ΡΑΔΙΟΕΝΙΣΧΥΤΗΣ SONY STR-GX315 ΣΕ ΑΡΙΣΤΗ ΚΑΤΑΣΤΑΣΗ - ΤΙΜΗ 60 ΕΥΡΩ ΚΑΙ ΣΥΝΑΛΛΑΓΗ ΑΠΟ ΤΟΝ ΧΩΡΟ ΜΟΥ [ΑΘΗΝΑ]
Power output: 70 watts per channel into 8Ω (stereo)
Frequency response: 10Hz to 50kHz
Input sensitivity: 2.5mV (MM), 250mV (line)
Signal to noise ratio: 75dB (MM), 82dB (line)
Output: 250mV (line)
Dimensions: 430 x 135 x 300mm
Weight: 6.2kg
Specifications
Tuning range: FM, MWPower output: 70 watts per channel into 8Ω (stereo)
Weight: 6.2kg
