pioneer king blu
argi
Banned
17 July 2006
7,032
salmonela
Large | Download
OverviewFeaturesRelatedSupport & MediaWhere to buy
Main Features
Plays • Blu-ray disc (BD-ROM, BD-R/RE)
• DVD-Video (DVD-R, DVD-R DL, DVD-RW)
• AVCHD (DVD-R, DVD-R DL, DVD-RW)
• CD (CD-DA, DTS-CD, PC-Files [ISO 9660 file system only])
• DivX, MP3, WMA, JPEG
HD Audio Dolby TrueHD, DTS-Master Audio HD
Terminals 2 x HDMI out*, 1 x Component Video out*, 1 x S-Video out*, 1 x Video out*, 1x Coaxial Digital Audio out*, 1 x Optical Digital Audio out*, 1 x 7.1ch Analogue Audio out*, 1 x Ethernet, 1 x RS-232C (* are gold-plated terminals)
Blu-ray Profile (+) BD-Live Ready
BonusView
BonusView (also known as BD Profile 1.1 or Final Standard Profile) players include a minimum of 256 MB local memory and the ability to play Picture-in-Picture. This feature displays a second image in a sub window for in-movie experiences such as active audio and video commentary.
Audio mixing lets you switch the sound between the main and sub windows.
BD-Live
BD-Live (also called BD Profile 2.0) players include a minimum of 1GB local memory and bring picture-in-picture and online functionality via the player’s internet connection.
The profile allows you to download up-to-date content to add to the movie, from refreshed trailers to exclusive special features.
KURO LINK Yes
HD Digital Film Direct 24 (+) Yes
Put simply, HD Digital Film Direct means “Master Quality”: what you see and hear on your flat-screen is exactly as the film-makers intended. Absolutely true to the original.
We’ve applied this standard as a label (see the logo on the right) to those of our products that accurately handle 24fps (frames per second) movie content; this will help you make the right product choice for the true HD movie experience.
Films are typically shot, developed and encoded for cinema reproduction at 24fps.
Regular PAL broadcasting and DVD have always played these images back at 25 fps (50Hz).
This has the effect of speeding up images and raising the pitch of sounds and voices.
But, the new high definition discs, like Blu-ray Disc, offer you access to a digitised ”true to the original” copy of the theatrical movie content.
We offer a product range that is perfectly matched for bringing the real cinema experience into your home: amplifiers, Blu-ray Disc players, home cinema systems and flat-screen TVs with our trademark screening of 24fps source input at 72Hz (3 images displayed per original frame).
High Definition JPEG Playback (+) Yes
Traditionally, your digital photo (or JPEG) files could only be displayed at the standard DVD resolution when you played them on your DVD player.
However, the scaling abilities of our new players ensure that your photo's can now be shown in outstanding high definition detail.
Video Signal D/A Converter (+) 297MHz / 12-bit (High Definition)
216MHz / 12-bit (Standard Definition)
Conversion of digital 8-bit DVD-Video data to analogue data can degrade Y (luminance) and C (chrominance) colour signals, distorting picture colour on playback. How do Pioneer DVD players overcome this problem to unleash more magnificent brilliance, depth, and detail in every colour?
Pioneer D/A conversion upgrades 8-bit Y/C signal data to 12-bit or 10-bit data to maintain data integrity and reproduce images that are truer to the DVD source.
Dimensions (W x H x D) 420 x 143 x 365 mm
Weight 13,8 kg
Power Consumption (in use/standby) (+) 59W / 0,3 W
Caring for the environment is important. It's why we are a Sustainable Energy Partner of the European Commission.
What this means is that we've committed to reduce power consumption in standby modes. The less energy we consume, the better for the environment.
For more information, visit our Sustainable Energy information page.
Playback
Playback Discs • Blu-ray disc (BD-ROM, BD-R/RE)
Home Media Gallery (+) Yes
When you insert a DVD, CD or Blu-ray Disc, the Home Media Gallery allows you to display a list of the titles, tracks or files recorded on that disc.
For DLNA Certified players, the Home Media Gallery allows you to browse and play movies, music and photos stored on your home PC or media server, connected on an identical Local Area Network (LAN). It even lets you play back HD video content
from your PC (or server) with up to 1920 x 1080p resolution.
When you connect the player to your home network, it will automatically detect, for example, WMV, MPEG-2 videos, JPEG photos or MP3 or WMA music files.
MP3 (+) Yes
All Pioneer players and DVD recorders are capable of reading MP3 files recorded onto CD-R/RW and CD-ROM discs.
WMA (+) Yes
This product can play back WMA files recorded on CD-R/RW discs. WMA is a music compression format developed by the Microsoft Corporation. It uses the latest encoding technologies to compress an original audio track, minimising file sizes while maintaining good audio quality.
AVCHD Discs Yes
JPEG Photoviewer allows you to display your digital photographs on-screen. Simply load your CD, CD-R or CD-RW disc containing the JPEG photographs into your product to start the slide show.
With our new models, you can rotate or zoom images, as well as create your own JPEG slideshow with music.
DivX Profile Type Home Theater
10-Key Direct Search & Play (+) Yes
This feature allows you to easily access each track, title or chapter at the touch of a button, using the numeric keys of the remote control.
Audio Features
192 kHz/24-bit D/A Converter Yes (Wolfson WM8740 x 8)
Torodial Power Transformer for Audio (+) Yes
Torodial Power Transformers yield practically no leakage, allowing for powerful audio and increased Signal-to-Noise ratio, with low vibration and little energy loss. The result is a faster response time and ‘cleaner’ signals.
Dolby Digital Decoder Yes
Dolby Digital Plus Yes
Dolby TrueHD Yes
Built-in DTS Decoder Yes
DTS CD Capability Yes
DTS Digital Surround (+) Yes
DTS Digital Surround is the high-quality surround sound format for providing 5.1 channels of discrete digital audio.
DTS-HD Master Audio Yes
MPEG-2 AAC (+) Yes
MPEG (Moving Picture Experts Group) is the name of a family of standards used to encode video and audio signals in a digital compressed format.
MPEG-2 AAC (Advanced Audio Coding) is able to handle more channels than MP2 or MP3 (48 full audio channels and 16 low frequency enhancements compared to 5 full audio channels and 1 low frequency enhancements for MP2 or MP3).
Digital Audio Output Dolby Digital, DTS, Linear PCM, MPEG-2 AAC
PQLS with HDMI (+) Yes
The PQLS (Precision Quartz Lock System) is a transfer control technology using the KURO LINK function.
The player’s output signals are controlled by the AV receiver to achieve high quality sound playback from a CD using the quartz oscillator of the AV receiver. This eliminates the influence of the jitter generated upon transfer which can adversely affect the sound quality.
Dynamic Range Control Yes
Pure Audio Yes
Auto Lip Synchronous Function (+) Yes
This function ensures an automatic and accurate synchronisation of audio and video.
Video Features
PAL/NTSC Dual System Yes
PureCinema Progressive Scan Yes
Video Adjust (+) Yes
From the Video Adjust screen you can choose various settings that affect how the picture is presented.
You can adjust the following picture quality settings:
• Sharpness: Adjusts the sharpness of edges in the picture (Fine, Standard, Soft)
• Brightness: Adjusts the overall brightness (-20 to +20)
• Contrast: Adjusts the contrast between light and dark (-16 to +16)
• Gamma: Adjusts the 'warmth' of the picture (High, Medium, Low, Off)
• Hue: Adjusts the red/green balance (Green 9 to Red 9)
• Chroma Level: Adjusts how saturated colors appear (-9 to +9)
Super Fine Focus Digital Filter Yes
Noise Reduction (+) Component Frame Digital Noise
Mosquito and Block Noise
Component Frame Digital Noise effectively removes ‘White Gaussian Noise’ by comparing film frames, distinguishing differences and removing the noise.
Gaussian Noise is white noise with a constant spectral (or ghostly appearance).
Block Noise
This feature reduces the block noise. Block Noise is a block-shaped distortion generated upon MPEG compression.
Pixel Scaler Yes
Deep Colour 48-Bit (except 1080p/50 and 1080p/60 output)
x.v. Colour (+) Yes
x.v.Colour (also known as xvYCC or Extended-gamut YCC) is a colour space that supports 1,8 times as many colours as the RGB colour space.
The result is that you see greens, reds and blues far deeper than previously possible.
Anamorphic Zoom (+) Yes
Ideally used when viewing 2.35:1 aspect ratio movies from a front projector with an anamorphic lens. The Anamorphic Zoom removes the black bars at the top and bottom of the screen.
Miscellaneous
Auto Power-Off Yes
Power Requirements AC 220 - 240V, 50/60 Hz
jim evo ix
9 November 2008
34
και επισεις αν γνωριζετε αν παιζει η και πως παιζει REGION A....
πολλα ζηταω ε? χαχα
blind guardian
6 November 2007
1,050
ΠΕΙΡΑΙΑΣ
To ''πιο μικρο'' της οικογενειας των Pioneer Blue Ray Players ξερετε ποτε ερχεται?
Εννοω το BDP-51FD
Ειναι αυτο:
http://www.pioneer.eu/eur/products/42/84/222/BDP-51FD/index.html
Ερχονται γιορτες και πρεπει να κανω ενα δωρο στον εαυτο μου και εγω!
Τι τιμες να παιζει αραγε?
Θα πηγαινα στο αδερφακι του το 71 αλλα ειναι ακριβο για μενα!
Θα μου πειτε δεν υπαρχουν αλλα εξαιρετικα Bd Players π.χ Panasonic τα 35 & 55?
Υπαρχουν και εχουν καλες τιμες!
Σκοπος για Pioneer ειναι να απαλλαγω απο τα πολλα τηλεκοντρολ και να εχω πληρη συμβατοτητα Π.Χ: H KURO LINK Eνωση που του επιτρεπει να εχει καλη επικοινωνια με την Kuro μου!
Εκτος αυτου μου αρεσει σαν εταιρεια η Pioneer! Σχεδιαστικα αλλα πανω απ'ολα και σε ποιοτητα!
Οτι ξερετε μου λετε!
Christmas is only 25 days from now!!!
blind guardian
6 November 2007
1,050
ΠΕΙΡΑΙΑΣ
Επισης ξεχασα να αναφερω πως ο λογος που δεν παιρνω PS3 ενω εχω φτασει πολλες φορες σε σημειο να το παρω ειναι πως δεν παιζει αντιγραφα Blue Ray!
Δηλαδη οταν με το καλο μπει στην ζωη μας το Blue Ray και θα θελουμε να εχουμε αντιγραφα ασφαλειας για τα BD-ROM δισκακια μας (τα οποια προς το παρον κοστιζουν αρκετα χρημματα)δεν θα τα υποστηριζει!
Αυτο ειναι κατι που το θελω!
Επισης ενας ακομη λογος που δεν παιρνω το PS3 ενω εχω διαβασει,δει και ακουσει τα καλυτερα ειναι πως δεν εχει πολυκαναλη αναλογικη εξοδο 5,1 η' 7,1!
Εγω που εχω ενισχυτη παλαιοτερης γενιας και εννοω αυτον:
http://www.amazon.co.uk/gp/product/...693062-4453505?ie=UTF8&n=560798&s=electronics
και δεν θα τον αλλαξω (για την ωρα τουλαχιστον) με ενδιαφερει αυτη η συνδεσιμοτητα!
Αρα παω ολοταχως για το παραπανω Pioneer Blue Ray Player!
Περιμενω τις γνωσεις και τις γνωμες σας!
monsoon
30 July 2006
264
Re: Απάντηση: pioneer king blu
Αν εννοείς backup ταινιών bluray, παίζει κανονικότατα..
Backup παιχνιδιών δεν παίζει (ακόμα..)
Τα δισκάκια bluray έχουν πέσει στα 4,6-6,9 ευρώ τα 25 GB και στα 10 ευρώ τα 50 GB.
blind guardian
6 November 2007
1,050
ΠΕΙΡΑΙΑΣ
Σχετικα με το εισαγωγικο παντως μηχανημα της Pioneer το BD - 51FD για το οποιο και σας ρωταγα πληροφοριες,το εψαξα σημερα και μου ειπαν σημερα απο Pioneer Center (Καλογεροπουλος) οτι θα ερθει μεσα στις γιορτες με τιμη γυρω στα 500 Euro!
Αντε με το καλο....να το παρουμε!
ZEANPAPAS
29 December 2008
278
ΠΑΙΔΙΑ ΚΑΝΑ ΝΕΟ ΜΕ ΤΟ PIONEER BDP LX 91?
ΞΕΡΕΙ ΚΑΝΕΙΣ ΠΟΤΕ ΘΑ ΑΡΧΙΣΕΙ ΝΑ ΔΙΑΤΙΘΕΤΑΙ?
ΕΠΙΣΗΣ ΜΙΑ ΑΠΟΡΙΑ ΓΙΑ ΤΟΥΣ ΓΝΩΡΙΖΟΝΤΕΣ,ΔΙΑΒΑΖΩ ΕΔΩ ΚΑΙ ΚΑΙΡΟ ΣΕ ΔΙΑΦΟΡΑ SITE ΟΤΙ ΘΑ ΚΥΚΛΟΦΟΡΗΣΕΙ ΜΕ 16 ΒΙΤ ΕΠΕΞΕΡΓΑΣΤΗ ΕΙΚΟΝΑΣ,
ΤΙΣ ΤΕΛΕΥΤΑΙΕΣ ΗΜΕΡΕΣ ΣΤΟ ΕΠΙΣΗΜΟ SITE ΤΗΣ PIONEER ΦΕΡΕΤΕ ΝΑ ΕΧΕΙ 12 ΒΙΤ ΕΠΕΞΕΡΓΑΣΤΗ.ΠΟΙΑ ΤΕΛΙΚΑ ΕΙΝΑΙ ΤΑ ΑΚΡΙΒΗ ΧΑΡΑΚΤΗΡΙΣΙΚΑ ΤΟΥ?
argi
Banned
17 July 2006
7,032
salmonela
και σε σχεση με το νεο οppo bluray τι πιστευεται οτι ειναι καλυτερο το pioneer?
το μονο κοινο ειναι οτι και τα 2 ειναι μπλε και εχουν ιδιες εισοδους
κατα τα αλλα αστο
ZEANPAPAS
29 December 2008
278
ΔΗΛΑΔΗ ΙΣΧΥΕΙ ΟΤΙ ΛΕΕΙ ΣΤΟ ΕΠΙΣΗΜΟ SITE?
ΣΤΗΝ ΕΛΛΑΔΑ ΠΧ. ΘΑ ΚΥΚΛΟΦΟΡΕΙ ΜΕ ΑΛΛΑ ΧΑΡΑΚΤΗΡΙΣΤΙΚΑ?
