-LG TV Line-up 2023-
xavito
29 October 2008
8,989
55"...[hdtelevizija.com]...LG 55C3 review
Is it just a repacked C2 with the latest version of the webOS smart TV platform or are there other noteworthy improvements?
Find out in this video.
LG 55C3 unboxing and installation
LG webOS 23 (version 8) overview and performance demo on 55C3
Since the introduction of the full-screen home menu, LG's webOS interface has become filled up with too much different content, making it more difficult to use.
In this video I'm showing how to simplify it with a few easy steps on 55C3 running version 23 (version 8 if we follow the old numbering).
By using a compatible LG 55C3 and LG soundbar, you could enable the so-called WOW Orchestra which uses speakers from both devices.
xavito
29 October 2008
8,989
43"...[geex.x-kom.pl]...LG 43UR78003 review...https://geex.x-kom.pl/recenzje/recenzja-lg-43ur78003/
VA panel,RGB,4-domain
Direcr LED LCD
50/60Hz
DCI-P3 (CIExy) coverage: 76%
In Filmmaker mode, on a board occupying 10% of the screen area, the maximum luminance was 289 cd/m² (nits) .
webOS 8.1
65"...[computerbild.de]...LG 65QNED826R review...https://www.computerbild.de/artikel/avf-Tests-Fernseher-LG-QNED826-37033421.html
ADS/IPS panel
Edge LED LCD
backlight is divided into six vertical stripes
100/120Hz με MCFI
most naturally in Picture Mode :Filmmaker
xavito
29 October 2008
8,989
42"...[geex.x-kom.pl]...LG 42C3 (42C33LA model) review...https://geex.x-kom.pl/recenzje/recenzja-lg-oled42c3/
In filmmaker (HDR) mode on the 10% board, the maximum luminance at the beginning of the three-minute measurement was 651 cd/m² (nits) and increased to 709 cd/m² (nits) within 180 seconds.
The luminance on a full-screen board was much lower than in a 10% window, at only 106 cd/m² (nits)
DCI-P3 (CIExy) : 95%
100/120Hz με MCFI
webOS 8.2
65"...[frandroid.com]...LG 65C3 test...https://www.frandroid.com/marques/l...un-televiseur-plus-lumineux-et-mieux-organise
xavito
29 October 2008
8,989
65"...[rtings.com]...LG 65B3PUA (US Model) review...https://www.rtings.com/tv/reviews/lg/b3-oled
Οι ρυθμίσεις είναι μόνο για αναφορά.
Δεν υπάρχει καμία εγγύηση ότι θα σας δώσουν την καλύτερη εικόνα που είναι σύμφωνη με τα πρότυπα της βιομηχανίας και κατάλληλη για το περιβάλλον προβολής σας (ειδικά ισορροπία λευκού, ρυθμίσεις συστήματος γάμμα και χρώματος που διαφέρουν από μονάδα σε μονάδα).
Εάν θέλετε μια εγγυημένη βαθμονομημένη εικόνα, καλέστε έναν επαγγελματία βαθμονομητή τηλεόρασης.
full calibration settings 65B3PUA ...https://www.rtings.com/tv/reviews/lg/b3-oled/settings
xavito
29 October 2008
8,989
50"...[geex.x-kom.pl]...LG 50QNED813R review...https://geex.x-kom.pl/recenzje/recenzja-lg-50qned813r/
η αντίστοιχη στην ελληνική αγορά είναι η 50QNED826R.
webOS 8.2
System software version 3.20.21.
Hardware platform : K8HPP
Remote control : MR23GA
Assembled in Poland.
VA panel,4-domain,vertical stripe,RGB
Edge (bottom) LED LCD
6 zones vertical stripes ,three levels of intensity,and completely switched off.
ANSI contrast ratio (factory settings of Filmmaker preset) 6100 : 1.
100/120Hz με MCFI.
DCI-P3xy : 86%.
HDR content: filmmaker preset,10% window size maximum luminance 690 cd/m² (nits).
Full-screen board the maximum luminance 523 cd/m² (nits).
no Dolby Vision.
At an angle
vertical local dimming on/off
xavito
29 October 2008
8,989
55"...[geex.x-kom.pl]....LG 55QNED863R (55QNED866R στην ελληνική αγορά) review...https://geex.x-kom.pl/recenzje/recenzja-lg-55qned863r/
ADS panel LCD,like IPS.
Direct mini LED FALD.
55" : 15 horizontal x 8 vertical = 120 dimming zones
100/120Hz με MCFI
K8HPP hardware platform (incidentally, the same as in the QNED81xR series and WOLEDs from the B3 series)
a7 gen 6
DCI-P3 (CIExy) coverage : 96%
webOS : 8.3
HDR content:
filmmaker picture preset,10% window size maximum luminance 1505 cd/m² (nits) at the beginning of this measurement,683cd/m² (nits) at the end of the three-minute measurement.
