή αν το κάνεις αξίζει και να το παρακάνεις, αν είσαι πραγματικά hi-end τύπος με κάτι παραπάνω ακόμη (3200 euros :bang: ) μπορεί κανείς να αποκτήσει το μοναδικό Consertino:firstprize:
Maria An.
28 June 2006
292
Α το είχατε ήδη ξετρυπώσει ε? Sorry για την επανάληψη, αλλά το είδα μπροστά μου ψάχνοντας κάτι άλλο και δεν μπόρεσα να αντισταθώ να μην σας το δείξω αμέσως..
Browser
10,575
Και καποιοι αλλοι απο την IFA τον περασμενο Σεπτεμβρη.....
 Νίκος
Σήμερα βρήκα και αυτόν στο ebay..
tms el84 single ended CLASS A TUBE ipod AMPLIFIER moded version
WITH TUBE HEAD PHONE
AMP OUT PUT
6 HZ - 80 KHZ - 3 DB
MAX POWER: MORE THAN 2 X 15 W 4 ohm
rms out put: 10 w 4 ohm ( 8w 8 ohm )
NOISE RATIO > 92 DB
TUBES: PRE - AMPLIFIER : 6N3 ( 5670 )
POWER AMPLIFIER PART: el84
MKP CAPS
TUBE HEAD PHONE AMPLIFIER OUT PUT
usb decoder = good for connect the pc computer / ipod and speaker
6N COPPER OUT PUT TRANSFORMER
POWERFUL, DYNAMIC WITH SWEET nice el84 TUBE SOUND !
voltage in put: 110v - 220 V - 240V
Τιμή κάνα 230άρι (μαζί με τα μεταφορικά) όπως πάει το πράμα..
Αξίζει λέτε? Και με τι ηχεία να συνδιάζεται άραγε ?
Stergito
11 November 2006
14,527
Υποθέτω ότι για να βγάλεις καλούτσικες εντάσεις με 15 βατ, θες πάνω από 90db ευαισθησία. Βέβαια, όλα είναι σχετικά. Υπολόγιζε περίπου με τα δεδομένα του t-amp.
Αυτό είναι καλό θέμα για τη hi-fi κατηγορία...
