Re: LG BD390 mkv player!
DivX file compatibility with this player is limited as follows:
• Available resolution size:
DIVX 3.xx – DIVX 6.xx: 720 x 576 (W x H) pixels
XVID, H.264/MPEG-4 AVC: 1920 x1080 (W x H) pixels
• The file names of DivX and subtitle are limited to 50 characters.
• DivX file extensions: “.avi”, “.divx”, “.mpg”, “.mpeg”, “.mp4”, “.mkv”
• Playable DivX subtitle: SubRip (.srt / .txt), SAMI (.smi),
SubStation Alpha (.ssa/.txt), MicroDVD (.sub/.txt),
SubViewer 2.0 (.sub/.txt), TMPlayer (.txt), DVD Subtitle System (.txt)
• Playable Codec format: “DIVX3.xx”, “DIVX4.xx”, “DIVX5.xx”, “XVID”,
“DIVX6.xx” (Standard playback only), H.264/MPEG-4 AVC
• Only the playback function is supported with DivX 6.0 in the unit.
• Playable Audio format: “Dolby Digital”, “DTS”, “MP3”, “WMA”, “AAC”
• Sampling frequency: within 8 - 48 kHz (MP3), within 32 - 48 kHz
(WMA)
• Bit rate: within 8 - 320 kbps (MP3), within 32 - 192 kbps (WMA)
• CD-R/RW, DVD±R/RW, BD-R/RE Format:
ISO 9660+JOLIET, UDF and UDF Bridge format
• Maximum Files/Folder:
Less than 650 (total number of files and folders)
• Not all the WMA Audio format is compatible with this unit.
• This player support H.264/MPEG-4 AVC profile Main, High at Level 4.1.
For a file with higher level, the player will ask whether you want to play
or not.
• Displaying subtitle file is not available for video files with “.mpg” and
“.mpeg” extensions.
• HD movie files contained on the CD or USB 1.0/1.1 may not played
properly. BD, DVD or USB 2.0 are recommended to play back HD
Από το μάνουαλ του 370. Οπότε τα ίδια θα ισχύουν και για το μεγαλύτερο 390. Μην βασίζεσαι στο πλαίσιο για τεχνικές προδιαγραφές......
