--- Sony Bravia V4500 ---
-Γιώργος-
19 June 2007
8,441
37°54'25''N-23°45'24''E
Σε τρία μεγέθη 26'', 32'' και 37'', με ανάλυση 1366x768, δέκτη HD mpeg4, Bravia Engine 2, Picture Frame Mode και 24p True Cinema.
5th May 2008 - Whether you’re into movies on Blu-ray Disc™, enjoying the latest PLAYSTATION®3 games or watching HD broadcasts, the BRAVIA™ V4500 series matches superb picture quality with smart features for a home entertainment experience like no other.
The V4500 series showcases Sony’s innovative new draw the LINE design concept. This beautifully inspired, pared-down styling philosophy enhances the total TV viewing experience without distracting from what’s on the screen. Accented by a dark silver speaker, the set’s deep piano black finish creates an effortlessly contemporary look to flatter any living space. 26-inch, 32-inch and 37-inch models all feature a swivelling stand for comfortable viewing from wherever you’re sitting in the room.
All screen size models feature an integrated MPEG-4 AVC HD tuner, allowing you to enjoy terrestrial HDTV programmes where compatible DVB-T/DVB-C services are available.
HD picture quality is superb thanks to latest-generation BRAVIA™ ENGINE 2 technology that gives images an unmatched richness and depth. The WXGA (1360×768 Resolution) LCD panel offers a very high dynamic contrast ratio of 33000:1 (26-inch and 32-inch models), ensuring deep, cinema-like blacks plus sparkling highlights. For an even more authentic home theatre experience, 24p True Cinema technology guarantees that movies on Blu-ray Disc™ are presented at the correct frame rate.
When you’re not watching television, Picture Frame Mode makes it easy to enjoy favourite images from your digital picture collection. Rich, detail-packed still images can be displayed by connecting any compatible USB flash memory device. Six pre-installed gallery pictures are also included, featuring a range of contemporary art images from van Gogh² to Pop Art. In Picture Frame Mode, image brightness is reduced to mimic the appearance of a photographic print or painting. Power consumption can be reduced by up to 35% compared with watching regular TV³.
Operation is satisfyingly intuitive, thanks to Sony’s XMB™ (Xross Media Bar™) on-screen interface that simplifies browsing TV channels, selecting inputs, Picture Frame Mode and other functions.
BRAVIA™ Sync controls your complete home theatre system from the TV remote. At the touch of a button, everything’s powered up and ready to play, with no need to juggle several different remotes to switch on other devices, select inputs and adjust levels. BRAVIA™ Sync also allows simple operation of a connected compatible Handycam® camcorder from the television’s remote.
Three HDMI sockets are provided for one-cable connection of other devices including PlayStation®3, Blu-ray Disc™ players and Handycam® HD camcorders.
“The superbly styled, easy to use BRAVIA™ V4500 series gives everyone a more satisfying home entertainment experience, whether they’re into TV, movies or games“, comments Hiroshi Sakamoto, Marketing and Product Planning Vice President, TV Operations Europe, Sony Europe. “And now with the inclusion of an HD tuner, there are even more options for enjoying great-looking HD images with breathtaking quality.”
Sony Europe
czoun
29 November 2007
7,734
Το χερούλι στο κάτω μέρος της οθόνης, σε τι χρησιμεύει............?????:chinscratch:
Υπάρχει κάποιος λειτουργικός λόγος ή είναι απλά το σχέδιο?????:grandpa:
kyrliot
31 March 2008
3,913
sorry gatare , σαν ποιοτητα tv ειναι super στο τσακ δεν την πηρα τα χριστουγεννα την 46χ3500 αλλα τωρα που θελω 52αρα και ακριβη ειναι και μοντελα θα αλλαξει φετος αρα μαλλον 52w4000 αν το sd σημα βλεπετε.
GeoGeoGeo
28 March 2007
3,497
Δεν είναι κενο ρε παιδια διαφανες είναι και μάλλον θα χει touch sensitive buttons.Πολυ καλά χαρακτηριστικα για την κατηγορια της και το design είναι αρκετα καλο παντως
smoothbore
23 March 2007
2,615
Δεν ξερω τι λετε γιαυτην εδω , αλλα οσον αφορα την Χ τρια πραγματα θα πω:
Υψος.........αλεπου...........κρεμασταρια :ROFLMAO::ROFLMAO:
smoothbore
23 March 2007
2,615
Bλεπω οτι δεν ειμαι ο μονος που μου εκατσε στο στομαχι η χ3500 χι χι
Ποτε δεν ειναι ευκολο να χωνεψει ενα στομαχι ..........οτι θα δωσει τοσα λεφτα για μια τηλεοραση :smash:
underdog
26 November 2007
6,744
Άντε και να τα δώσει...όταν αρχίσει ο πεντοζάλης στο θολωμένο του μυαλό και μάτι στα γρήγορα πλάνα; :afro: :ADFAD2:
kyrliot
31 March 2008
3,913
Underdog, ολα αyτα τα blu-ray που εχεις δεν πρεπει να τα εχεις αγορασει απο Ελλαδα π.χ harry potter εγω δεν τα εχω δει.
