MacBook Air Reviews (13-inch, mid-2013)
Portioli
3 June 2007
3,909
Dystopia
Λίγες αλλαγές εμφανισιακά (τι να αλλάξουν κι όλας)
Καλύτερος SSD, πιο γρήγορος επεξεργαστής (Haswell)
καλύτερα γραφικά (όχι κάτι το ιδιαίτερο) , με καλύτερη απόδοση - 12 ώρες (!).
Specs:
Hardware specs as reviewed:
  • CPU: Intel Core i5 Haswell, 1.3GHz (Turbo boost up to 2.6GHz)
  • Graphics/display: Integrated Intel HD5000, 11.6-inch display, 1366x768 (2560 by 1600 pixels on external display)
  • Memory: 4GB, 1600Mhz LPDDR3
  • Storage: 256GB
  • Ports: 2-USB 3.0, Thunderbolt, audio out, dual microphones
  • Camera: 720p Facetime camera
  • Connectivity: Wi-fi 802.11 a/b/g/n, 802.11 ac, Bluetooth 4.0
  • Battery: 39WHr, 9 hours
  • Height: 0.11-0.68 inch (0.3-1.7 cm)
  • Width: 11.8 inches (30 cm)
  • Depth: 7.56 inches (19.2 cm)
  • Weight: 2.38 pounds (1.08 kg)
Reviews:
- [Engadget] MacBook Air review (13-inch, mid-2013)
- [PCMag] Apple MacBook Air 13-inch (Mid 2013)
- [ifixit]MacBook Air 13" Mid 2013 Teardown
- 13" MacBook Air Review Roundup: Apple's Battery Claims Appear Accurate, SSD and Graphics Drive Performance Increases
- [ZDNet]New MacBook Air: Haswell ups the game (review)
- Forbes | New MacBook Air Is A Winner
- techradar.pro|Hands on: 2013 MacBook Air review
- [macuser]Το iFixit ανοίγει το νέο MacBook Air: πιο γρήγορος SSD και μεγαλύτερη μπαταρία
Portioli
3 June 2007
3,909
Dystopia
The 2013 MacBook Air Review (13-inch)
Το anandtech τεστάρει το νέο MacBook Air.
Σπάει τo κοντέρ σε αυτονομία:
This is just ridiculous. Apple claims 12 hours, we tend to test a little more strenuous than Apple does and ended up with just over 11 hours of battery life on a single charge. These highly idle cases end up dominated by display power, which is why we actually see the smallest improvement in battery life over the previous generation here (~35%, normalized for battery capacity).
If you drop brightness down to something more reasonable (~100 nits) you’ll get some truly insane numbers:
Even normalizing for battery capacity changes, the new 13-inch MacBook Air increases battery life by 65% over the previous model.
όχι τόσο εντυπωσιακά τα πράγματα για τους pcie ssd
Peak random read performance is roughly comparable to the previous-generation Samsung controller. Random write performance took a bit of a hit but it's still more than fast enough for client workloads. Sequential speeds are much improved but the gains are really only visible at high queue depths. Low queue depth sequential transfers can’t be split up enough in order to really require PCIe.
What does this mean in the real world? The new SSD is definitely snappier in system use. Wake from sleep is a bit quicker, as are application launches. The funny thing is that with the exception of high-speed Thunderbolt arrays, most external sources aren’t fast enough to even stress the new storage subsystem in the MacBook Air.
πιο αναλυτικά
papakostasl
6 November 2009
130
η οθόνη που φοράει είναι retina? αν όχι, υπάρχει προγραμματισμός για να αντικατασταθεί η υπάρχουσα με retina
ευχαριστώ
spcav
18 August 2006
16,616
Δεν ειναι retina
Δεν εχει ακουστει κατι για retina σε Air ακόμη.
Λογικα, θα γινει, το πότε, αγνωστο.
7,544
Καλημέρα σε όλους και Χρόνια Πολλά!!!
Τη δίμηνη συμβίωσή μου με το MacBook Air θα την χαρακτήριζα "ονειρώδη"!!...βέβαια το μοντέλο που έχω είναι BTO i7/8GB RAM...δεν είναι απλά πολύ γρήγορο...είναι ακαριαίο!!!..δουλεύω και το imovie και επεξεργάζομαι FULL HD βιντεάκια...τρομερή άνεση!!...δεν κάνω φοβερά και παράξενα πράγματα...η εμπειρία χρήσης όμως είναι απολαυστική!!
...κοστίζει όσο ένα ακριβό MBP...
δεν μου έχει λήψει-σε καμιά περίπτωση-η retina....κάποια στιγμή ίσως βάλλουν..σε κάποια μοντέλλα..αλλά από την άλλη σκέφτομαι ότι θα κτυπηθούν τα MBP...για σκέψου τόσο λεπτό μηχάνημα με αυτές τις επιδόσεις,αυτή την αυτονομία και retina...ίδωμεν!!!
Καλές γιορτές σε όλους!!! :))
Νάσο,θεωρείς ότι και η βασική έκδοση των 4gb Ram και 128 gb ssd με τον i5 καλύπτει ένα μέσο χρήστη,όπως εμένα δηλαδή,για καθημερινή εργασία,με τη βαρύτερη δουλειά να είναι το photoshop?Χρόνια πολλά!
