Nova EON TV / EON+
mike75
25 December 2010
98
CBR/ABR/VBR: the 3 encoding modes​
LAME is able to encode your music using one of its 3 encoding modes: constant bitrate (CBR), average bitrate (ABR) and variable bitrate (VBR).
Constant Bitrate (CBR)​
This is the default encoding mode, and also the most basic. In this mode, the bitrate will be the same for the whole file. It means that each part of your mp3 file will be using the same number of bits. The musical passage beeing a difficult one to encode or an easy one, the encoder will use the same bitrate, so the quality of your mp3 is variable. Complex parts will be of a lower quality than the easiest ones. The main advantage is that the final files size won't change and can be accurately predicted.
Average Bitrate (ABR)​
In this mode, you choose a target bitrate and the encoder will try to constantly maintain an average bitrate while using higher bitrates for the parts of your music that need more bits. The result will be of higher quality than CBR encoding while the average file size will remain predictible, so this mode is highly recommended over CBR.
Variable bitrate (VBR)​
In this mode, you choose the desired quality on a scale going from 9 (lowest quality/highest distortion) to 0 (highest quality/lowest distortion). Then encoder tries to maintain the given quality in the whole file by choosing the optimal number of bits to spend for each part of your music. The main advantage is that you are able to specify the quality level that you want to reach, but the inconvenient is that the final file size is totally unpredictible.
kardasios
30 September 2021
154
Θα μπορούσες λίγο πιο απλά ρε φίλε περιληπτικά να απαντήσεις
billpeppas
23 October 2013
6,845
Athens
Το ABR είναι καλυτερο απο το CBR ποιοτικά στο video encoding. Εγω το εχω ABR auto. Οπως ηταν απο την αρχή. Υπαρχει και το VBR που ειναι το καλυτερο αλλα δεν το εχει το box. VBR>ABR>CBR έτσι παει η σειρά. Και γω δεν τα ήξερα ακριβώς αλλα το έψαξα στο internet.
Σε έναν κόσμο όπου όλοι θα είχαμε γραμμές με σταθερό transfer rate 200Mbps π.χ., το CBR θα ήταν το καλύτερο.
Επειδή δεν έχουμε όλοι σφαίρα γραμμές, και μπορεί να υπάρχουν και μεγάλες πτώσεις στην ταχύτητα αν π.χ. έχουμε πολλούς χρήστες στην γραμμή, υπάρχουν τα VBR/ABR και τα "πρωτόκολλα" που κάνουν target bitrate adaptation.
Το VBR/ABR μπορεί να είναι καλύτερο από το CBR αν έχουν υψηλότερο bitrate ενώ ταυτόχρονα το minimum bitrate target τους δεν πέφτει κάτω από το br του CBR.
VBR/ABR έχουν μικρές ως και μη εντοπίσημες διαφορές μεταξύ τους (με κοντινά bitrates προφανώς, όχι με ουσιαστική διαφορά στο file size δηλ.).
kardasios
30 September 2021
154
kardasios
30 September 2021
154
Εγώ που έχω κατοστάρα γραμμή τι με συμφέρει για να έχω την καλύτερη εικόνα από τα δύο profile
billpeppas
23 October 2013
6,845
Athens
Αν κατάλαβα σωστά, κάποιος με αρκετά γρήγορη και σταθερή σύνδεση καλύτερα να προτιμήσει το CBR στα 7 Mbps !
Πρέπει να ξέρεις τι avg, max & min bitrates έχουν καθορισμένα στα ABR/VBR profiles.
Μπορεί το CBR να είναι καρφωμένο στα 7Mbps, αλλά το VBR να έχει target 7Mbps... με maximum τα 12Mbps οπότε σε σκηνές που χρειάζεται παραπάνω bitrate το VBR in this case θα έχει καλύτερη εικόνα από το CBR εκέινη την στιγμή.
ananias47
26 August 2016
4
Γεια σας παιδια ειμαι συνδρομητης 3πλαυ δορυφορικο φουλ πακ 50μβπς και λήγει σε λιγες μερες το συμβολαιο μου .Τωρα πληρωνω 41ε με νοβα γκο εχτρα και απεριοριστα προς κινητα(που δεν με ενδιαφερουν).Σκεφτομαι το εον+ 100μβπς στα 43ε.Το εον+ γκο χωρις την ενεργοποιηση του εχτρα θα μπορω να την βαλω στο μιβοχ και να παιζει παραληλα ή θελει το εχτρα??Τι κοστος εχει το εχτρα τωρα στο καινουργιο εον τβ??Και κατι τελευταιο αν γνωριζεται εμενα η γραμμη ειναι 50mbps χωρις ομως να ειναι βοιπ παρολο που το ρουτερ ειναι βοιπ .Γινεται να μεταβω σε κατοσταρα γραμμη αλλα να μην γινει βοιπ η τηλεφωνια??(γιατι το σπιτι εχει 3 μπριζες τηλεφωνου και σε ολες εχω σταθερα τηλεφωνα ή φαξ)
Ευχαριστω
algedan
9 October 2008
1,598
Αν σε καλύπτει 100αρα, τότε γίνεσαι voip αυτόματα. Αυτό βγαίνει αν υπάρχει διαθεσιμότητα για 100αρα και με ενημέρωσαν από κατάστημα.
Εδώ στην γραμμή μου δεν υπάρχει διαθεσιμότητα 100αρας, έχω όμως ήδη vdsl 50αρα με απεριόριστα κινητά και σταθερά και κανονική τηλεφωνία όπως και εσύ (ΑΚ γαρ!).
Αν καλύπτεσαι εσύ με 100αρα τότε πιθανό είναι να πας σε voip, γιατί μάλλον καλύπτεσαι από καμπίνα.
Αυτά μου τα έλεγαν σε κατάστημα, δεν ξέρω αν φίλος από εδώ έχει 100αρα Νόβα χωρίς voip, ας μας ενημερώσει.
nickefor
21 August 2010
44
ΑΘΗΝΑ
Τα 50€ για την μετατροπη που μου ειπε μαλλον ειναι αυτο που λενε τα παιδια τελος υποβαθμισης
Και σε μένα τα ζήτησαν τα 50 ευρώ μετατροπή, παρότι έχω ανοιχτό συμβόλαιο, γιατί η δέσμευση έχει λήξει από τον Ιούλιο.
Όταν της είπα ότι "Γιατί τότε να μην το κάνω σε άλλο όνομα, κάποιου μέλους της οικογένειας, ώστε να πάρω και τους 3 μήνες δώρο;"
Μου είπε ότι οι τρεις μήνες δεν είναι ακριβώς δώρο, αλλά μια μικρή έκπτωση 5-10 ευρώ το μήνα στο πάγιο.
-- edit --
Και επίσης να μοιραστώ κι εγώ την εμπειρία μου,
Συνδρομητής Full Pack με 50άρα γραμμή και απεριόριστα κινητά, και novagoExtra, έχει λήξει η δέσμευση από το καλοκαίρι.
Τους πηρα τηλ για ανανέωση και μου είπαν θα με καλέσει το τμήμα ανανεώσεων.
Με πήραν μετά από 2-3 μέρες, και μου είπαν ότι με καλούν κατευθείαν από τα κεντρικά της Nova ώστε να μου δώσουν ειδική προσφορά, λόγω των τόσων χρόνων που είμαι συνδρομητής.
Η προσφορά ήταν μετατροπή σε 100αρα και EON+ με απεριόριστα σταθερά και κινητά στα 46 ευρώ. Κόστος μετατροπής 50 ευρώ και χωρίς μήνες δώρο (όπως είπα από πάνω).
Κατιξερω
23 October 2021
17
Στη συγκεκριμένη περίπτωση, abr=adaptive bitrate και cbr=constant bitrate. Στο abr ο player τραβάει το ψηλότερο stream που επιτρέπει η γραμμή σου, με maximum αυτό που έχεις βάλει ως όριο. Αν σεταρεις cbr τότε καρφώνεις μια συγκεκριμένη ανάλυση την οποία αν δεν μπορεί η γραμμή σου να την τραβήξει αρκετά γρήγορα θα σου κάνει διακοπές και buffering.
Looter
20 July 2008
1,625
-- edit --
Πολύ λάθος τακτική να ζητάνε 50αρικα για το ΤΙΠΟΤΑ.
- Να δεχτώ αν έχεις συμβόλαιο που πληρώνεις περισσότερα και ΔΕΝ έχει λήγει να σου βάλουν το 50αρικο μετατροπής αν και πάλι είναι ΑΠΟΓΟΗΤΕΥΤΙΚΟ για τον ήδη πελάτη που στηρίζει την εταιρία.
- Να δεχτώ αν έχει ΛΗΞΕΙ το συμβόλαιο να σου βάλουν το 50αρικό αν σε βάλουν στο promo με τους δωρεάν 3 μήνες για να κάνεις νέα δέσμευση αλλά και αυτό είναι ΑΠΟΓΟΗΤΕΥΤΙΚΟ καθώς τον εξοπλισμό τον έχεις ήδη και box ΔΕ σου δίνουν.
Η μόνη περίπτωση που θα δεχόμουν το 50αρικο είναι για έπαιρνα το box , τίποτα άλλο.
Αλλά και αυτό αν παίξει σωστά η εφαρμογή για τις TV , δεν το χρειάζονται 9 στους 10.
Αν η εικόνα στο cast είναι όπως χθες στα τελευταία 20 λεπτά του ντέρμπι και έπειτα προσωπικά δεν κάνω καμία κίνηση.
leo06
14 October 2007
6,738
Πάτρα
Από ΑΚ δεν δίνουν το box, μόνο δορυφορικό αν και έχω 50αρα ΟΤΕ. Βλέπω netflix 4k αλλά η νόβα με hd δεν το δίνει. Αν πάω μόνο για tv όμως δινουν το box, είναι για γέλια.
stonec
23 September 2008
116
Μου ήρθαν πριν από λίγο οι κωδικοί της υπηρεσίας, χωρίς να μου έχει έρθει ο τεχνικός με το box.
Αν εγκαταστήσω την εφαρμογή στο mi box θα παίξει; Διαβάζω ότι δουλεύει μόνο σε κινητό και tablet, ισχύει;
whiteMan
25 October 2020
458
Εχω ένα δίλημμα.. Μια μέρα πριν λανσάρει η eon συμφώνησα για 24αρι triple play full με 3 μήνες δώρο. Ωστόσο με ενδιαφέρει πολυ να μάθω αν θα πάρω την smart tv θέαση ή όχι. Στο τσατ μου λένε ότι να ναι κάποιοι δεν ξέρουν κάποιοι λένε θα πάρεις όλες τις παλιες παροχες(που σημαίνει όχι smart tv). Το συμβόλαιο αυτή την στιγμή βρίσκεται στο κούριερ και σκέφτομαι να πάω να το υπογράψω ή όχι. Αν ξαναζητησω προσφορα πιστευετε θα μου δώσουν 24αρι triple play δορυφορικό eon? Δεν το νομίζω.. Θα μου πουν εφόσον μπορουμε να σου διαθέσουμε 100αρα να κάνουμε το πακετο eon+ triple play.. Εγώ όμως δεν θέλω 100αρα για πολλους λόγους.. Τι να κάνω λέτε; έχει υπογράψει κανένας κάποιες μέρες πριν το eon να μοτ πει αν πηρε την smart tv θέαση;
angelalex
24 December 2018
1,254
Ναι θα παίξει μόλις τώρα μίλησα με την nova γιατί εμένα είναι να έρθει σήμερα το box και μου είπαν εάν δεν έχει έρθει η υπηρεσία θα ενεργοποιηθεί ούτως ή άλλως σήμερα οπότε θα μπορώ να την χρησιμοποιήσω κανονικά
Reactions: stonec
whiteMan
25 October 2020
458
Αν έχεις υπογράψει συμβόλαιο με το box μπορεί να το χρησιμοποιήσεις ΚΑΙ στο mi box
Reactions: stonec
Domeniko 3
17 October 2021
107
Καλά το nova my account είναι για γέλια.
5 μέρες μετά την έναρξη της υπηρεσίας και στο μενου αναβάθμισης σου αναφέρει τις υπηρεσίες με NOVA εξοχικό ή Nova Multiview η Nova Energy.
Αν πατήσεις στα link να τα επιλέξεις για να βρεις πληροφορίες σε πετάει στο site της nova στην σελίδα με τις προσφορές της EON άρα αυτές οι υπηρεσίες δεν ενεργοποιούνται πλέον από το Nova My Account και αναθεμά κι αν ισχύουν πλέον.
Δηλαδή τόσο δύσκολο είναι να προσέξουν κάτι τέτοιο και να μην δυσκολεύουν τον κόσμο χωρίς λόγο;
seaman13
4 September 2009
549
Κύριοι, full quality μόνο από eon box. Μην συγκρίνετε με cast, browsers κλπ. Αν θέλετε να κάνετε σύγκριση να είναι μήλα με μήλα. Browser με browser,cosmote box με eon box, cast με cast. Το box παίζει το native raster scan της πηγής χωρίς μετατροπές. Σε όλα τα άλλα γίνονται μετατροπές (που ρίχνουν την ποιότητα).
Full quality και σε tv app ας πουμε lg tv?
