Sigma dp-series large-sensor compacts ..
4,594
http://www.imaging-resource.com/new...yled-sigma-dp-series-large-sensor-compacts-ge
http://www.dpreview.com/news/2014/0...ource=news-list&utm_medium=text&ref=title_0_0
19.6/4,9 Μp "Foveon Quattro" direct image sensor .. με την μεγάλη ανάλυση μόνο στο πάνω Layer (Κατι σαν το 4:1:1 color subsampling)
Newly developed Foveon X3 Quattro direct image sensor
Now featuring 39 megapixel-equivalent ultrahigh resolution
Capturing the information transmitted by light vertically instead of horizontally, the full-color image capture system of the Foveon direct image sensor is the only one of its kind in the world. This system makes possible the sensor’s full-bodied image quality, which is characterized by rich tone and gradation and texture that one can almost touch.
The newly developed Foveon X3 Quattro is the latest generation of this unique sensor. While retaining the distinctive characteristics of its predecessors, it offers an even higher level of image quality. In addition to 30% higher resolution, the volume of image data has become lighter, and it enables much faster image processing and lower current consumption.
At the same time, Able to maintain the same exacting standard of image quality while increasing megapixels and enhancing noise characteristics, this 1:1:4 solution was the inspiration for the name of the current generation of Foveon sensor: “Quattro.”
.. Για να δούμε ..
paulmarinis
7 September 2007
4,537
Re: Foveon reinvented: Radically-styled Sigma dp-series large-sensor compacts ..
εγω νομιζω πρεπει να βαλουν και τηλεφωνο μεσα της παντως....να βγαινει και η κεραια:)
AlexTheodin
25 December 2007
5,912
Athens, Thessaloniki, Köln
Abomination...
Σαν ξυριστική μηχανή που περνάει κρίση ταυτότητας. Γιατί??????
Θα θάψουν εναν απο οτι φαίνεται πολλά υποσχόμενο αισθητήρα και έναν σίγουρα καλό φακό...
send
30,947
Απάντηση: Re: Foveon reinvented: Radically-styled Sigma dp-series large-sensor compac
Abomination...
Αρχίζω σιγά-σιγά και διαμορφώνω άποψη για το Marketing dpt της Σίγμα....
leonkoum
20 December 2008
4,887
Απάντηση: Foveon reinvented: Radically-styled Sigma dp-series large-sensor compacts .
Χριστός κι Απόστολος!
Τι ασχήμια είναι τούτη?
Taσο χανεις την ουσια για το περιτύλιγμα.....:flipout:
opus dei ?
send
30,947
Βρε Κώδικας ΝταΒίντσι και βάλε μιλάμε οι τύποι.... :flipout:
Billy the Kid
28 April 2007
14,825
Αθήνα με απόσπαση.
Να μην εκπλαγούμε βέβαια αν λανσαριστεί στην τιμή των 15.000 και σε δυο μήνες πέσει στα 150 όπως συνέβη με την SD1
Κάτι σαν την κατοχική δραχμή και τον Μαρκεζίνη ένα πράγμα...
cacau
7 June 2008
20,365
Από το στόμα σου και στου Θεού το αυτί...
4,594
Woww .. στο βασικό ISO εντυπωσιακή ευκρίνεια !!! (και καλό χρώμα παρόλλο που εκφραστηκαν αμφιβολίες...) δείτε την σε φουλ μεγεθος .. (δεξι κλικ - view image).
αλλα ανεβάζοντας ISO χαλάει γρήγορα το χρώμα .. :( .. θα με κάνουν να κατεβάζω το αχώνευτο Sigma Photo Pro για δοκιμές στα RAW ..
ilias
9,146
Bratislava
Σιγα βρε γκρινιαρη... λες να ειναι χειροτερο απο αυτο της νικον το ΝΧ-D που κατεβασα εγω? :twoguns:
Kosh
7 September 2006
91,306
Εκεί ψηλά.....
Eγω μια SD1 παντως θα την χτυπησω οταν καραξεφτιλιστει.
yiannakas
28 September 2006
1,714
έλα ντε... έχει μπαστακωθεί στο χιλιάρικο εδώ και καιρό
_tzo_
Banned
18 November 2007
11,985
Re: Απάντηση: Re: Foveon reinvented: Radically-styled Sigma dp-series large-sensor co
Ωραία η Quattro, αλλά προτίμησα το φτηνότερο εισιτήριο της Merill (400 ) για να μπω στον κόσμο του Foveon.
paulmarinis
7 September 2007
4,537
κοιταω και εγω για καμια μεταχειρισμενη στο ebay:)
_tzo_
Banned
18 November 2007
11,985
Re: Απάντηση: Foveon reinvented: Radically-styled Sigma dp-series large-sensor compac
Τουβλάκι, μεταλλική, στιβαρή κατασκευή, made in Japan. Kαλή αίσθηση στα κουμπιά και ειδικά στη μία και μοναδική ροδέλα.
Βουτυράτο το δαχτυλίδι εστίασης στον φακό. Γενικά εμπνέει αίσθηση ποιότητας στην κατασκευή.
Φορτίζουν τώρα οι δύο μπαταρίες. Ναι, βάζει δύο μπαταρίες η Sigma, λόγω της τραγικά περιορισμένης αυτονομίας (40 λήψεις σε πραγματικές συνθήκες!).
Βολεύει τουλάχιστον που είναι ίδιες μπαταρίες με της Ricoh GR, κι έτσι θα αλλάζω μπαταρίες μεταξύ των δύο μηχανών, και στις εκδρομές θα κουβαλάω έναν φορτιστή.
ΒΛΑΣΙΔΗΣ
19,341
μπράβο!!!
Πολύ καλή κίνηση. θα έπαιρνα κι εγώ μια τέτοια (με τον 45άρη), αλλά δεν ήλθαν τα χρήματα που περίμενα.
