H τηλεόραση είναι LG 42 LM670S
To media info του αρχείου που μου παίζει μόνο ήχο:
General
Unique ID : 175097811249744842042376190497610117516 (0x83BA9C9E27B25BD4BE9F4337B295B18C)
Complete name :
Format : Matroska
Format version : Version 2
File size : 6.75 GiB
Duration : 1h 48mn
Overall bit rate : 8 893 Kbps
Encoded date : UTC 2010-10-04 10:51:07
Writing application : mkvmerge v2.9.7 ('Tenderness') built on Jul 1 2009 18:43:35
Writing library : libebml v0.7.7 + libmatroska v0.8.1
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : [email protected]
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Codec ID : V_MPEG4/ISO/AVC
Duration : 1h 48mn
Bit rate : 6 567 Kbps
Width : 1 280 pixels
Height : 1 440 pixels
Display aspect ratio : 0.889
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.149
Stream size : 4.98 GiB (74%)
Writing library : x264 core 105 r1724 b02df7b
Encoding settings : cabac=1 / ref=4 / deblock=1:-2:-2 / analyse=0x3:0x113 / me=umh / subme=7 / psy=1 / psy_rd=1.00:0.15 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-3 / threads=6 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / constrained_intra=0 / bframes=6 / b_pyramid=0 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=crf / mbtree=1 / crf=18.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
Language : English
Default : Yes
Forced : No
Audio #1
Format : AC-3
Format/Info : Audio Coding 3
Mode extension : CM (complete main)
Codec ID : A_AC3
Duration : 1h 48mn
Bit rate mode : Constant
Bit rate : 640 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Compression mode : Lossy
Stream size : 497 MiB (7%)
Language : Russian
Default : Yes
Forced : No
Audio #2
Format : DTS
Format/Info : Digital Theater Systems
Format profile : ES
Codec ID : A_DTS
Duration : 1h 48mn
Bit rate : 1 510 Kbps
Bit depth : 24 bits
Stream size : 1.15 GiB (17%)
Language : English
Default : No
Forced : No
Το media info του αρχείου που δεν παίζει καθόλου έχει απαγορευτικό κόκκινο σημάδι πάνω στο αρχείο:
Format : Matroska
File size : 7.99 GiB
Duration : 44mn 4s
Overall bit rate : 26.0 Mbps
Encoded date : UTC 2012-02-27 17:02:28
Writing application : mkvmerge v3.4.0 ('Rapunzel') сборка от May 15 2010 09:38:20
Writing library : libebml v0.8.0 + libmatroska v0.9.0
Video
Format : AVC
Format settings, ReFrames : 5 frames
Duration : 44mn 4s
Bit rate : 22.4 Mbps
Width : 1 920 pixels
Height : 2 160 pixels
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.225
Stream size : 6.90 GiB (86%)
Writing library : x264 core 119 r2106 07efeb4
Encoding settings : cabac=1 / ref=5 / deblock=1:-3:-3 / analyse=0x3:0x113 / me=umh / subme=9 / psy=1 / psy_rd=1.00:0.15 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-3 / threads=6 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=4 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=crf / mbtree=1 / crf=18.0 / qcomp=0.60 / qpmin=10 / qpmax=69 / qpstep=4 / vbv_maxrate=40000 / vbv_bufsize=40000 / crf_max=0.0 / nal_hrd=none / ip_ratio=1.40 / aq=1:1.00
Default : Yes
Forced : No
Audio #1
Format : DTS
Codec ID : A_DTS
Duration : 44mn 4s
Bit depth : 16 bits
Stream size : 476 MiB (6%)
Language : Russian
Default : Yes
Forced : No
Audio #2
Format : DTS
Codec ID : A_DTS
Duration : 44mn 4s
Bit depth : 24 bits
Language : English
Default : No
Forced : No
Και το media info ενός mkv αρχείου που παίζει κανονικά όπως και τα περισσότερα:
Format : Matroska
File size : 7.74 GiB
Duration : 1h 34mn
Overall bit rate : 11.7 Mbps
Encoded date : UTC 2012-06-07 15:44:56
Writing application : mkvmerge v4.2.0 ('No Talking') built on Jul 28 2010 18:38:23
Writing library : libebml v1.0.0 + libmatroska v1.0.0
Video
Format : AVC
Muxing mode : Header stripping
Duration : 1h 34mn
Bit rate : 9 500 Kbps
Nominal bit rate : 10 000 Kbps
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Variable
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.191
Stream size : 6.29 GiB (81%)
Writing library : x264 core 107 r1745 4785e8e
Encoding settings : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x3:0x113 / me=hex / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=6 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=abr / mbtree=1 / bitrate=10000 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / ip_ratio=1.41 / aq=1:1.00
Default : Yes
Forced : No
Audio #1
Format : DTS
Codec ID : A_DTS
Duration : 1h 34mn
Bit depth : 24 bits
Stream size : 1 024 MiB (13%)
Default : Yes
Forced : No
Audio #2
Format : AC-3
Codec ID : A_AC3
Duration : 1h 34mn
Bit rate : 448 Kbps
Bit depth : 16 bits
Stream size : 304 MiB (4%)
Language : Greek
Default : No
Forced : No
Text
Format : PGS
Muxing mode : zlib
Codec ID : S_HDMV/PGS
Codec ID/Info : The same subtitle format used on BDs/HD-DVDs
Language : grc
Default : Yes
Forced : No
Menu
00:00:00.000 : en:00:00:00.000
00:03:22.411 : en:00:03:22.411
00:06:31.891 : en:00:06:31.891
00:12:05.099 : en:00:12:05.099
00:13:50.496 : en:00:13:50.496
00:18:38.826 : en:00:18:38.826
00:23:06.844 : en:00:23:06.844
00:25:56.221 : en:00:25:56.221
00:30:40.839 : en:00:30:40.839
00:34:48.753 : en:00:34:48.753
00:39:43.047 : en:00:39:43.047
00:43:38.366 : en:00:43:38.366
00:48:19.188 : en:00:48:19.188
00:52:52.502 : en:00:52:52.502
00:56:46.111 : en:00:56:46.111
01:02:08.016 : en:01:02:08.016
01:09:23.868 : en:01:09:23.868
01:16:25.456 : en:01:16:25.456
01:22:41.581 : en:01:22:41.581
01:27:35.375 : en:01:27:35.375
Τι γίνεται ακριβώς και δεν παίζουν μερικά ή δεν έχουν εικόνα αλλά μόνο ήχο ;
Καλημέρα και καλως σας βρήκα,
Στον Browser της SmartTV 42 LM670S υπάρχει κουμπί που όταν θέλω να ανοίξω ένα link να μου το ανοίγει σε άλλη καρτέλα ; όπως κάνουμε στον firefox και σε άλλους browsers ;
General
Complete name :
Format : Matroska
Duration : 1h 48mn
Video
Format : AVC
Duration : 1h 48mn
Color space : YUV
Bit depth : 8 bits
Language : English
Default : Yes
Forced : No
Audio #1
Format : AC-3
Codec ID : A_AC3
Duration : 1h 48mn
Bit rate : 640 Kbps
Bit depth : 16 bits
Language : Russian
Default : Yes
Forced : No
Audio #2
Format : DTS
Format profile : ES
Codec ID : A_DTS
Duration : 1h 48mn
Bit depth : 24 bits
Language : English
Default : No
Forced : No
Format : Matroska
Duration : 44mn 4s
Video
Format : AVC
Duration : 44mn 4s
Color space : YUV
Bit depth : 8 bits
Default : Yes
Forced : No
Audio #1
Format : DTS
Codec ID : A_DTS
Duration : 44mn 4s
Bit depth : 16 bits
Language : Russian
Default : Yes
Forced : No
Audio #2
Format : DTS
Codec ID : A_DTS
Duration : 44mn 4s
Bit depth : 24 bits
Language : English
Default : No
Forced : No
Format : Matroska
Duration : 1h 34mn
Video
Format : AVC
Duration : 1h 34mn
Color space : YUV
Bit depth : 8 bits
Default : Yes
Forced : No
Audio #1
Format : DTS
Codec ID : A_DTS
Duration : 1h 34mn
Bit depth : 24 bits
Default : Yes
Forced : No
Audio #2
Format : AC-3
Codec ID : A_AC3
Duration : 1h 34mn
Bit rate : 448 Kbps
Bit depth : 16 bits
Language : Greek
Default : No
Forced : No
Text
Format : PGS
Muxing mode : zlib
Language : grc
Default : Yes
Forced : No
Menu
