- 12 May 2009
- 5,362
Ήρθε...
Πάρτε για αρχή μια μικρή γεύσηhttps://www.stereo.net.au/reviews/musical-fidelity-m3scd-cd-player-review
M3scd - Specifications
Performance
- Jitter: <135 picoseconds peak to peak
- Frequency Response: 10Hz to 20 kHz -0.2dB max.
- Signal to Noise Ratio: >117dB
- THD(+ noise): <0.003% 10Hz to 20 kHz
- Linearity: <0.1dB down to -96dB
- Channel Separation: 105dB 20 Hz to 20 kHz
Hardware
- DAC:24 bit Delta-Sigma (bit stream) dual differential 8x over-sampling
Outputs
- 1x line level RCA
- 1x Toslink optical connector (Digital SPDIF)
- 1x Trigger output - 3.5mm (1/8”) mono jack +12V DC
Inputs
- 1x RCA coaxial connector SPDIF 32-192 kbps
- (16-24 bit stereo PCM)
- 1x TOSLINK optical connector 32-96 kbps
- 1x USB type ‘B’ connector
- Asynchronous data stream at up to 24-bit/96kHz
- Trigger in
General
