Ίσως κάποιος να μας πει/καθοδηγήσει πως μπορούμε να διορθώσουμε την συμβατότητα με την neotion FTA mpeg4 to mpeg2 convertor Common interface μπαίνοντας στο service mode της Kuro KRL-32/37/46V. Ευχαριστώ
Activating public mode
• Make sure the TV is switched off (not in standby)
• While keeping the 'VOL+' and 'INPUT' buttons on top of the TV pressed, switch on the power, until 'Public Mode' and '---' appears.
• Enter the 3-digit entry code: 027
• OK you need to follow that procedure again by holding down VOL MINUS and INPUT and then when you have got this far you will see a K on the screen, you then quite quickly need to press VOL MINUS and CHANNEL MINUS (all this is done at the set) this will take you into the service menu multiple lines of characters, you then need to toggle through the menus using the channel button until you see Factory Initialise, enter this I think with the volume button then press ok, wait 30 seconds then turn the set off, wait 30 seconds again then turn set on, everything then will be defaulted as though you just took set out of the box
Activating service mode
• While keeping the 'INPUT' and 'MENU' buttons on top of the TV pressed, switch on the power, until 'Service Mode' and '---' appears.
• Enter the 3-digit entry code: 810
Note: According to the service manual to enter adjustment mode the following procedure should be followed (it did not work for me, though):
• While keeping the 'VOL-' and 'INPUT' buttons on top of the TV pressed, switch on the power, until the letter 'K' appears.
• Then hold the 'VOL-' and 'P-' buttons on top of the TV pressed, until multiple lines of blue characters appear.
When in service mode:
• Use Program up/down to go to the next line
• Use Cursor up/down to get to the next page
• Use Cursor Left/Right to change an item (+10/-10)
• Use Volume Up/Down to change an item (+1/-1)
• Use INPUT to select a different input
• Use RETURN to return to a present page
• Use Enter for executing a function
Deactivating service mode
Switch off the TV.
UPGRADING
1. Turn off the AC power (Unplug the AC power cord).
2. Insert the upgrading USB flash memory for upgrade into the service slot.
3. While holding down the power button, plug in the AC power cord of the main unit to turn on the power.
4. Upgrade begins automatically.
Power on the device automatically starts to flash. The blue LED Ignition will begin to blink and after 5 seconds, the power button can be released. During this process (about 2 minutes) the screen remains dark. Then after the set starts, the upgrade screen like the figure below is displayed.
5. If any of the procedures fails, the following upgrade failure screen shows up. For the failing procedure, the “NG” marking turns red. NOTE: In such case, try to upgrade the software again. If it still fails, the hardware may be in trouble
7. Turn off the AC power (Unplug the AC power cord). Take out the upgrading USB flash memory.
8. Now the software has been upgraded.
NOTE: Then get the set started and call the process adjustment screen 1/16 to check the main software version.
Do a reset.
HOME MENU" > "SETUP" > "RESET
