- 29 October 2008
- 8,987
Νέα συσκευή αναπαραγωγής UHD Blu-ray Magnetar υψηλής ποιότητας με HDR10+ και Dolby Vision...https://www.flatpanelshd.com/news.php?subaction=showfull&id=1671001782
Το νέο UDP800 UHD Blu-ray player υπόσχεται ποιότητα εικόνας αναφοράς καθώς και υποστήριξη πολλαπλών μορφών για UHD Blu-ray, Blu-ray, DVD, DVD-Audio, SACD και άλλα.
Τιμή; 1600 ευρώ.
Teardown
BT.2020/BT.709/BT.601 color space support
Disc type
UHD Blu-ray, Blu-ray, Blu-ray 3D, DVD-Video, DVD-Audio, AVCHD-SACD, CD, Kodak Picture CD, CD-R/RW, DVD±R/RW, DVD±R DL, BD-R/RE
Output
Analog audio: stereo
Independent stereo analog audio: XLR balanced output, RCA output
Optical/coaxial audio: up to 2 channels /192kHz PCM, Dolby Digital, DTS
HDMI audio: up to 7.1 channel /192kHz PCM, up to 5.1 channel DSD, Bitstream
HDMI video: UHD/p24 1080/1030p / 1030I / 720p / 576p / 576I / 480p / 480I
Analog audio characteristics
Frequency range: 20HZ-20khz (-3dB ~ +0.05dB)
Signal-to-noise ratio: & GT: 120dBr
Total harmonic distortion + Noise: & LT: 0.00018%
Output level: (RCA) 2. l±0.2Vrms. (XLR) 4.2±0.4Vrms
Dynamic range: AGT: 120dB
Channel separation: & GT: 120dB
General specification
Power supply: AC 100-240V ~, 50/60Hz
Power: 30 W (Standby: 0.5W in energy saving mode)
Size: 430 mm x 300 mm x 90 mm
Weight: 8kg
Working temperature: 41° F – 95° F 5° C – 35° C
Working humidity: 15% – 75%
πηγή : flatpanelshd.com
Τιμή; 1600 ευρώ.
Teardown
Magnetar UDP800 Specs:
Media Tek MT8581 chipsetBT.2020/BT.709/BT.601 color space support
Disc type
Output
Weight: 8kg
