Nvidia Shield TV / TV PRO (2019)
ΔΗΜΗΤΡΗΣ.Π
25 October 2006
20,749
ΑΘΗΝΑ
το shield εχει δικια του λειτουργια για τα frames,τη οποια ονομαζει match frame.
δεν γνωριζω εαν το refresh rate που αναφερεις παιζει στο shield και το κατα ποσο δουλευει σωστα.
Reactions: valkal19
nakata
11 June 2007
2,235
var/etc/home
Today we released SHIELD Experience Upgrade v9.1.1 (33.2.0.157) for all SHIELD and SHIELD Pro units. This update is based on SHIELD Experience Upgrade 9.1 and includes the following fixes and enhancements:
Enhancements
Adds power control option to wake SHIELD when TV input changes to SHIELD
Adds developer option to force Dolby Vision Low Latency if available. Enable if Dolby Vision not properly detected on some Philips OLED TVs
Adds developer option to improve HDMI-CEC volume control for AVR/Soundbars (“Clean up preferred playback logical address”)
General cleanup and re-organization of developer options
Bug Fixes
SHIELD TV App
[Android only] Resolves issue where SHIELD TV app would not launch properly on some Samsung Galaxy phones
Video/Display
Fixes bug where protected content would not play if external storage is connected
Fixes color accuracy bug when “Default to Rec .709 for HD videos” developer option is enabled
Fixes issue where Automatic Game Mode would be enabled on NVIDIA Games even when disabled
[SHIELD 2019 models] Resolves video crash issue when seeking in quick succession when Dolby Audio Processing is enabled
Audio
[SHIELD 2019 models] Resolves issue where audio would not be present until reboot when Dolby Audio Processing is enabled
[SHIELD 2019 models] Resolves issue where audio would play at an accelerated rate when Dolby Audio Processing is enabled
Storage
Fixes bug where files were not detected properly on connected removable storage
Fixes bug when mounting NAS using IP addresses for accounts with empty passwords
Resolves large smb file transfer disconnect issues by disabling anonymous access by virus scanners
Accessories
Resolves issue where Simplified wake buttons would not power on IR controlled TV
Resolves issue where SHIELD would be unresponsive to BT devices up to 60 seconds after startup
[2015/2017 SHIELD] Resolves MxMaster 3 BT mouse pairing issue
Resolves issue where TV remote would not control SHIELD 30 seconds after waking SHIELD
Resolves some issues where CEC volume control was not functioning properly on AV receivers or soundbars
Resolves issue where Control4 systems would not wake up SHIELD if systems is turned off while Screensaver is active
Other
Resolves issues where UI would be displayed in low resolution for a split second
Fixes bug where user had to select a home app when setting up SHIELD after factory reset or system upgrades
“Enable Dolby Vision” notification will be suppressed after dismissing
Fixes bug where region specific apps would not be visible after disabling
Fixes bug where microphone notification would be displayed on “Ok Google” hotword activation
Livas
6 September 2010
95
Μόλις το πέρασα το 9.1.1 και έπαθε σοκ κάθε ένα λεπτό μετά την αναβάθμιση έκανε restart ! Και απλά αναμονή να το είχα έκανε restart!
Το πάτησα power off κανονικά και μετά δεν ανταποκρινόταν το remote καθόλου !
Το έβγαλα και το έβαλα από το ρεύμα και φαίνεται τώρα να είναι όλα ενταξει !
Πρώτη φορά με κάνει κάτι τέτοιο !
mikal
18 July 2012
60
Ερώτηση για Dolby Atmos και HDR to SDR tone mapping
Εχω το Shield Pro συνδεδεμένο σε 1080p projector (Epson 5820).
Μεταξύ τους υπάρχει scaler με EDID manager ρυθμισμένο σε 4Κ non-HDR.
Μέχρι σήμερα παίζω Netflix και Disney+ σε HD και έχω το Shield για AI upscaling με πολύ καλό αποτέλεσμα.
Επειδή αγόρασα soundbar που υποστηρίζει Dolby Atmos θέλω να βρω τρόπο να παίζει Netflix και Disney+ σε DA σε περιεχόμενο που υποστηρίζεται.
Εννοείται ότι θα κάνω upgrade σε UHD plan το Netflix (και θα χάσω δυστυχώς το ΑΙ upscaling)
Για το Disney+ θα πρέπει να ρυθμίσω τον EDID σε 4κ hdr για να περάσει το Dolby Atmos.
Αν κόψω το HDR από το Shield θα δουλέψει το Atmos?
Επειδή με ενδιαφέρει και η εικόνα, θα κάνει hdr to sdr tone mapping το Shield με αυτόν τον τρόπο?
Darudakos
2 August 2011
275
Ωχ, αυτό ήρθε πριν καμια βδομάδα σε μένα (είμαι γραμμένος στις beta) και νόμιζα ότι ήταν beta.
Sent from my V2145 using Tapatalk
polakis
19 September 2008
2,791
Ρε παιδια και στο netflix εχω stutter σε LG OLED C1. Τι γινεται; Πως φτιαχνεται; Και στο disney τα ιδια...
theox
11 June 2007
713
Westeros
Πέρα από το πρόβλημα που αναφέρεις το οποίο πρέπει να λυθεί, γιατί δεν χρησιμοποιείς τις εφαρμογές WebOS για τις παραπάνω υπηρεσίες;
Reactions: ΔΗΜΗΤΡΗΣ.Π
polakis
19 September 2008
2,791
Ναι οκ απλα επειδη τις εχω και στο nvidia και το χρησιμοποιω για τα παντα, ελεγα μπας και διορθωνονται τα θεματα.
Darudakos
2 August 2011
275
Σήμερα συνέβη κάτι πολύ περίεργο σε μοντέλο 2017.
Τόσο καιρό δεν μου δουλεύει το CEC σε Yamaha ενισχυτή, πάνε αρκετοί μήνες, είχα γραφτεί σε Beta μήπως και το διορθωναν, καμιά βελτίωση μετά απο 4-5 beta αναβαθμίσεις.
Σήμερα στα καλά καθούμενα δουλεύει :)
Η τελευταία αναβάθμιση η σταθερή ήρθε σε μένα πριν 15 μέρες περίπου.
Δεν μπορώ να καταλάβω τι έγινε.
Darudakos
2 August 2011
275
Και σήμερα πάλι τα ίδια. Δεν δουλεύει. Δοκίμασα reboot και μερικές ρυθμίσεις στις επιλογές προγραμματιστή.
Ίσως δοκιμάσω και επαναφορά εργοστασιακών αύριο.
Haris1977
9 May 2011
900
Μάλλον το τελευταίο update (public) επηρέασε το Cosmote tv app. Kαι εξηγούμαι:
Όταν είμαι στο app και βλέπω πχ replay tv / live streaming, όταν αλλάξω hdmi source και επανέλθω στην cosmote, βγάζει error
"Δημιουργήθηκε πρόβλημα, δοκίμασε ξανά "ERROR_CODE_DRM_DISALLOWED_OPERATION"
Tο χει κάνει και σε σας? Αν κάποιος έχει cosmote tv μπορεί να το κοιτάξει και να μας πει?
(δεν το κάνει σε άλλο app και δεν το κάνει όταν αντί για hdmi source πας στην tv)
ΔΗΜΗΤΡΗΣ.Π
25 October 2006
20,749
ΑΘΗΝΑ
εμενα αυτο το κανει απο την προηγουμενη εκδοση και το εχω αναφερει λιγες σελιδες πισω.
οποτε μαλλον ειναι καποιο bug της εφαρμογης και οχι του shield.
