LG E9 : Reviews - Εντυπώσεις - Σχόλια
georgedim33
2 August 2019
27
Καλησπερα.ειμαι κατοχος μιας e9 oled.παρακολουθω netflix και οταν παιζει το woofer τριζει ασχημα.εχει κανεις καμια εμπειρια να μου πει η να τηλ σε lg.συγκεγκριμενα μου τριζει παρα πολυ στη σειρα "another life"που εχει και atmos.
Reviews - tests:
-55"...[lesnumeriques.com]...LG 55E9 review...https://www.lesnumeriques.com/tv-televiseur/lg-55e9-p51607/test.html
μετάφραση google fr to en
24e51461-televiseur-oled-lg-55e9-un-design-et-une-barre-de-son-pour-faire-la-difference__w800.jpeg
622fd9a3-televiseur-oled-lg-55e9-un-design-et-une-barre-de-son-pour-faire-la-difference__w800.jpeg
-55"...[rtings.com]...LG 55E9PUA review...https://www.rtings.com/tv/reviews/lg/e9-oled
-55"...[homecinemamagazine.nl]...LG 55E9PLA review,calibration...https://www.homecinemamagazine.nl/2019/12/review-lg-oled55e9pla-e9-serie-oled-tv/
μετάφραση google nl to en
-55"...[avforums.com]...LG 55E9 review...https://www.avforums.com/reviews/lg-e9-oled55e9-oled-tv-review.16889
image.php
Comparison:
LG E8 vs LG E9 side-by-side comparison ...https://www.rtings.com/tv/tools/compare/lg-e8-vs-lg-e9/608/907
-We review the LG E9 OLED TV which is a step-up model from the C9, and explain the new [Dynamic Tone Mapping] "HGIG" option added since firmware 04.70.05.
Features include a picture-on-glass design and improved sound quality.
Our review sample is the 55-inch LG OLED55E9PLA which is the UK 3-pin plug version.
https://www.youtube.com/watch?v=9SY1e8s4pHU
source video:[hdtvtest.co.uk]
-We compare the picture quality of the LG E9 and Sony AG9 (also marketed as the Bravia A9G) 2019 OLED TVs. The results of this comparison can also be applied to the LG C9, since it uses the same panel and video processor as the E9.
Topics covered include near-black handling, colour accuracy, motion, video processing, HDR and gaming.
https://www.youtube.com/watch?v=AuVw4oEMDgA
-65"...[avmagazine.it]...LG 65E9PLA test...https://www.avmagazine.it/articoli/4K/1328/supertest-oled-4k-lg-65e9_index.html
μετάφραση google it to en
Made in Republic of Korea
Sub-pixel macro-photography of the seventh, eighth and ninth generation LG Display (LGD) panels.
Αρχικές ενδεικτικές τιμές:
65E9 : 4.299
55E9 : 3.299
georgedim33
2 August 2019
27
Lg oled65e9
Ειμαι κατοχος της lg oled65e9.θα ηθελα να ρωτησω το εξης το wooder της τριζει απιστευτα και ενοχλητικα.εχει κανεις καμια εμπειρια να μου πει η να καλεσω στην lg για τυχον προβλημα.
Werewolf
15 January 2010
7,214
Απάντηση: Lg oled65e9
Εχεις ηδη ρωτησει εδω.
https://avclub.gr/forum/showthread.php/168414-LG-E9-Reviews-%CE%95%CE%BD%CF%84%CF%85%CF%80%CF%8E%CF%83%CE%B5%CE%B9%CF%82-%CE%A3%CF%87%CF%8C%CE%BB%CE%B9%CE%B1?p=1058362171&highlight=#post1058362171
Επειδη καποιος δεν μπορει να γνωριζει τι εσυ θεωρεις ενοχλητικο, σε τι σταθμες ακους τους τριγμους, αν εχεις τερματισει απο καποιο eq τις χαμηλες συχνοτητες κλπ καταλαβαινεις οτι ειναι δυσκολο να σου απαντησει καποιος, ειδικα εαν δεν εχει το ιδιο μοντελο.
Η σειρα Ε θεωρειται πως εχει καλυτερο ηχο απο τις σειρες Β/C. Εαν πιστευεις οτι το προβλημα εμφανιζεται ακομα κι οταν δεν παιζεις σε αρκετα ανεβασμενες σταθμες (συμφωνα παντα με τις ικανοτητες μιας Tv), θα ηταν συνετο να επικοινωνησεις με το σερβις.
georgedim33
2 August 2019
27
Για παραδειγμα βλεπω στο netflix το another life το woofer τριζει ακομα και στο 15 volume δεν συζηταω για 30 ενταση και πανω επισης δεν εχω πειραξει τιποτα μαμα ολα ειναι στον ηχο.το μονο που εχω βαλει on ειναι dolby atmos και AI τιποτα αλλο.εκανα τεστ στο you tube βαζοντας test woofer και μιλαμε οτι τριζει ολο το πλαστικο απο πισω για να καταλαβεις.απλα ζηταω καποια εμπειρια και απο c9 εστω γιατι γνωριζω οτι εχει woofer πριν μπλεξω με το σερβις ασκοπα και την ανοιγουν,θα ηθελα να ειμαι λιγο πιο σιγουρος πρωτα.
Panoramix
31 January 2012
11,421
Re: Lg oled65e9
Αυτό το πράγμα που φοβόμαστε μη μας μας ανοιξει την τηλεόραση το σέρβις λες και είναι γερός που θα μπει χειρουργείο και φοβόμαστε μη δε ξυπνήσει από τη νάρκωση είναι πολύ γλυκούλι.
Σε κάποιο μαγαζί που να την έχει στημένη δε μπορείς να ακούσεις πρώτα Μήπως βγάλεις κάποιο συμπερασμα;
georgedim33
2 August 2019
27
Αυτο το εχω κανει ηδη αλλα δεν εχουν καποια ανοιχτη.μονο τη c9 βρηκα σε public στο mall και οταν του ζητησα τη χαρη αυτη αυτος βαριοτανε που ζουσε και με ξαποστειλε με τροπο.ενταξει δε θα πεθανω κιολας 5 ετη εγγυηση εχω,θα δειξει στη πορεια.ερχομαι απο c7 προβληματικη για να καταλαβεις και το σερβις του μανωλοπουλου στην lg ειναι το πιο αθλιο.στο λεω εντελως εμπειρικα πλεον με πολυ ταλαιπορεια.
georgedim33
2 August 2019
27
Τελικα δοκιμασα σε πλαισιο μια αλλη τηλ.και ετριζε και αυτη.τι να πω αντε βγαλε ακρη
czoun
29 November 2007
7,734
Πρόβλημα στην οθόνη (εξωτερικα)
Burn in έπαθε , κέρμα ήταν ....Η σχετική συζήτηση μεταφέρθηκε στο ανωτέρω link και βλέπουμε.
EDIT
Παραθέτω και εδώ σχετική παραπομπή για την αποφυγή παρεξηγήσεων.
Αν το εκλάβατε ως επιθετικό, σας ενημερώνω ότι δεν ήταν πρόθεσή μου.
Σχετικά με το αν διαβάζουμε πριν απαντήσουμε, διάβασα και το μήνυμά σας στο νήμα κατόχων της Ε9 και το μήνυμά σας από το πρόβλημα που είχατε αναφέρει πριν το burn in.
Διερωτήθηκα πιο συνέβη πρώτο και συγχώνευσα τα μηνύματα σας για να σας ρωτήσω αργότερα, όπερ και εγένετο.
Άλλωστε, το ερώτημά σας αφορά γενικότερο προβληματισμό περί OLED και όχι αποκλειστικά της Ε9, γι' αυτό και λάβατε δύο απαντήσεις με παράθεση του σχετικού συνδέσμου.
Δεν είδα να σας ενόχλησε εξίσου - η προηγηθείσα της δικής μου - προτροπή του μέλους djx33 να διαβάσετε και εκλαμβάνω το Υ.Γ.: σας περισσότερο επιθετικό από το δικό μου.
Σε κάθε περίπτωση σας εύχομαι καλή συνέχεια και να απολαύσετε τη νέα σας τηλεόραση.
anegefalos
16 January 2012
16
Καλησπερα,ποιες ειναι οι προτεινομενες ρυθμισεις εικονας για να μειωθει η πιθανοτητα εμφανισης burn in;Ευχαριστω
Lobo10
23 May 2012
3,891
Τηλεοπτικό εγώ παίζω στο oled light 30 σε LG GX. Εσύ ποια έχεις;
anegefalos
16 January 2012
16
Εγω εχω την e9.oled light εννοεις τη λυχνια oled προφανως.Τις υπολοιπες ρυθμισεις ως εχουν;
Lobo10
23 May 2012
3,891
Ναι για προστασία από burn in δεν χρειάζεται κάτι άλλο.
Είναι by default και η φωτεινότητα λογοτύπου στο low και η μετακίνηση οθόνης στο ON.
Τσέκαρε όμως.
anegefalos
16 January 2012
16
Τσέκαρε όμως.
Ναι αυτα ειναι στο οn.Για netflix και video games η λυχνια στο 85 ειναι οκ;
Lobo10
23 May 2012
3,891
Netflix σε Dolby Vision και HDR γενικά χωρίς λογότυπα παίζεις με ασφάλεια στο 100.
HDR Gaming 80 με 90 είσαι Οκ.
Απλά να τηρείς το κλείσιμο για 10 λεπτά ανά 4-5 ώρες ώστε να πραγματοποιηθούν τα Compensation Circles.
anegefalos
16 January 2012
16
Σε ευχαριστω πολυ
Reactions: Lobo10
