- 29 December 2008
- 1,684
Κυκλοφορησε στην Ινδονησια.Αναμενετε και στην Ευρωπη?
Και ethernet απ οτι βλεπουμε....
MANHATTAN Passion 1080 HD Vision
( Supports Streamix Data Cards )
MPEG-4/H.264/DVB-S2
576p/720p/1080i
Ethernet
USB 2.0
eSata
HDMI
Video Componenten
Analog A/V
2 x CI
1 x Card Reader
Dolby Digital
Satellites Stored 254
Transponder Capacity 3000
Channels Memory 9999
Image 63KB
Spec's:.
MAIN SYSTEM RESOURCE
Main Processor : 32Bit ARM CPU
Flash Memory : 8 MB
Graphic (MPEG) & System DRAM
: 64 MB + 32 MB
EEPROM : 8 KB (For Positional Model)
CONDITIONAL ACCESS INTERFACE
PCMCIA : 2 Slot Common Interface
CONAX CAS : 1 Slot Smart Card
TUNER & CHANNEL
Input Connector : F - Type, IEC 169-14, female
Frequeny Range : 950 to 2150 MHz
Signal Level : -25 to -65 db
LNB Power & Pollarisation
: Vertical + 13,5 V (+ 14,5 V@high Voltage), Horizontal +18(+18,5V@high Voltage)
: Current max 500 MHz (Over Load Protection)
22 KHz Tone : Frequency 22 ± 2 KHz
DisEqC Control : Version 1.0 1.1 1.2/USALS Compatable
Demodulation : OPSK, 8PSK
Input Symbol Rate
: DVB-S:2-45Ms/s,DVB-S2:10-30Ms/s(OPSK), 10-31Ms/sBPSK)
FRONT PANEL
Display : 12 Digital VFD Display
Key : 7Buttons
USB
USB 1.1/2.0 : Host Mode
MPEG TRANSPORT STREAM A/V DECODING
Transport Stream
: MPEG-2 ISO/IEC 13818, Transport Stream Specification
Profile level : MPEG2 MP@ML, MPEG2 MP@HL, MPEG4 AVC/H264 HP@L4
Input Rate : 15 MB/s Max
Aspect Ratio : 4:3, 16:9 (letter box)
Video Resolution : 720x576P. 1920x1080i, 1280x720P
Audio Decoding : MPEG-1/MusiCamLayer I&II
Audio Mode : Single Channel/Dual Channel/Joint Stereo/Stereo
A/V & DATA IN/OUT
Digital Output : HDMI
TV Scart : Video Output (CVBS, RGB) Audio Output
VCR Scart : Video Output (CVBS), Video Input (CVBS), Audio Output
Video : RCA/Cinch, Video Output (CVBS)
Audio R/L : RCA/Cinch Volume and Mute Control
S/PDIF : Digital Audio Output, Fiber Optic
RS-232 : Transfer rate 115,2 Kbps. 9 Pin D-sub type
Network : 10/100 Base-T RJ45 Port
COMPONENT VIDEO OUTPUT
Y : 1Vp-p @ internal coloured
Pb : 524mVp-p @ internal coloured
Pr : 524mVp-p @ internal coloured
RF - MODULATOR
RF-Connector : 75ohm IEC 169-2, Male / Female
Frequency : 470 to 860 MHz
Output Channel : CH21-69
TV Standard : PAL B/G/I/D/K selectable via Menu
Channel : CH4O (or TBD), Software Changeable via Menu
POWER SUPPLY
Input Voltage : 100 to 240 Vac, 50Hz/60Hz
Type : SMPS
PHYSICAL SPECIFICATION
Size (HxWxD) : 340x60x268mm
Weight (Net) : 2,5 Kg
MPEG-4/H.264/DVB-S2
576p/720p/1080i
Ethernet
USB 2.0
eSata
HDMI
Video Componenten
Analog A/V
2 x CI
1 x Card Reader
Dolby Digital
Image 63KB
Spec's:.
Flash Memory : 8 MB
: 64 MB + 32 MB
TUNER & CHANNEL
Input Symbol Rate
FRONT PANEL
Key : 7Buttons
USB
Transport Stream
A/V & DATA IN/OUT
RF - MODULATOR
POWER SUPPLY
Type : SMPS
