Νέο ΑΚΜ AK4497ΕQ
sokmav
5 February 2012
14,227
Όλα δείχνουν πως μάλλον πρόκειται για την ναυαρχίδα της σειράς με top χαρακτηριστικά και μετρήσεις.
The AK4497 is a new generation premium 32-bit DAC based on AKM’s VELVET SOUND architecture that has been widely adopted by well-established high-end audio companies. High signal to noise performance is achieved by improving VELVET SOUND technology by supporting a larger current drive capability. The performance of an audio DAC using switched capacitor is expanded to the limit with the AK4497. In addition, AKM has developed an original process that has greatly improved low noise performance and electric margin for audio devices, increasing data amount and enhancing original acoustic sound that can be found in the sound strength.
Dynamic Sound Playback with Large Amount of Playback Information: VELVET SOUND architecture is improved
Not only circuit designing but also the LSI manufacturing process was newly developed at AKM exclusively for AKM’s audio devices. The AK4497 is the first device to utilize this process in AKMs foundry. 32-bit processing is integrated for the IRD (Impulse Response Designed) Filter, reproducing a detailed and natural signal wave. A low-dispersion short delay filter was newly added to the other five filters found in our previous generation device. So, six different digital filter types are selectable according to the user audio and system preferences.
— AKM’s Best Performance D/A Converter
Low-distortion technology achieves industry’s best performance of -116dB THD+N DAC with 128dB S/N characteristic. The AK4497 has the best performance among AKM’s D/A converters. In addition, OSRD (Over Sampling Ratio Doubler) technology greatly reduces out of band noise.
Supporting High Resolution Data
The first in the industry, a 22.4MHz DSD input is supported. The digital input supports up to 768 kHz PCM and 22.4 MHz DSD (Direct Stream Digital), recreating high-resolution sound that is as close as possible to the original acoustic source.
Application
High-end Audio, Professional Audio, AV Receivers, CD/SACD Players, Network Audio, USB DAC’s
image.jsp
Απομένει να δούμε αν θα είναι το τελευταίο της σειράς και τις υλοποιήσεις που θα το υιοθετήσουν.
26 June 2006
14,830
Athens
Μόνο η ψηφιακή υπάρχει. Υπάρχει και τίποτα άλλο? :)
Για μένα η "επανάσταση" θα γίνει (και θα ακουστεί από όλους) όταν βελτιωθούν οι ηχογραφήσεις, ΙΜΟ...
Sonus Naturalis
12 July 2009
9,101
Αθήνα, Ηλιούπολη
Μεγάλη κουβέντα Σταύρο! Τεράστιο θέμα με πολλές προεκτάσεις. Μάλλον πρέπει να το συζητήσουμε αυτοτελώς, σε άλλο χωριστό νήμα...
petronik
18,512
Θεσσαλονικη
Απάντηση: Re: Νέο ΑΚΜ AK4497ΕQ
Εγώ δεν ανησυχώ. Έχω σπόνσορα τον Πέτρο με τις φανταστικές ιδέες του :HTEHETH63:
Τι έκανα πάλι ; δηλαδή δεν σου κίνησε το ενδιαφέρον ;
Α ειναι πολύ καλά.
Βέβαια εκεί πανω θα πεσει ΦΠΑ και τελωνείο οποτε θα παει στο χιλιάρικο.
Στα 850-900
Εγώ θα σας έλεγα να μην πέσετε στην παγίδα των φτηνών Κινέζικων πλακετών. Είναι αγνώστου πατρός και πραγματικά αμφίβολων δυνατοτήτων.
Ολοκληρωμένα σαν το 4497 για να παίξουν σύμφωνα με τα specs τους θέλουν κορυφαία τροφοδοσία, αναλογικά στάδια και πολύ προσεκτικό layout.
Οι παραπάνω πλακέτες κατά πάσα πιθανότητα δεν έχουν κανένα από τα τρία.
Το Gustard από την άλλη.. ενδιαφέρον... πολλή τεχνολογία σε πολύ λογική τιμή.
tuxx
3 January 2014
3,319
/dev/null
Επίσης για την ιστορία, απ' ότι κατάλαβα στις τιμές αυτές δεν περιλαμβάνουν USB receiver. Χρειάζονται έξτρα πλακετάκι.
