LG TV 2018 - european models | | | | | | | | | | | | |
____________________ | W8, G8, E8, C8
______________________ | B8
______________________ | SK95
______________________ | SK90 / SK85
______________________ | SK81 / SK80
_______________________ | SK79
_____________________ | UK77 / UK75
____________________ | UK69 / UK67
____________________ | UK65
___________________ | UK64
___________________ | UK63
___________________ | UK61
_________________ |
Hardware & OS | | | | | | | | | | | | |
CPU - marketing name | Alpha 9 | Alpha 7 | Alpha 7 | Alpha 7 | Alpha 7 | | | | | | | |
CPU - frequency | 1.008GHz | 1.008GHz | 1.008GHz | 1.008GHz | 1.2GHz | 1.2GHz | 1.2GHz | 1.2GHz | 1.2GHz | 1.2GHz | 1.2GHz | |
CPU - cores | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | |
GPU - cores | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | |
DDR - RAM (GB) | 3GB | 2GB | 2GB | 2GB | 2GB | 2GB | 1.5GB | 1.5GB | 1.5GB | 1.5GB | 1.5GB | |
DDR - ROM
Вътрешно пространство за съхранение (GB) | 8GB | 8GB | 4GB | 4GB | 4GB | 4GB | 4GB | 4GB | 4GB | 4GB | 4GB | |
Panel | | | | | | | | | | | | |
Type of matrix | OLED | OLED | 65 - S-IPS
55 - S-IPS | 65 - S-IPS (RGB)
55 - S-IPS (RGB)
49 - S-IPS (RGB) | 75 - S-IPS (RGB)
65 - S-IPS (RGB)
55 - S-IPS (RGB)
49 - S-IPS (RGB) | 65 - S-IPS (RGB)
55 - S-IPS (RGB)
55 - S-IPS (RGB)
49 - S-IPS (RGB) | 70 - A-MVA
65 - S-IPS
55 - S-IPS
50 - A-MVA (RGB)
43 - S-IPS | 86 - S-IPS ()
75 - S-IPS
70 - A-MVA (RGB)
65 - S-IPS
50 - A-MVA (RGB)
43 - S-IPS | 65 - S-IPS | 65 - S-IPS (WRGB)
55 - S-IPS
50 - A-MVA (RGB)
49 - S-IPS
Panel frequency | 120Hz | 120Hz | 65/55 - 120/100Hz | 65/55 - 120/100Hz | 75/65/55 - 120/100Hz
49 - 60/50Hz | 65/55/49 - 60/50Hz | 65/55/49 - 60/50Hz | 75 - 120/100Hz
65/55/50/43 - 60/50Hz | 86/75 - 120/100Hz
43 - 60/50Hz | 60/50Hz | 60/50Hz | |
Backlight | Self-luminous pixels (no backlight) | Self-luminous pixels (no backlight) | FALD Pro | Slim Direct LED | Edge LED | Edge LED | Edge LED | Edge LED | 70 - Edge LED
50/43 - Direct LED | Direct LED | 65, 55 - Direct LED
50/49/43 - Edge LED | 65 - Direct LED |
Local Dimming | Pixel Dimming / Self Lighting Pixel | Pixel Dimming / Self Lighting Pixel | 96 zones | 48 zones | Local Dimming | Local Dimming | Local Dimming | Local Dimming | Global Dimming | Global Dimming | Global Dimming | |
Color Depth | 10-bit | 10-bit | 10-bit | 10-bit | 10-bit | 10-bit | 8-bit + FRC | 8-bit + FRC | 8-bit | 8-bit | 8-bit | |
Nano Cell | - | - | 2.Generation | 2.Generation | 2. Generation | 2.Generation | 2.Generation | - | - | | - | |
Brightness - SDR/HDR | 200/400nit,
800nit | 200/400nit,
800nit | 200/560,
400nit / 700nit | 200/400,
450nit / 540nit | 200/ | 200/300 | 200/320,
600nit/400nit | | 200/400,
750nit/500nit | | 200/280,
350nit / 350nit | |
Uniformity | ≥70% | ≤70% | ≥65% | ≥65% | ≥65% | | ≥65% | | ≥65% | | ≥65% | |
Contrast | 140 000:1 | 140 000:1 | 200:1, 1600:1(?) | 200:1, 1600:1(?) | 200:1, 1400:1 (?) | 200:1, 1400:1 (?) | 200:1, 1400:1(?) | 200:1, 1 | 200:1, 1200:1(?) | | 200:1, 1200:1(?) | |
Gamut coverage | 98.5 DCI P3 uv | 98.5 DCI P3 uv | 94% DCI P3 uv | 94% DCI P3 uv
74% Rec.2020 uv | 90% DCI P3 | | 90% DCI P3 uv | | 84% DCI P3 uv | | 80% DCI P3 uv | |
Response Time
(време за реакция) | ≤28ms | ≤28ms | 32ms ≤ 8ms (Тип.)
≤ 12ms (Макс) | 32ms ≤ 8ms (Тип.)
≤ 12ms (Макс) | ≤ 32ms ≤ 8ms (Тип)
≤ 12ms (Макс) | | ≤ 32ms ≤ 8ms (Тип)
≤ 12ms (Макс) | | ≤ 32ms ≤ 9ms (Тип)
≤ 13ms (Макс) | |
PWM dimming frequency | 0Hz
Flicker Free | 0Hz
Flicker Free | 120Hz | 120Hz | | | | | | | | |
Viewing Angle
Color Shift
Brightness
Black Level | - | - | - | -
25 °
31 °
75 ° | - | - | - | - | | | | |
Black Frame Insertion (BFI) | Yes | Yes | Yes | Yes | | | | | | | | |
Motion Interpolation | TruMotion | TruMotion | TruMotion | TruMotion 200 | 75/65/55 - TruMotion 200
49 - TruMotion 100 | TruMotion 100 | | | 86/75 - TruMotion 200
49 - TruMotion 100 | TruMotion 100 | TruMotion 100 | TruMotion 100 |
IMAGE | | | | | | | | | | | | |
Active HDR | Dolby Vision
Technicolor Advanced HDR | Dolby Vision
Technicolor Advanced HDR | | | | | | |
Passive HDR | HDR 10 Pro
HLG | HDR 10
HLG | HDR 10
HLG | HDR 10
HLG | HDR 10
HLG | HDR 10
HLG | HDR 10
HLG | HDR 10
HLG | HDR 10
HLG | HDR 10
HLG | HDR 10
HLG | HDR 10
HLG |
HFR | 4K: USB (without HDR)
2K: HDMI, USB | | 4K: USB (without HDR)
2K: HDMI, USB | 4K: USB (without HDR)
2K: HDMI, USB | 4K: USB (without HDR);
2K: HDMI, USB | 2K: HDMI (60Hz),
USB (60Hz) | 2K: HDMI (60Hz), USB (60Hz) | 2K: HDMI (60Hz), USB (60Hz) | 2K: HDMI (60Hz), USB (60Hz) | 2K: HDMI (60Hz), USB (60Hz) | 2K: HDMI (60Hz), USB (60Hz) | No |
Support for video decoder | HEVC (4K @ 120P, 10-bit)
VP9 (4K @ 60P, 10-bit),
SHVC (4K @ 60P, 10-bit) | HEVC (4K @ 120P, 10-bit), VP9 (4K @ 60P, 10-bit), SHVC (4K @ 60P, 10-bit) | HEVC (4K @ 120P, 10-bit), VP9 (4K @ 60P, 10-bit), SHVC (4K @ 60P, 10-bit) | HEVC (4K @ 120P, 10-bit), VP9 (4K @ 60P, 10-bit), SHVC (4K @ 60P, 10-bit) | HEVC (4K @ 120P, 10-bit), VP9 (4K @ 60P, 10-bit), SHVC (4K @ 60P, 10-bit) | HEVC (4K @ 120P, 10-bit), VP9 (4K @ 60P, 10-bit), SHVC (4K @ 60P, 10-bit) | HEVC (4K @ 60P, 10-bit), VP9 (4K @ 60P, 10-bit), SHVC (4K @ 60P, 10-bit) | HEVC (4K @ 60P, 10-bit), VP9 (4K @ 60P, 10-bit), SHVC (4K @ 60P, 10-bit) | | | | |
Audio | | | | | | | | | | | | |
Акустична честотна характеристика | 160Hz-6300Hz | 160Hz-6300Hz | 160Hz-6300Hz | 160Hz-6300Hz | 160Hz-6300Hz | 160Hz - 6300Hz | 160Hz-6300Hz | 160Hz-6300Hz | 160Hz-6300Hz | 160Hz-6300Hz | 160Hz-6300Hz | |
Speaker system | W8 - 4x10W, 2x10W
65G8 - 4.2 sound system / 60 watts (subwoofer: 20 watts)
65E8 - 4.2 sound system / 60 watts (subwoofer: 20 watts)
55E8 - 2x10W, 2x10W
77C8 - 2.2 sound system / 40 watts (subwoofer: 20 watts)
65C8 - 4x10
55C8 - 2x10W, 2x10W | | | SK90 - 2.2 sound system / 40 watts (subwoofer: 20 watts)
SK85 - 2.2 sound system / 40 watts (subwoofer: 20 watts) | SK81 - 2.2 sound system / 40 watts (subwoofer: 20 watts)
SK80 - 2.0 sound system / 20 watts | 2.0 sound system,
20 watts (2x10W), | 2.0 sound system / 20 watts | 2.0 sound system / 20 watts | 2.0 sound system / 20 watts | 2.0 sound system / 20 watts | 2.0 sound system / 20 watts | 2.0 sound system / 20 watts |
Dolby Atmos | Yes | Yes | Yes | Yes | No | No | No | No | No | No | No | No |
Speaker calibration to seating position | Yes | Yes | Yes | Yes | Yes | Yes | Yes | 69 - Yes
67 - Compatible (requires Magic Remote Remote) | | | | |
Bluetooth playback via TV speakers | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | yes | Yes | |
Supported audio codecs | AC3 (Dolby Digital), EAC3, HE-AAC, AAC, MP2, MP3, PCM, DTS, DTS-HD, DTS Express, WMA, apt-X | AC3 (Dolby Digital), EAC3, HE-AAC, AAC, MP2, MP3, PCM, DTS, DTS-HD, DTS Express, WMA, apt-X | AC3 (Dolby Digital), EAC3, HE-AAC, AAC, MP2, MP3, PCM, DTS, DTS-HD, DTS Express, WMA, apt-X | AC3 (Dolby Digital), EAC3, HE-AAC, AAC, MP2, MP3, PCM, DTS, DTS-HD, DTS Express, WMA, apt-X | AC3 (Dolby Digital), EAC3, HE-AAC, AAC, MP2, MP3, PCM, DTS, DTS-HD, DTS Express, WMA, apt-X | AC3 (Dolby Digital), EAC3, HE-AAC, AAC, MP2, MP3, PCM, DTS, DTS-HD, DTS Express, WMA, apt-X | | | AC3 (Dolby Digital), EAC3, HE-AAC, AAC, MP2, MP3, PCM, DTS, DTS-HD, DTS Express, WMA, apt-X | AC3 (Dolby Digital), EAC3, HE-AAC, AAC, MP2, MP3, PCM, DTS, DTS-HD, DTS Express, WMA, apt-X | AC3 (Dolby Digital), EAC3, HE-AAC, AAC, MP2, MP3, PCM, DTS, DTS-HD, DTS Express, WMA, apt-X | |
Smart TV | | | | | | | | | | | | |
Smart TV platform | webOS 4.0 | webOS 4.0 | webOS 4.0 | webOS 4.0 | webOS 4.0 | webOS 3.5 | webOS 4.0 | webOS 4.0 | webOS 4.0 | webOS 4.0 | webOS 4.0 | webOS 3.5 |
Web browser | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes |
My channels | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes |
Magic Link | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes |
Service | | | | | | | | | | | | |
Magic remote remote control | Included | Included | Included | Included | Included | Included | Included | 69 - Included
67 - Compatible (not included) | Compatible (not included) | Compatible (not included) | Compatible (not included) | Compatible (not included) |
Remote control (type) | LG Magic Remote Remote Control (MR18) | LG Magic Remote Remote Control (MR18) | LG Magic Remote Remote Control (MR18) | LG Magic Remote Remote Control (MR18) | LG Magic Remote Remote Control (MR18) | LG Magic Remote Remote Control (MR15RA) | LG Magic Remote Remote Control (MR18) | LG Magic Remote Remote Control (MR18) | | | | |
Remote control via app (LG TV Plus) | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes |
Intelligent speech recognition | Yes (German, English, Italian, French, Spanish, Portuguese, Polish) | Yes (German, English, Italian, French, Spanish, Portuguese, Polish) | Yes (German, English, Italian, French, Spanish, Portuguese, Polish) | Yes (German, English, Italian, French, Spanish, Portuguese, Polish) | Yes (German, English, Italian, French, Spanish, Portuguese, Polish) | Yes (German, English, Italian, French, Spanish, Portuguese, Polish) | | Compatible (German, English, Italian, French, Spanish, Portuguese, Polish, Turkish, Russian, Korean) (Requires Magic Remote Remote Control) | Compatible (German, English, Italian, French, Spanish, Portuguese, Polish, Turkish, Russian, Korean) (Requires Magic Remote Remote Control) | Compatible (German, English, Italian, French, Spanish, Portuguese, Polish, Turkish, Russian, Korean) (Requires Magic Remote Remote Control) | Compatible (German, English, Italian, French, Spanish, Portuguese, Polish, Turkish, Russian, Korean) (Requires Magic Remote Remote Control) | Compatible (German, English, Italian, French, Spanish, Portuguese, Polish, Turkish, Russian, Korean) (Requires Magic Remote Remote Control) |
Convert speech to text (speech-to-text) | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes |
Let texts speak (text-to-speech) | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes |
Quick Access (Hotkeys / Favorites) | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes |
Magic Zoom features | Live Zoom, Focus Zoom | Live Zoom, Focus Zoom | Live Zoom, Focus Zoom | Live Zoom, Focus Zoom | Live Zoom, Focus Zoom | Live Zoom, Focus Zoom | | Live Zoom, Focus Zoom (requires Magic Remote Remote Control) | Live Zoom, Focus Zoom (requires Magic Remote Remote Control) | Live Zoom, Focus Zoom (requires Magic Remote Remote Control) | Live Zoom, Focus Zoom (requires Magic Remote Remote Control) | Live Zoom, Focus Zoom (requires Magic Remote Remote Control) |
360VR | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes |
Network Support | LAN, WLAN, Bluetooth | LAN, WLAN, Bluetooth | LAN, WLAN, Bluetooth | LAN, WLAN, Bluetooth | LAN, WLAN, Bluetooth | LAN, WLAN, Bluetooth | LAN, WLAN, Bluetooth | LAN, WLAN, Bluetooth | LAN, WLAN, Bluetooth | LAN, WLAN, Bluetooth | LAN, WLAN, Bluetooth | LAN, WLAN, Bluetooth |
Screen Share functions
(Screen Mirroring) | Miracast overlay | Miracast overlay | Miracast overlay | Miracast overlay | Miracast overlay | Miracast | Miracast | Miracast | Miracast | Miracast | Miracast | Miracast |
DLNA | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes |
LG Sound Sync | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes |
SIMPLINK (HDMI CEC) | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes |
Various functions | | | | | | | | | | | | |
Auto calibration | Yes | Yes | Yes | Yes | Yes | No | No | No | No | No | No | No |
Gallery | Yes | Yes | Yes | Yes | Yes | No | No | No | No | No | No | No |
Picture-in-Picture (Multi-View) | Yes | Yes | Yes | Yes | Yes | Yes | | | No | No | No | No |
music player | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes |
Recording on external USB hard disk | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes |
Timeshift (time-shifted television) | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes |
Timer-controlled recording | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes |
Network-enabled file browser | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes |
Connections | | | | | | | | | | | | |
HDMI | 4 | 4 | 4 | 4 | 4 | 4 | | | 3 | 3 | 3 | 3 |
ARC support (Audio Return Channel) | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes |
USB | 3 | 3 | 3 | 3 | 3 | 2 | 2 | 2 | 2 | 2 | 2 | 2 |
LAN (Ethernet / RJ45) | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes |
WIRELESS INTERNET ACCESS | Yes (802.11ac) | Yes (802.11ac) | Yes (802.11ac) | Yes (802.11ac) | Yes (802.11ac) | Yes (802.11ac) | Yes (802.11ac) | Yes (802.11ac) | Yes (802.11ac) | Yes (802.11ac) | Yes (802.11ac) | Yes (802.11ac) |
Bluetooth | Yes (V4.2) | Yes (V4.2) | Yes (V4.2) | Yes (V4.2) | Yes (V4.2) | Yes (V4.2) | Yes (V4.2) | Yes (V4.2) | Yes (V4.2) | Yes (V4.2) | Yes (V4.2) | Yes |
CI + Slot (Common Interface) | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes |
CI + version (Common Interface) | CI + 1.4 | CI + 1.4 | CI + 1.4 | CI + 1.4 | CI + 1.4 | CI + 1.4 | CI + 1.4 | CI + 1.4 | CI + 1.4 | CI + 1.4 | CI + 1.4 | CI + 1.4 |
Digital audio output (optical) | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes |
Headphone output (3.5 mm jack) | Yes | Yes | Yes | Yes | Yes | Yes | | | | | | |
Component / Composite (AV) | No | No | No | No | No | Yes | Yes | Yes | Yes | Yes | Yes | Yes |
