Re: Popcorn hour c-200(Το νέο προϊόν)
ΕΠΙΤΕΛΟΥΣ
RELEASENOTES FIRMWARE
Release date : 1 June 2010
Firmware 02-03-100531-21-POP-408 Beta 1
1. New NMT apps 02-03-100427-21-POP-408
2. BD/AVCHD/DVD/CDDA
- Fixed playback of BD-J disc in SD TV mode
- Fixed BD ISO playback cannot display external subtitles (Mantis #5000593)
- Fixed BD playback with external freeze at end of movie (Mantis #5000596)
- now able to playback some BD titles e.g. Pirate of Carribean, Avatar
- BD playback - Load subtitle index.srt (case sensitive) in BDMV folder by default
3. Video Photo and Audio playback
- HD aduio passthru support for file playback (SimpleBD, m2ts, ts and mkv)
- Fixed certain Arabic subtitle failed to display
- Fixed failure to playback some AVI which contain ID3 (aoe-cop.avi)
- Fixed frequent press of Enter key at start of audio file playback occasional cause system failure
- Fixed slideshow failed via Picasa if the album has more than 700 photos (Mantis #5000535)
- Fixed incorrect photo played randomly when play a single photo (pressing Enter) via myiHome (Mantis #5000535)
- Fixed MKV issues related to makemkv
4. UPNP-AV
- Fixed remote renderer (EyeCon etc) cannot set pause, mute, volume up/down
- Fixed discovered devices disappear when certain UPnP device is attached to network
- Swisscenter Simple Media Server (SIME); reduce waiting time of change track.
- PlayOn UPnP server; fix streaming issue.
5. PHF
- Fixed old shoutcast menu could not pop up
- "Standby" by pressing Power key
- Fixed Return key not working
6. System
- Fixed "purple splash" during system bootup
- Fixed failure to go to enter Media Source screen after setting TCP Receive Window to "auto"
- Wifi card driver Update
7. NMT Apps
- Fixed NMT Setup unable to perform fresh setup on new harddisk with no partition
RELEASENOTES NMT Apps
Version: 02-02-100318-19-POP-408
1. Minimum firmware version to use this NMT App is 02-03-100531-21-POP-408-999
2. compatible now with new SDK Firmware 02-03-100531-21-POP-408-999
ΕΠΙΤΕΛΟΥΣ
4. UPNP-AV
5. PHF
6. System
7. NMT Apps
