Panasonic GH5 mkΙ/mkΙΙ φωτογραφία
kbouk
8 January 2010
22,554
ΠΕΙΡΑΙΑΣ
Απάντηση: Re: Panasonic GH5
Νέο firmware με βελτιώσεις στο AF : http://av.jpn.support.panasonic.com/support/global/cs/dsc/download/
Improvement of tracking performance and minimizing of backfocusing in continuous AF mode with 225 AF points
Fix of a One-Push-AE bug in Creative M mode, when SS/Gain-Operation is set to Angle/ISO
Fix of bug that sometimes caused timecode to be reset upon battery change
Fix of a bug that caused showing all footage, instead of just the intended frame in 6k/4k Photo mode
Μεγάλη η βελτίωση σύμφωνα με το https://www.cinema5d.com/massively-...rmance-for-gh5s-gh5-and-g9-with-new-firmware/
kbouk
8 January 2010
22,554
ΠΕΙΡΑΙΑΣ
Από σήμερα είναι διαθέσιμες οι παρακάτω βελτιωσεις: https://av.jpn.support.panasonic.com/support/global/cs/dsc/download/fts/dl/gh5.html
Expanded compatibility with Profoto wireless transmitters
- Profoto wireless transmitters "Air Remote TTL-O/P" and "Profoto Connect-O/P" can be used.
* All functions may not be available depending on the situation.
Improved AF performance
- [AF-ON: Near Shift] and [AF-ON: Far Shift] functions have been added. [AF-ON: Near Shift] preferably focuses on a subject nearby while [AF-ON: Far Shift] preferably focuses on a subject far away.
- Focus Peaking function is available in any AF mode.
- It is possible to set continuous AF on the live view screen in Creative Video mode or in other video recording mode when the video recording area is displayed.
Other added functions
- [AWBw] has been added to WB mode.
- [Highlight Weighted] has been added to metering mode.
- [Exposure Offset Adjust.] has been added to Custom menu, which enables adjustment of the standard exposure value for all metering modes.
- [0.5SEC] has been added for an option of [Duration Time (photo)] in [Auto Review].
Other improvements
- AE can be locked with the [AF/AE LOCK] button when ISO Auto is set in M mode.
- [MODE1] has been added to the Live View Boost function, which increases the frame rate for smooth image display to enable easier manual focusing.
Improved operational stability
- There were cases where Backup Recording using the Double Card Slot Function stopped during writing. This bug has been fixed.
- There were cases where the images shot vertically did not rotate on playback. This bug has been fixed.
- Operational stability of image stabilizer has been improved. (When [Image Stabilizer] > [E-Stabilization(Video)] and [Boost I.S.(Video)] is ON. ).
cacau
7 June 2008
20,413
Η ολοκληρωμένη δοκιμή της mk II από το dpreview, 85% με ασημένιο μετάλλιο. Εκτός από το DFD που εξακολουθεί να υπολείπεται στα κινούμενα θέματα, τους άρεσε πολύ - ειδικά η τιμή λανσαρίσματος (εκεί) που βγήκε ίδια με το street price του προηγούμενου μοντέλου...
