-Samsung TV Line-up 2017-
xavito
29 October 2008
8,984
[hdtvtest.co.uk]...Samsung Q9 & Q8 is World’s 1st QLED TV with 100% DCI-P3 Colour Volume...http://www.hdtvtest.co.uk/news/samsung-q8-201701044401.htm
source photo:[hdtvtest.co.uk]
[nl.hardware.info]...CES: Samsung shows QLED TVs show with connections via extension...https://nl.hardware.info/nieuws/50601/ces-samsung-laat-qled-televisies-zien-met-aansluitingen-via-verlengkabel
μετάφραση google nl to en
[/IMG]
source photos:[nl.hardware.info]
xavito
29 October 2008
8,984
[flatpanelshd.com]...Samsung unveils "QLED " - Q9 flagship TV is flat...http://flatpanelshd.com/news.php?subaction=showfull&id=1483516350
source photo:[flatpanelshd.com]
[forbes.com]...Samsung QLED TVs Hands On: Welcome To The Revolution...http://www.forbes.com/sites/johnarc...g-qled-tvs-hands-on-welcome-to-the-revolution
Pic: John Archer
https://www.youtube.com/watch?v=mKJqZOWNmXw
source video:[you tube - engadget.com]
[hdtvtest.co.uk]...Samsung QLED TV’s Viewing Angle Improved by Novel Subpixel Structure...http://www.hdtvtest.co.uk/news/qled-subpixel-201701044404.htm
...For eagle-eyed enthusiasts (that is, our readers), the most interesting change will be one that the company did not explicitly draw attention to in its presentations: the new displays’ subpixel rendering techniques. When viewed up close, the majority of the images shown on the QLED LCD panels did not appear with the traditional RGB stripe layout, but instead were displayed with a cross-hatch pattern. It turns out that each pixel is split into two domains, which are then driven with different gamma properties. The end result is the improvements in off-axis viewing angle quality. Samsung refers to the technique as Dual Pixel Structure.
Samsung are not the first LCD manufacturer to use such a technique - €“ long-time HDTVTest readers will likely be thinking of Sharp’s interesting LCD panels, and even Sony’s most recent displays have employed a more subtle variant. However, both the method and the results being demonstrated by Samsung’s new QLED displays appears far more pronounced. By this, we mean the different subpixel layout is more visible, but so too are the improvements to off-axis viewing. As with those similar methods from other manufacturers, full white areas of the screen in Samsung’s QLED implementation appear as RGB stripe, with the different pixel rendering technique becoming more visible in the darker and mid tones. (One of the first tests we’ll run when we receive review samples will be to feed a gradient ramp test pattern to the screens, to better observe the different rendering techniques used at different luminance levels.)
The new method is likely to divide opinion. Users who like to sit close to the screen will probably notice the cross-hatched effect more, and in one moving test clip, bright yellow New York style taxis moving quickly up the screen appeared with a diamond-like shimmer. On the other hand, users with larger and wider rooms may decide that the off-axis viewing improvements outweigh any other disadvantages the technique may or may not bring...
source:[hdtvtest.co.uk]...
:SFGSFGSF:
xavito
29 October 2008
8,984
[dday.it]...Zoeller, Samsung: "QLED the best technology in the world. The OLED reminds me of the plasma, limited and consumes more "...http://www.dday.it/redazione/22005/zoeller-samsung-qled-la-miglior-tecnologia-al-mondo-loled-mi-ricorda-il-plasma-limitato-e-consuma-di-piu
[dday.it]...Samsung launches QLED TV: improve contrast, color and brightness. All the details...http://www.dday.it/redazione/22003/samsung-qled-tv
[cnet.com]...Samsung QLED TVs face tough battle against LG's OLED...https://www.cnet.com/uk/products/samsung-q9-series/preview/
https://www.youtube.com/watch?v=1evv0mlHTlA
source video:[you tube - PROHARDVER.hu ]
World premiere tonight: Samsung ready with QLED...http://www.recordere.dk/2017/01/verdenspremiere-i-nat-samsung-klar-med-qled/
μετάφραση google dk to en
Samsung: QLED is better than OLED...http://www.recordere.dk/2017/01/samsung-qled-bedre-oled/
source :[recordere.dk]
JL_?
19 September 2008
15,415
Terra
''Having now seen the new TVs in the flesh, it seems that Samsung’s first QLED TVs not only live up to the hype, but if anything surpass even my most ‛out there’ hopes......''
http://www.forbes.com/sites/johnarc...ds-on-welcome-to-the-revolution/#12cdb336741f
Τι λέτε βρέθηκε ανταγωνιστής για τις OLED η είναι ακόμα ένα marketing trick?
Πολυ χλωμό το βλέπω, αλλά ας έρθουν πρώτα, να τις δούμε και να τις μετρήσουμε...
Μα απορώ, γιατί δεν καταργεί τις OLED στα κινητά και ταμπλέτες της, να βάλει QLED κι εκεί; :BDGBGDB55:
hxostil
εμενα η απορια μου ειναι αφου βγαζει Oled στα κινητα και ταμπλετ γιατι δεν το κανει και στις τηλεορασεις??μα τι πινουν εκει στην samsung
JL_?
19 September 2008
15,415
Terra
Ο τρόπος κατασκευής OLED πάνελ που εφαρμόζει η Samsung, δεν της επιτρέπει ικανοποιητικά production yields για τα μεγέθη των τηλεοράσεων, οπότε...
JL_?
19 September 2008
15,415
Terra
δεν υπαρχει δεν μπορω..υπαρχει δεν θελω...
Όταν υπάρχουν πατέντες σε ισχύ από τον βασικό αντίπαλο, οι κατευθύνσεις που μπορεί να βρει έκφραση το "θέλω", περιορίζονται σημαντικά...
hxostil
εε ναι .....τωρα βεβαια λεει οτι βρηκε το χρυσο αυγο..οπως και καθε χρονο
