alambi
Νέο BETA Λογισμικό - V3.0. 5Aug2014 BETA
Βελτιώσεις:
1. Fix: jukebox: restore incorrect movie when nav Up/Down on about.jpg Movie Info Sheet and play trailer
2. Fix: jukebox+: generating new about.jpg when using 'add jukebox+'
3. Dev: tmdb: add 2 types 'Clip' and 'Teaser' into trailer filter. Default is to look for trailer tag but if its missing will then look for 'Clip' or 'Teaser' tag and use this for the Trailer Link
4. Fix: jukebox: the movie 'Slightly Single in L.A. (2013)' fail to get info.
5. Dev: tmdb: update 1.3.2
6. Dev: setup menu: remove 'System - Screensaver - Options - Flickr'
7. Dev: setup: set default value of 'Force Decode AAC/MP3' to 'on'.
8. Dev: setup menu: change 'Dont care' to 'Auto'.
NOTE: Setup Menu -
Set 'Trailers' to 'on' for Trailer functionality
Set 'force decoding of AAC/MP3 audio' to 'on' if you do net get any audio on Movie Trailers
Κατέβασμα απο εδώ
Βελτιώσεις:
NOTE: Setup Menu -
Κατέβασμα απο εδώ
