Nabilo DM800 Pure Flash 10DEC2008 + Barry Allen 4.6.38
george664
11 May 2007
1,449
ΡΕΘΥΜΝΟ
Nabilosat DM800 Pure Flash 10DEC08, with Barry Allen 4.6.38
What is the Nabilosat DM800 Pure Flash ?
This image is a simple, pure CVS image to install to flash memory. It is reccomended to those who like the multiboot option with Barry Allen. It is light, fast, reliable and, most of all, upated. Therefore, it is the best solution for multiboot purposes.​
What is included in this image ?
This image is including the latest available edition of Barry Allen: 4.6.38​
Why should I install this image in flash ?
Because it includes all the latest drivers and kernel modules required to install new images in multiboot. Nabilosat team is about to release version 0.5 of its Black Hole image. If installed to multiboot, the new Black Hole v0.5 requires an updated image in the flash memory. For this reason, Nabilosat team prepared this Pure version for you.​
How do I install Barry Allen with this image ?
Barry Allen will be automatically installed at the end of the default wizard​
Will I loose the images alread installed on my media ?
No, you will not loose any of your favourite images, already installed to your media. You will reboot and find them again, ready to be used.​
How do I install it to flash ?
You can install it via WebInterface or via serial. However, it is important that you read the simple instructions reported here under.​
Release Details
Nabilosat Bootlogo by MaximoII
Barry Allen 4.6.38 included
TARGET_ARCH = "mipsel"
TARGET_OS = "linux"
MACHINE = "dm800"
DISTRO = "opendreambox"
DISTRO_VERSION = "1.5.0"
TARGET_FPU = "soft"
COMPILED DATE = "10 december 2008"
ENIGMA2_CVS_DATE = "10 december 2008"
ENIGMA2_VERSION = "2.6 experimental"
BARRY_ALLEN_VERSION = "4.6.38"
Instructions
1) Flash your DM 800 with Web Interface or DreamUp and serial cable
2) Complete the Default Wizard to setup the basic steps
3) Upon Wizard completion, you will be prompted to press OK to install Barry Allen
4) Press OK once, and wait for the Wizard to install Barry Allen
5) When Barry Allen is updated, the Default Wizard will be completed.
6) Reboot your Dreambox
Barry Allen will have been updated. You will find your previous images listed, choose your favorite as always.
AlexT_
10,452
Θεωρητικά το Nabilo DM800 Pure Flash 10DEC2008 + Barry Allen 4.6.38, υπόσχεται συμβατότητα με το νέο Nabilo Image που δεν έχει κυκλοφορήσει ακόμα.
greg
926
Γλυφαδα
απο nabilosat.info σημερα 15.15
A new updated version of the Pure Flash will be released this afternoon.
Therefore, this current version is no longer available for download, and the 3d is
Stay tuned for the new one.
Με το που το εβαλα το πρωτο στην φλας αρχισε να μου κανει και στο gemini 3.8 το ιδιο προβλημα που ειχα και με το 3.9 με το standby. Δλδ, οταν πατας να παει standby ο δεκτης κρασαρει το Enigma..
greg
926
Γλυφαδα
Φιλε καλυτερα να κανεις ενα registration γιατι απο εκει θα κατεβασεις και το νεο τους ιματζ για το οποιο εχω ποσταρει εδω συν οτι θα παρεις πολλες απαντησεις σε προβληματα / αποριες σου..2 λεπτακια θα κανεις.. -bye-
AlexT_
10,452
Αυτό είναι το προηγούμενο.
Κυκλοφόρησε σήμερα νέο και είναι αυτό που παραπέμπει ο greg παραπάνω.
Σύμφωνα με τους "κατασκευαστές" αυτό πρέπει να εγκατασταθεί για να λειτουργήσει σωστά το black hole.
Voreios
18 January 2007
4,750
Το κατέβασα μόλις απο το Ναμπίλο φορουμ αλλά λεει οτι εχει φρεσκους (σημερινούς) drivers....και δεν δουλεύει σε multiboot με κανένα προηγούμενο (αρα...ακόμη και με το gemini 3.90)
Ποτε θα ξαναδουλέψουν όλα μαζί σωστά;
Εγω πάντως δεν έχω δίλλημα, αν δεν δουλευει gemini δεν βαζω image
Voreios
18 January 2007
4,750
Οχι, δεν εχεις προβλημα, κανει οτι σε πεταει έξω και μετα...κανεις back στον browser και μπαίνεις!
satnick
6 September 2008
2,275
Απάντηση: Re: Nabilo DM800 Pure Flash 10DEC2008 + Barry Allen 4.6.38
ΦΙΛΕ ΚΑΙ ΓΩ ΤΟ ΙΔΙΟ ΠΑΘΕΝΑ!!!!
Και νομιζα οτι εχει τιποτα ο δεκτης!!!!-bye--bye-
satnick
6 September 2008
2,275
ακομα δεν γυνετε registration στο nabilo η εγω εχω το προβλημα ???
thanks
Ακομα 5 φορες προσπαθησα και μετα με αφησε εξω για 15 λεπτα
τωρα που τα bugs θεριζουν μονο απο το επεισημο site!!!!
greg
926
Γλυφαδα
Re: Απάντηση: Re: Nabilo DM800 Pure Flash 10DEC2008 + Barry Allen 4.6.38
Ειναι γνωστο το προβλημα, το εχω ακουσει απο πολλους φιλους..
satheo
25 December 2007
1
registration xwris invite sto nabilo auto thelo na to dw!ektos ean to eleutherwsan teleutaia ewdomada!
Voreios
18 January 2007
4,750
Καλώς ήρθες φιλε satheo (εχουμε μιλήσει και στο τηλέφωνο μία φορά αν θυμάσαι...)
Αυτό που λες δεν το ξερω (αν θελει τωρα invite το φορουμ) αλλά το κάνει και σε μένα που ειμαι γραμμένος απο καιρό, όταν παω να ξαναβαλω τα στοιχεία μου (αρχικά με πεταει έξω και μετα κανοντας πίσω με βάζει) γι αυτό και απάντησα έτσι θεωρώντας ότι ειναι ήδη γραμμένος
