Αύριο θα παρουσιαστεί η μηχανή που με έχει κάνει να σκέφτομαι να τα δώσω όλα και να γυρίσω σε Sony.. Ο λόγος φυσικά για την a77
Το μόνο "κακό" είναι ότι δεν είναι ff.. Κάτι που θα "διορθώσει" η a99 μέσα στο 2012
a77 specs:
24.3 MP Exmor HD CMOS sensor
19 points AF sensor with 11 cross sensors
ISO 100-16000, with expandeable ISO 50 option
1920 x 1080 60p/24p AVCHD 2.0
P/A/S/M manual controls while recording video
1200 zone metering
Completely new developed Bionz processor
12 fps
1/8000 shutter speed
50ms minimum release time lag
electronic first shutter curtain
TrueBlack 921k 3-way tilt LCD
3 million dot OLED viewfinder
Smart teleconverter function with 1.4x and 2.0x option
Built-in flash
Built-in GPS
Battery life with over over 500 shots
Magnesium alloy body
Dust and Moisture proof
Multi Frame NR
SD card (no CF!)
Body only will be priced at $1000-$1200
Body + 16-50mm f/2.8 SSM Kit will be priced between $1600 and $1800.
Sony a65
specs, σε σχέση με την a77:
As you know the A65 shares the same 24 Megapixel sensor of the A77. The only differences are:
A77 has 19 point AF system with 11 cross sensors while the A65 has only 3 cross sensors.
A77 can do 12 fps while the A65 can do 10fps.
A77 has new 3 way tilting LCD, A65 has “classic” tilting LCD
A77 can do 50 ISO while A65 can not.
The A77 has a magnesium body while the A65 has not.
The A77 has 1/8000 shutter while A65 has a 1/4000 shutter
The A77 has a top LCD screen while the A65 has it not.
The A77 is Dust and Moisture proof while the A65 is not
Αύριο θα παρουσιαστούν επίσης η ΝΕΧ-7, ΝΕΧ-5Ν, ο 16-50 f2.8 SSM, η VG20, ο 50mm f1.8 OSS για ΝΕΧ, ο Zeiss 24mm f1.8 για ΝΕΧ αλλά αυτά είναι για άλλο thread
a77 specs:
1200 zone metering
12 fps
Built-in flash
Built-in GPS
Multi Frame NR
SD card (no CF!)
Sony a65
