Plasma Screen Burn Prevention
To be honest, screen burn on plasma TV is becoming less and less of an issue today, as plasma manufacturers have developed new technologies to tackle the problem. Some pre-burn their plasma panels evenly in the factory before shipping them out to consumers. Some employ motion-adaptive technology to shift the pixels very subtly to the extent that we cannot detect any movement, yet it’s enough to prevent screen burn on plasma TVs. Most newer plasma TVs – certainly both the Panasonic TH42PX70 and Pioneer PDP4270XD – offer grey masking for 4:3 programmes… on the notion that any phosphor excitation in accordance to the moving image in the centre is better than no excitation at all.
That said, it’s better to take precautionary steps during the first 200 hours of a plasma TV’s lifespan when the phosphors are still unstable and burn more intensely, making plasma screen burn a real risk. The most common (and correct) advice is to switch to Cinema mode, lower the brightness and contrast and use the plasma TV normally, taking care not to display static pictures or logos for more than 30 minutes. Also, try to use zoom modes to fill up the 16:9 plasma screen when watching 4:3 programmes or 2.85:1 DVDs… for the first 100 to 200 hours.
However, if you wish to speed up the process, here’s a hardcore method (not for the faint-hearted, but particularly useful when the editorial deadline’s looming around the corner) step-by-step:
1. Adjust the brightness and contrast correctly on your plasma TV. If you don’t have calibration material just set them to slightly below half of the maximum possible.
2. Display a pure white image covering the whole of the plasma screen. Reference Materials, Title 14 (System Evaluation), Chapter 6 (100% Flat Field) in Digital Video Essentials works well, just make sure you don’t display the pause button too.
3. Gradually increase the hours during the power-on/ power-off cycles (i.e. do this for 2 hours then switch the TV off for one hour; then 4 hours on, 2 hours off; then 5 hours on, 2 hours off; and so on and so forth). This way the phosphors can stabilise properly, and you can catch any potential problem before it becomes worse.
4. 50 to 100 hours of power-on running-in will age the phosphors sufficiently to minimise the risk of plasma screen burn.
Περισσοτερα εδω: http://www.hdtvtest.co.uk/news/2007/03/27/plasma-screen-burn/
