LG CX : Reviews - Εντυπώσεις - Σχόλια
sokos
19 January 2007
2,316
-04.30.55 3. Changes ⓐ HDMI4 no signal improvement (03.00.35) ⓑ Improved HDMI No signal issue in eARC On state (03.00.45) ⓒ Some bug fixes (03.00.60) - Improvement of the power not turning off when connected to a specific set -top - Improvement of noise generation when transmitting iPhone video to TV with Airplay app - Improvement of volume drop when setting the set-top box volume to low (1~2) - Improvement of screen saver execution error - Improvement of pop-up message that Bluetooth service needs to be initialized ⓓ Add new model name_OLED55_65_77CXFNA ⓔ Specific eARC equipment works as ARC improvement (03.00.70) ⓔ Voice mode, output mode, improvement of lip sync distortion when using the voice recognition button on the magic remote control / improvement of no video when switching IP channels (03.00.75) ⓖ Function correspondence (03.10.43) Improved Apple Airplay function AMD FreeSync support (only OLED CX and GX supported) Improved sports alert function ⓗ Icon and text are not displayed properly or are output in a block shape issue improvement (03.11.10) ⓘ New NVIDIA GeForce RTX 30 series compatibility issues improved (03.11.25) ⓙ HDMI 2.1 compatibility issue improvement (03.11.30) → Improved VRR performance so that there is no interruption in PC and console games ⓚ MR Minor 2 compatible (03.21.09) - Improved home launcher design - Listen to TV sound on mobile through ThinQ App - Added number keys/color keys for screen remote control according to the development of new magic remote control ⓛ Image quality improvement reflected (03.21.16)
Improvement of minor issues related to software (03.21.21) ⓝ Improvement of minor issues related to software (03.23.10) ⓞ Improvement of minor issues related to software (03.23.15) ⓟ Improvement of minor issues related to software (MR5_03.23.25) ⓠ Improvement of minor issues related to software (03.23.35) ⓡ MR4_2109(04.30.10) Improvement of minor issues related to software / Improvement of music recognition function performance ⓢ Improvement of minor issues related to software (04.30.35) ⓣ Improvement of minor issues related to software (04.30.40) Ⓤ improved software-related minor issues (04.30.55)
Reactions: theox and Lobo10
ΔΗΜΗΤΡΗΣ.Π
25 October 2006
20,764
ΑΘΗΝΑ
συνηθως δεν αναφερουν αναλυτικα τις αλλαγες.
στην c1 πχ που πηρε και αυτη update,ανεβηκε η φωτεινοτητα του πανελ,αλλα αυτο δεν αναφερεται πουθενα.
ας διορθωνουν τα bugs,και ας μην αναφερουν τιποτε...:cool:
Robin Hood
15 September 2011
250
Να γραψω οτι το Prime video δεν κλειδωνει την οθονη της cx οπως κανει το netflx. Eτσι μπορεις να κανεις οτι θελεις και να εχεις και πληρη οθονη :)
Υπαρχει και περιεχομενομενο HDR ( δηλαδη βγαινει το σηματακι πανω δεξια) στο netflix δεν το εχω δει μεχρι τωρα , εκτος απο το dolby vision φυσικα που και αυτο ειναι φοβερη ποιοτητα! Τωρα ποια ποιοτητα ειναι καλυτερη ας γραψει καποιος εμπειρος εγω παω με το ματι χε χε ;)
koufos
30 October 2021
220
Πειραιάς
προσωπικα απο τοτε που ξεκινησα να βλεπω blu ray δεν μπορω να παω πισω σε ποιοτητα των streaming services, μου φαινεται πενιχρή. ιδίως με τη cx
Robin Hood
15 September 2011
250
Δεν νομιζω αψογη ειναι η εικονα κατι δεν κανεις καλα στις ρυθμισεις σου .!! Και το blue ray !!!Που βρισκεις δισκους σε μαγαζια εγω εχω μεινει στο dvd :)
koufos
30 October 2021
220
Πειραιάς
lol. ok
Για bluray δισκους amazon.co.uk και ebay!
Robin Hood
15 September 2011
250
lol. ok
Ναι οντως εχει ταινιες απο οτι ειδα στο ebay . To prime για παραδειγμα εχει 6 euro 3 users (λεμε τωρα) Τρια ατομα ειναι 2 euro το μηνα!! Θες παρα πολλα χρηματα για να φερνεις ταινιες ενταξει ο καθενας ειναι δικαιωμα του και οσο αντεχει η τσεπη φυσικα!!..:unsure:
Χαίρομαι που μεγαλώνει η oled κοινότητα...
Πλέον θα γνωρίζετε ότι δεν υπάρχει γυρισμός (σε lcd)
Ουτε για αστειο (y)
Reactions: Lobo10
billdanos
31 March 2008
214
Τι εννοείς πως δεν έχεις HDR στο netflix? Μήπως δεν έχεις συνδρομή για UHD περιεχόμενο?
Reactions: Robin Hood
billdanos
31 March 2008
214
Το DV είναι HDR και θεωρητικά είναι καλύτερο, καθώς έχει ανώτερες προδιαγραφές.
Προφανώς και όταν αναφέρομαι στο HDR εννοώ και το Dolby Vision, που επίσης έχεις ένδειξη στην CX όταν παίζει τέτοιο περιεχόμενο από netflix κλπ.
Robin Hood
15 September 2011
250
Καλησπερα,
Στο PRIME παρουσιαζονται ταινιες που στην περιγραφη τους γραφουν HDR.
Aυτες οταν τις ανοιγεις πριν ξεκινήσει το εργο εμφανίζεται δεξια και πανω στην ΤV ενα εικονιδιο που γραφει HDR
H τηλεοραση μπαίνει σε νεο menu .Εκει πρεπει να κανεις αν θες δικες σου ρυθμισεις κτλπ ξεχωριστα .
To netflix εμφανιζει ταινιες που γραφουν DOLBY VISION εδω αντιστοιχα οπως παραπανω παει σε αλλο Menu και εκει θελει αλλες ρυθμισεις
Αυτο εννοώ
Θα πειραματιστω και με τα δυο ακομα δεν ειμαι ετοιμος να βγαλω γνωμη. Ειναι σιγουρα διαφορετικα Modes θα ελεγα αν το γραφω και σωστα ..:)
Lobo10
23 May 2012
3,898
Απάντησες μόνος σου σωστά.
Είναι διαφορετικά modes, το μόνο κοινό ότι χρειάζονται και τα 2 τη μέγιστη φωτεινότητα της τηλεόρασης.
Robin Hood
15 September 2011
250
Nαι στα δυο modeς αυτα παιζω 90 με 100 Λυχνια (y)
Reactions: Lobo10
Nexus
29 August 2007
508
Τα HDR10 - Dolby Vision - HDR10+ είναι απλά διαφορετικά standards για να επιτευχθεί το μεγαλύτερο δυναμικό εύρος στην εικόνα, που ονομάζεται HDR (High Dynamic Range).
Σε σχέση με το SDR (Standard Dynamic Range), που είναι αυτό που είχαμε συνηθίσει πριν την έλευση του 4Κ, το HDR προσφέρει μεγαλύτερη γκάμα χρωμάτων (P3/Rec2020 σε σχέση με το Rec709 του SDR), υψηλότερο peak brightness >1000nits σε σχέση μετα 100Nits στο SDR, και μεγαλύτερο βάθος χρώματος (10bit/12bit σε σχέση με τα 8bit).
Από τα 3 HDR standards που υπάρχουν σήμερα, το DV είναι κατά πολύ ανώτερο του απλού HDR10, καθώς οι παράμετροι της εικόνας αλλάζουν δυναμικά καρέ καρέ, κάτι που δεν κάνει το HDR10. Επίσης υποστηρίζει βάθος χρώματος 12bit και μέγιστη φωτεινότητα τα 10,000 nits, αλλά αυτά έχουν λιγότερη σημασία καθώς οι περισσότερες τηλεοράσεις δεν υποστηρίζουν κάτι παραπάνω από 10bit/1000nits. Το HDR10+ υποστηρίζει και αυτό δυναμική αλλαγή των παραμέτρων της εικόνας ανά καρέ, και μέγιστη φωτεινότητα τα 4,000Nits.
Το Netflix, AppleTV, Disney+ υποστηρίζουν το DV για την μέγιστη ποιότητα εικόνας σε επιλεγμένες ταινίες, ενώ το Amazon στις περισσότερες HDR ταινίες του υποστηρίζει μόνο το HDR10. Κάτι που θα πρέπει να προστεθεί είναι ότι ενώ τα HDR10/HDR10+ είναι ανοιχτά standards και δωρεάν, το Dolby Vision ανήκει στην Dolby και δεν είναι δωρεάν, για αυτό και κάποιες συσκευές δεν το υποστηρίζουν.
Αν η TV σου υποστηρίζει DV, τότε το Netflix επιλέγει αυτόματα αυτό σαν το καλύτερο format που μπορεί να χρησιμοποιηθεί για την αναπαραγωγή των HDR ταινιών.
Robin Hood
15 September 2011
250
Παρατήρησα (3d μικρη αισθηση ) και περισσότερο βαθος στο prime σε ταινιες HDR παντα στο hdr mode (ελαφρως πειραγμενο με τις απαιτήσεις μου). Στο netflix δεν βλεπω κατι τετοιο στο (DOLBY VISION) αυτην την μικρο αίσθηση!!
Το personal τεστ εγινε με τις εφαρμογες στην TV και οχι απο εξωτερικη πηγη.Το γραφω αυτο γιατι δοκιμασα ενα pc παλιο και η TV δεν αναγνωρισε το Mode .H καρτα γραφικων δεν ανοιγει το HDR της cx απλα βλεπεις οτι δινει η καρτα. To δικο μου pc για τα μπαζα .... :coffee:
@ να γραψω οτι δεν εχω σχεση ουτε με την amazon ουτε με την netflix προσπαθω να δω τι στελνουν αυτοι σε ποιοτητα ,ασχετως τι γραφουν πανω απο τις ταινιες καθως και την συμπεριφορασ της ΤV και κοντινα μοντελα. Το πακετο του netfflix ειναι το ultra για ενα φιλο που ειχε ρωτησει ξεχασα να απαντησω
Το netflix εχει πολυ περισσοτερες ταινιες αλλα οταν μπει η cx στο mode HDR εχω την εντυπωση παμε καπου αλου ...;)
Οσοι δεν εχετε το prime υπαρχει ενα mode στην cx EΦΕ HDR .Αν το γυρισετε εκει σε μια ταινια ειναι λιγο ζαλαδα!! Ε σκεφτείτε στο Prime αυτο το εφε χωρις ζαλαδα δηλαδη οπως πρεπει ..:cool: Ισως να υπαρχουν και αλλες εφαρμογες εκτος του Prime θα σας παει στο mode και θα εχετε και εσεις τα δικα σας συμπερασματα!!
Aυτα τα ολιγα....
Lobo10
23 May 2012
3,898
Aυτα τα ολιγα....
Νομίζω μπαίνει αυτόματα σε hdr filmmaker mode στο prime το οποίο σύμφωνα με μαρτυρίες επαγγελματιών του χώρου (calibration experts) είναι αρκετά καλά ρυθμισμένο out of the box.
Αν φέρεις επαγγελματία στο σπίτι να στη ρυθμίσει, το Dolby Vision υπερτερεί του HDR10 σε αρκετές παραμέτρους που έχουν αναλυθεί σε προηγούμενα post.
Robin Hood
15 September 2011
250
Ναι αυτοματα μπαινει φευγει απο τα κλασικα modes και μπαινει στο (HDR FILMAKER MODE) .Αμα θελεις το πας και αλλου να μπαινει αυτοματα. Εγω πειραξα το filmaker ελαχιστα και ερασιτεχνικα.
Μαλιστα για αυτο ειδα την διαφορα αυτη..Σιγουρα εναs επαγγελματιας θα τα παει ουρανο και τα δυο modes συμφωνώ απολυτα ..:)
