μήπως μπορεί κάποιος να μου πει γιατί δεν μου παίζει τα 2 παρακάτω βίντεο:
Code:
Video: MPEG4 Video (H264) 640x480 29.97fps [Stream 00]
Audio: MPEG Audio Layer 3 32000Hz mono 48kbps [Stream 01]
General
Complete name :
Format : AVI
Format/Info : Audio Video Interleave
File size : 460 MiB
Duration : 55mn 52s
Overall bit rate : 1 152 Kbps
Writing library : VirtualDub build 100/release
lmdo : hlmdψ
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : [email protected]
Format settings, CABAC : Yes
Format settings, ReFrames : 1 frame
Codec ID : H264
Duration : 55mn 52s
Bit rate : 1 095 Kbps
Width : 640 pixels
Height : 480 pixels
Display aspect ratio : 4:3
Frame rate : 29.970 fps
Resolution : 24 bits
Colorimetry : 4:2:0
Scan type : Progressive
Bits/(Pixel*Frame) : 0.119
Stream size : 438 MiB (95%)
Writing library : x264 core 60 r913bm 64848ff
Encoding settings : cabac=1 / ref=1 / deblock=1:0:0 / analyse=0x3:0x13 / me=umh / subme=1 / brdo=0 / mixed_ref=0 / me_range=16 / chroma_me=0 / trellis=0 / 8x8dct=1 / cqm=0 / deadzone=21,11 / chroma_qp_offset=0 / threads=1 / nr=0 / decimate=1 / mbaff=0 / bframes=0 / keyint=250 / keyint_min=25 / scenecut=40 / rc=crf / crf=27.0 / rceq='blurCplx^(1-qComp)' / qcomp=1.00 / qpmin=10 / qpmax=51 / qpstep=4 / ip_ratio=1.40 / aq=2:1.00
Audio
Format : MPEG Audio
Format version : Version 1
Format profile : Layer 3
Codec ID : 55
Codec ID/Hint : MP3
Duration : 55mn 52s
Bit rate mode : Constant
Bit rate : 48.0 Kbps
Channel(s) : 1 channel
Sampling rate : 32.0 KHz
Resolution : 16 bits
Stream size : 19.2 MiB (4%)
Alignment : Split accross interleaves
Interleave, duration : 256 ms (7.67 video frames)
και
Code:
General
Complete name :
Format : AVI
File size : 419 MiB
Duration : 52mn 19s
Overall bit rate : 1 119 Kbps
lmdo : hlmdψ
Video
Format : AVC
Codec ID : H264
Duration : 52mn 19s
Bit rate : 1 062 Kbps
Width : 640 pixels
Height : 480 pixels
Colorimetry : 4:2:0
Bits/(Pixel*Frame) : 0.115
Stream size : 397 MiB (95%)
Audio
Format : MPEG Audio
Codec ID : 55
Codec ID/Hint : MP3
Duration : 52mn 18s
Stream size : 18.0 MiB (4%)
υπάρχουν περιθώρια μετατροπής με κάποιο πρόγραμμα κλπ ή πρέπει να ψάξω για άλλο version;
επειδή μου χουν τύχει διάφορα τέτοια βίντεο που λέει ότι δεν τα υποστήριζει τελευταία, παρακαλώ πολύ ας μου απαντήσει όποιος ξέρει
