Νέοι Denon 8k avr 2020
Pleo
14 March 2008
19,992
DTS:X Pro και επανέρχεται το Dolby Center Channel Spread με f/w update στις 11 Νοεμβρίου.
https://www.audioholics.com/editorials/denon-marantz-firmware-update
  • DTS:X Pro for the Denon AVR-X6700H and Marantz SR8015 as well as the AVR-X8500H, AVR-A110 and the Marantz AV8805!
  • Adding back Dolby Center Spread Feature for the 2019 and 2020 AVR lineup.
  • Dolby Surround Front Wide support for AVR-X8500H and AV8805.
  • Dolby Height Virtualization for the AVR-X8500H and the AV8805.
  • Adding back DTS Neural:X capability on Dolby content for 2019 AVR lineup (2020 lineup supports it out of box).
  • 180Hz crossover settings.
  • Change from 70Hz crossover settings for IMAX to 80Hz for the speakers + sub and 120Hz for LFE just like it's done for Dolby Atmos and DTS:X.
  • Screen Saver function for 2020 AVR lineup.
  • Power up volume level default fix. In our review of the Marantz SR8015 we found a bug with respect to power up volume not engaging to its preset level but instead, defaulting to minimum.
Ξέχασα να το σχολιασω πριν.
Σε ποιο σημείο του βίντεο η της περιγραφής αυτού αναφέρεται ότι πρόκειται για προσωρινό workaround μέχρι να βρεθεί η τελική λύση?
Από το 2:57 και πέρα.
Pleo
14 March 2008
19,992
Δοκιμή του AVC-X6700H.
https://audio.com.pl/testy/kino-domowe/wzmacniacze-a-v/3281-denon-avc-x6700h
When driving two we get 2 x 170 W, connecting the next ones is a challenge for a common power supply, but 5 x 110 W is still an excellent result, just like 7 x 90 W, and when all eleven are loaded, we get 11 x 58 W, but then we hear intense work fans, yet the housing gets very hot. In practice, the effect channels sound less intensely than the front ones, so such extreme situations will not occur in normal use.
Και όπως πάντα με τη ρύθμιση στα 4Ω που περιορίζει την ισχύ στο τροφοδοτικό:
Denon configured the system very cautiously, not for the first time. With one channel controlled, the power is only 64 W, but for consolation it does not drop significantly when connecting other channels - in stereo we have 2 x 64 W, and when running the entire arsenal - 11 x 44 W.
Pleo
14 March 2008
19,992
Απ' ό,τι φαίνεται το PS5 δεν έχει θέμα στο 4Κ@120Hz και τους Denon/Marantz.
Είναι μάλλον θέμα handshake μεταξύ των συσκευών. Λύνεται με ένα απλό restart στον ενισχυτή AV, αφού πρώτα τον έχεις θέσει σε 8K Enhanced mode.
Και απ' ό,τι φαίνεται έχει να κάνει όντως με τη διαφορά στο Hardware των τριών και τεσσάρων γραμμών, ακριβώς όπως τα έχουμε αναφέρει και εδώ.
Εάν ισχύουν τα παραπάνω περί handshake, τότε πράγματι με ένα f/w update είναι εύκολο να λυθεί.
Από τον Techno Dad
*CONFIRMED* PlayStation 5 + Denon/Marantz = 4K120 HDR | NO BUGS HERE! 4K120 + HDR PS5 Setup HDMI 2.1
https://www.youtube.com/watch?v=JZB0M5Z_to8
vadergr
17 August 2007
27,569
Μεταμορφωση
Δεν είμαι σίγουρος ότι θα είναι τόσο απλό.
Όταν είχε προκύψει το θέμα αρχικά κάτι είχε αναφερθεί περί τροπου μετάδοσης της εικόνας.
Το PS5 στελνει με διαφορετικό τρόπο την εικονα σε σχέση με τα series x και τις rtx κάρτες.
Το βασικό είναι να βρεθεί γενική λύση για όλα.
Pleo
14 March 2008
19,992
Με το ps5 φαίνεται να λύθηκε το πρόβλημα.
Το μόνο που μένει είναι να δούμε αν το power cycle στον ενισχυτή που τώρα γίνεται για να ξαναεπικοινωνησει με handshake με την πηγή, θα είναι θέμα που λύνεται με update.
Ενδιαφέρον είναι ότι και στην τηλεόραση ήθελε και μια επιπλέον ρύθμιση που απ' ότι φαίνεται δεν είχε γινει όταν προεκυψε το θέμα.
Καλά νέα πάντως που λειτουργεί το 4Κ@120Hz.
spcav
18 August 2006
16,673
Ελπιδοφόρα νέα.
Θέλω να ελπίζω ότι το θέμα του restart θα φτιάξει με FW.
Πρέπει βέβαια να περιμένουμε να δούμε και τι γίνεται με όλες τις πηγές (nvidia και Xbox).
ΥΓ Το Deep Color στην TV είναι step 1 ρύθμιση εδώ και χρόνια (και για το Xbox)
Pleo
14 March 2008
19,992
Είναι και μια ρύθμιση στο PS5 που αναφέρεται στο βίντεο, σχετικά "θαμμένη" μέσα στα μενού που χρειάστηκε να ανοίξει για να λειτουργήσει και να δείξει 4Κ120Α στο input και στο output το μενού.
(Μάθαμε και τι είναι το Α στο 4Κ120Α με τη βοήθεια χτεσινού βίντεο παρουσίασης στο νήμα με τους νέους Yamaha. Α θα πει uncompressed, B θα πει compressed).
pathfinder
28 October 2007
1,510
Πικέρμι
Ειμαι κάτοχος του pioneer VXR-920 με ηχεία KEF C5,C4,C3,C2. Ποιον denon θα ηταν προτιμοτερο να παρω για αλλαγη του υφιστάμενου ενισχυτη με ολα τα HDMI2.1 κλπ ?2700Η ή κατι παραπανω ?
Pleo
14 March 2008
19,992
Προς αντικατάσταση τον 2700, προς αναβάθμιση τον 3700.
Το θέμα είναι ότι η διαφορά τιμής μεταξύ των δύο είναι μεγάλη σήμερα που μιλάμε στις 23 Νοεμβρίου.... ουπς... . :eek:
Pleo
14 March 2008
19,992
Που σημαίνει ότι ούτε φέτος θα έχει μοντέλο της σειράς 3xxxx σε BF. Φυσικά. Οι παραλλαγές 1600 2700 με και χωρίς DAB θα είναι βασικά. Και οι 550ΒΤ και S650H.
Pleo
14 March 2008
19,992
Τελικά ο 2700 φέρει FM?
Ναι. Κανονικά. FM/AM.
Στην πλάτη ο 2700Η έχει την κλασική ομοαξονική είσοδο για την κεραία FM. Στο μοντέλο με το DAB (X2700H DAB) στην ίδια θέση έχει το βιδωτό βύσμα F-connector για να πάρει την κεραία DAB/FM.
Η επιλογή να έχει ο 2700H αναλογικό ραδιοφωνικό δέκτη επίγειας μετάδοσης, έγινε κατόπιν των στοιχείων που έχει η Sound United τα οποία δείχνουν ότι χρήση αναλογικού δέκτη ραδιοφώνου κάνουν περισσότερο οι χρήστες των εισαγωγικών μοντέλων. Κι έτσι τον διατήρησαν για φέτος τουλάχιστον.
billpeppas
23 October 2013
6,871
Athens
Στους 2700h/3700h γινεται τα δυο surround ηχεια σε 5.1 setup να ειναι ασυρματα/heos?
Όχι, αλλά αν πάρεις ενεργά τα πίσω ηχεία μπορείς να τα κάνεις ασύρματα χρησιμοποιώντας το SVS SoundPath Wireless adapter.
Δεν συνιστάται όμως αν δεν έχουν άμεση οπτική επαφή με τους πομπούς τους στον δέκτη, σε σχετικά μικρή απόσταση, όταν μπαίνει άνθρωπος μεταξύ πομπού και δέκτη έχει κενά στο σήμα.
vlad66
29 October 2017
15,279
Αγιοι Αναργυροι
γιατί; τι σε εντυπωσίασε;
ο "θηριώδης" Μ/Σ;; τα "τεράστια" τρανζίστορς; οι "μεγα"ψύκτρες;;
ή οι ατελείωτες καλωδιώσεις;;
και θα ρωτήσω για μια φορά ακόμα.. γιατί δεν γειώνουν τους AV στο δίκτυο;;;;
Reactions: yiorta
