NAD 326 BEE
Status
Not open for further replies.
costis_d
20 November 2009
757
Πειραιάς
img.php
Πωλείται λόγω αναβάθμισης, ο NAD C326 BEE σε μαύρο χρώμα και άριστη κατάσταση (10/10) με το τηλεκοντρόλ του και αναβαθμισμένος με Audioquest PreAmp jumpers μεταξύ προενισχυτικού και τελικού σταδίου (υπάρχουν και τα εργοστασιακά jumpers αν κάποιος τα θέλει). Περισσότερες λεπτομέρειες για το tweak εδώ:
http://thesoundapprentice.blogspot.gr/2013/11/tweak-your-nad-preamp-jumpers-make-good.html
Δεν υπάρχει το κουτί οπότε θα προτιμούσα συναλλαγή εντός Αττικής.
Το μηχάνημα είναι 2x50 Watt αλλά βγάζει πολύ περισσότερη ισχύ.
Review από το "The Absolute Sound":
"It took only a few moments of listening to be reminded that a lot has changed in the past thirty years when it comes to amplification, all of it for the better. Banished is the 3020’s warm, somewhat veiled personality, mandated back then by the limitations of solid-state technology at low price-points, in its place a thoroughly neutral tonal balance, a considerably more transparent window onto the presentation, and far more control and authority.
Richard Goode’s Beethoven sonatas left me in stunned disbelief by how much 50 really intelligently designed watts per channel could bring my low-sensitivity Quad 2805s to life. Goode’s Waldstein, without in any way sacrificing nuance and delicacy, is a powerhouse performance, nowhere more so than in the thundering coda to the last movement, which filled the room to a nearly lifelike level. Extraordinary dynamic range from seemingly limited power has always been a specialty chez NAD, and the C 326BEE Integrated Amplifier continues to uphold a proud tradition.
Link
Έπαιζε χωρίς πρόβλημα με τα Chario Reference Tower 100 (4ωμα) και τώρα με τα ProAc D18.
Specs:
  • 2 x 50W Continuous Power into 4 ohms and 8 ohms
  • 100W, 150W, 200W IHF Dynamic power into 8, 4 and 2 ohms, respectively
  • PowerDriveβ„’ circuit
  • NAD SR 8 Full System Remote control
  • Headphone socket
  • Front panel Media Player (MP) input for attaching portable MP3 Player
  • Relay Input Switching
  • Holmgren Toroidal Power transformer
  • 7 Line inputs, including one tape in/out
  • All discrete circuitry Short signal path from input to output
  • All sockets Gold plated
  • Tone controls defeat switch
  • Main-amp input & pre-amp outputs
  • Subwoofer (mono) Out
  • Soft Clippingβ„’
  • IR Input/Output
  • 12 volt trigger out
  • Detachable IEC Power Cable
  • <1W Standby Power Consumption
  • Free of lead and other environmentally dangerous substance
Τιμή στο skroutz: 456 ευρώ
Τιμή πώλησης: 300 ευρώ
Επικοινωνία με ΠΜ.
indy
21 December 2006
58
ΛΟΥΤΡΑΚΙ
Re: Απάντηση: NAD 326 BEE
μπορω να τον συνδέσω ως τελικό στα pre-outs του πολυκάναλου που έχω ?
costis_d
20 November 2009
757
Πειραιάς
Εδώ γράφει ότι γίνεται.
"Connections and convenience
This amp offers ample flexibility for hooking up your gear. You get seven audio inputs, plus a handy front-panel connection for a portable music player. Separate preamp input/line-level output jacks let you use the C 326BEE as an independent power amplifier or preamp for future system expansion. Two separate line-level outputs let you easily add a powered subwoofer. And the included remote gives you easy control of the amplifier and the other NAD audio components in your system."
Δυστυχώς δεν έχω προσωπική άποψη, τον έχω μόνο για μουσική.
more peers
24 April 2009
20,131
Συγνώμη για την παρέμβαση.
Ο 326 έχει τη δυνατότητα σύνδεσης με pre out πολυκάναλου, παίζοντας σαν τελικός ενισχυτής.
Δεν έχει όμως το κλασικό av passthrough με το πάτημα ενός κουμπιού. Θα πρέπει να βγούν οι πίσω γέφυρες και να συνδεθεί rca ώστε να λειτουργήσει ως av passthrough.
indy
21 December 2006
58
ΛΟΥΤΡΑΚΙ
στην περίπτωση που βγάλω τις πίσω γέφυρες οι άλλες είσοδοι του NAD θα παίζουν ώστε να δίνω και από αλλού σήμα ?
leo1964
12 May 2010
10,381
Νησί των Φαιάκων
όταν βγάλεις τις γέφυρες,θα έχεις 2 ζεύγη rca
το ένα χρησιμοποιείται για σύνδεση με τελικό και το άλλο δέχεται σήμα από προ
Status
