New generation 24.33 Mpix APS-C CMOS sensor
‛PRIME IV’ image processing engine with image accelerator unit
5-axis ‛SR II’ in-body image stabilization (5-stop correction)
27-point ‛SAFOX 11’ autofocus system (25 cross-type)
Sensitivity: ISO 100-819,200
Continuous drive: 7 fps
Maximum shutter speed 1/24,000 s (electronic shutter)
Dust-proof and drip-proof casing with 67 seals; cold resistance up to minus 10℃
Pixel Shift
Low-pass-filter-free sensor
Low-pass selectorigh resolution RGB sensor of about 86,000 pixels
Continuous drive: 7 fps (JPEG: up to 8 frames; RAW: up to 8 frames; RAW +: up to 7 frames)
Maximum shutter speed: 1/6,000s (mechanical shutter), 1/24,000s (electronic shutter)
Optical viewfinder with approx. 100% coverage and approx. 0,95x magnification
3-inch 921,000 dots vertical tilting LCD screen
Full HD video, 4K interval video
Motion bracket, depth-of-field bracketing function
Built-in Wi-Fi (IEEE 802.11b/g/n)
Compatible with ‛O-GPS-1’ GPS unit (sold separately)
Storage media: SD / SDHC / SDXC cards (compatible with UHS-I standard)
Battery: D-LI109
D-LI109 and D-LI90P available for battery grip D-BG7
Weight: 643g (body only), 703g (including battery and memory card)
Expected release date: February 23rd, 2017
Color: Black / Silver
No lens kits will be available
Optical viewfinder with 100% coverage
3-inch tilting LCD screen
Video: Full HD
DR II
Dimensions: 131.5 x 101 x 76mm
Weight: 643g
Price: ¥137,700 (8% VAT included), European RRP: 1,299 (20% VAT included) or aprox. $1,150
