Pioneer DV-696AV Hakan V6.0 Firmware
Για όποιους δεν το είδαν ακόμα:
Hakan V6.0 firmware βασισμένο στο πιο πρόσφατο firmware που έβγαλε η Pioneer (YDC7410A)
Download στο γνωστό μέρος:
http://www.pioneerfaq.info/english/dv696.php?player=DV-696AV&question=Firmwares
και εναλλακτικά:
http://rapidshare.com/files/43706727/YDC7410A_V6_ENG.zip
Για όλες τις κωδικοσελίδες. Υποστηρίζει Ελληνικούς χαρακτήρες μόνο στους υπότιτλους.
http://rapidshare.com/files/43705707/YDC7410A_V6_CP1253.zip
Αποκλειστικά για την Ελληνική κωδικοσελίδα που εκτός από τους υπότιτλους, υποστηρίζει Ελληνικούς χαρακτήρες και στα filenames του browser. (Έτσι ισχυρίζονται, δεν το έχω δοκιμάσει προσωπικά ακόμα)
Hakan V6.0
07-07-2007
- Long filenames
- white subtitles outlined with gray
- Turned off preview of images/video in filebrowser
- Replaced background images. You can now see what TV-system the dvd player is set to.
- Replaced screensaver.
- The pointer stays as it was in File browser and is not reseted any more
- Shuffle with MP3 on surround button, hold longer to have V.Surround
- Playe Mode with MP3 activated!
- Multiregional when Enter is pushed until the player turns off.
- Original region setting restorde when Clear is pushed until player turns off.
- Show all caracters in filename, foldername and when Display button is pushed instead of "_".
- Dont play new file on FF or FR, its hard to explain, just play some file, press FF key move selection bar to other file, press "play" or "enter" and check results
- Filbrowser names centerd
- A new font for file browser
- Changed subtitle window.
- Fixed bug with .SRT and .IDX/SUB Subtitles timing.
- Dimmer function under 0 key. Hold longer to obtain: On, ½-light and Off.
- White subtitles with black outline and transparent background
- Only one size avalible for DivX subtitles, but it's bigger then the original one. So CP1252 workes for everyone, just wont disply your languages charaters in file browser
- Supports now bigger DivX/Xvid subtitles for CP1250, CP1251, CP1252, CP1254 and CP1255
- Default font changed thanx to Robert7
- Support for Greek (CP1253) in firmware now.
- New icons made by Dinderi.
- Based on new original firmware, YDC7410A.
- Pan&Scan.
- UOP Messages disable, (User Operations Prohibitet), but only partially
- .SRT timing bug.
- Show specific extension in filebrowser.
- Now shows all chars avalible.
- New bigger subttile font. Even bigger for Hebrew
Με κόκκινο χρώμα είναι οι αλλαγές - προσθήκες από το προηγούμενο firmware.
