-Sony TV Line-up 2020-
winlink
4 July 2006
1,324
Ελληνικό, Αττική
Σύμφωνα με το manual
Dimensions (Approx.) (w × h × d)
with Table-Top Stand
KD-65X70xx: 146.3 × 90.4 × 34.0 cm
KD-55X70xx: 124.1 × 78.1 × 34.0 cm
without Table-Top Stand
KD-65X70xx: 146.3 × 84.5 × 8.0 cm
KD-55X70xx: 124.1 × 72.1 × 7.9 cm
άρα βάθος βάσης για 55 & 65 είναι 34cm
Όσον αφορά το πλάτος της επιφάνειας που χρειάζεται, για την 65 λέει εδώ 82.9cm και για την 55 81,2cm
Λίγο ψάξιμο έκανα και τα βρήκα
hristoslav2
8 January 2016
359
Varna, Bulgaria
Sony43"49"50"55"60"65"70"75"85"
ZH8MVAMVA
XH95MVAMVAMVAMVAMVA
XH90 / XH92MVAMVAMVAMVA
XH85IPSMVA
XH81IPSIPSIPSIPS
XH80IPSIPSPLS (IPS)IPSIPSMVA
X70IPSIPSMVAMVA
xavito
29 October 2008
8,988
48"...[hdtvtest.co.uk]...Sony KD-48A9 review
We review the Sony A9 (also marketed as the BRAVIA A9S in the USA) 48-inch OLED TV which is branded as "Master Series" by the Japanese brand.
Topics covered including:
near-black handling,
colour accuracy,
motion performance including 120Hz black frame insertion,
video processing,
screen uniformity,
HDR including Dolby Vision,
as well as gaming including input lag and PS5 compatibility.
https://www.youtube.com/watch?v=pvtJ_IRNUTY
xavito
29 October 2008
8,988
48"...[rtings.com]...Sony XBR-48A9S review,calibration...https://www.rtings.com/tv/reviews/sony/a9s-oled
Specs...http://www.sonypremiumhome.com/pdfs/product_XBR48A9S_2020-07-22_05-59-10.pdf
Dimensions...http://www.sonypremiumhome.com/pdfs/48A9S-Dimension-Drawing.pdf
source:[sonypremiumhome.com]
xavito
29 October 2008
8,988
We compare TV-led Dolby Vision vs player-led Dolby Vision using two Sony XH90 (also known as the BRAVIA X900H in the USA) 4K LED LCD TVs, two OPPO 203 4K Blu-ray players, as well as two Spears & Munsil UHD HDR Benchmark disc.
Player-led Dolby Vision is also known as low-latency or source-led Dolby Vision.
The differences are more obvious in person than what's captured on camera, since we had to slightly defocus the zoomed-in shots to avoid introducing moire to our footage.
https://www.youtube.com/watch?v=e_a77zJTrO4
source:[hdtvtest.co.uk]
xavito
29 October 2008
8,988
55"...[tweakers.net]...Sony KD-55X7055 vs LG 55NANO816NA vs Samsung UE55TU7020 vs Hisense 55A7500F...https://tweakers.net/reviews/8510/betaalbare-55-inch-televisies-de-populairste-maat-voor-zeshonderd-euro.html
Sony KD-55X7055:VA panel,50/60Hz, Wide Color Gamut ("Triluminos" color technology)
LG 55NANO816: IPS panel,50/60Hz, Wide Color Gamut ("NanoCell" color technology)
Samsung UE55TU7020 : VA panel,50/60Hz,no Wide Color Gamut
Hisense 55A7500F:VA panel,50/60Hz,no Wide Color Gamut
Sony KD-55X7055
We find uniformity best with Sony television. Still, there is something to criticize here, because the corners are quite dark and the image at the top and bottom edges is clearly less clear. The black display is not bad for an LCD TV and the brightness of black remains within limits, even at an angle.
xavito
29 October 2008
8,988
Following a firmware update, certain Sony TV models in Europe are now displaying an inconvenient pop-up notification every time a picture mode/ setting that can affect the light output on screen is adjusted.
Sony TV models that are affected include the Sony XH90/ XH92, as well as Sony TVs with X1 Ultimate chipsets (Sony AF9, AG9, A8, XH95, etc.).
The pop-up warning message reads: "This may increase power consumption more than the normal configuration.", requiring users to either click "OK" or "Cancel".
We reached out to Sony UK for comment, and this is their response: "This was implemented based on the EU regulation for power consumption. We will take customer feedback seriously, and will consider for future user interface."
https://www.youtube.com/watch?v=oqprrcMAqqk
xavito
29 October 2008
8,988
Ενημέρωση υλικολογισμικού σε v6.5042 (PKG6.5042)...https://www.sony.gr/electronics/support/lcd-tvs-android-z8h_zh8-series/kd-75zh8/downloads/00017153
Ημερομηνία κυκλοφορίας:24-02-2021
Πλεονεκτήματα και βελτιώσεις:
Επιλύει ένα πρόβλημα κατά το οποίο δεν ακούγεται ήχος από τα κανάλια της τηλεόρασης μετά την ενεργοποίηση της τηλεόρασης ή την αλλαγή καναλιού
Επιλύει ένα πρόβλημα κατά το οποίο δεν ακούγεται ήχος από εφαρμογές μετά την ενεργοποίηση της τηλεόρασης
Επιλύει ένα πρόβλημα κατά το οποίο το YouTube σταματούσε να παίζει περιεχόμενο
Επιλύει ένα πρόβλημα κατά το οποίο η τηλεόραση ενεργοποιείται ξαφνικά όταν γίνεται απόπειρα σύζευξης συσκευών Bluetooth με την τηλεόραση ενώ είναι απενεργοποιημένο το RC
Ενημερωμένη ταξινόμηση καναλιών (ισχύει μόνο στην Κροατία)
Αυτές οι πληροφορίες ισχύουν για τα ακόλουθα μοντέλα τηλεόρασης:
KD-ZG9
KD-ZH8
KD-ZF9
KD-AF9
KD-AG9
KD-A8
KD-48A9
KD-XH95
KD-XG95
KD-XG85
KD-XH85
KD-XH80/81
xavito
29 October 2008
8,988
Νέες ενεργειακές ετικέτες στις τηλεοράσεις Sony χρονιάς 2020...https://geex.x-kom.pl/wiadomosci/nowe-etykiety-energetyczne-w-telewizorach-sony/
Η Sony άλλαξε τις ετικέτες στις τηλεοράσεις της που κυκλοφόρησαν πριν από το 2021, αλλά εξακολουθούν να πωλούνται.
Εξηγούμε ποιος είναι ο λόγος αυτής της απόφασης.
Βασικά, οι τηλεοράσεις με την ονομασία "KD- ..." και "KE ..." είναι τα ίδια μοντέλα.
Το "KE ..." είναι ένα μοντέλο του οποίου η κατανάλωση ισχύος συμμορφώνεται με τους νέους κανονισμούς ενέργειας.
Η μόνη διαφορά είναι η προεπιλεγμένη ρύθμιση κατανάλωσης ενέργειας.
Η προεπιλεγμένη φωτεινότητα προσαρμόζεται στη ρύθμιση κατανάλωσης ενέργειας.
Εάν ο πελάτης προτιμά μια ρύθμιση υψηλότερης φωτεινότητας, μπορεί να την προσαρμόσει για μια φωτεινότερη εικόνα, αλλά σε αυτήν την περίπτωση η κατανάλωση ενέργειας θα αυξηθεί σύμφωνα με τη νέα ρύθμιση.
Η αλλαγή προκύπτει από την ενημέρωση των κανονισμών για την κατανάλωση ενέργειας στην Ευρωπαϊκή Ένωση και τη Μεγάλη Βρετανία.
Οι μέθοδοι και τα κριτήρια μέτρησης έχουν αλλάξει, και ως εκ τούτου οι τιμές και η ταξινόμηση έχουν αλλάξει, αλλά η κατανάλωση ισχύος της ίδιας της τηλεόρασης παρέμεινε η ίδια.
Εν ολίγοις, είναι τα ίδια μοντέλα αλλά με μια νέα ενεργειακή ετικέτα.
Γιατί η Sony εισήγαγε νέες ενεργειακές ετικέτες για τηλεοράσεις;
Οι λόγοι για την εισαγωγή των νέων ετικετών εξηγούνται σε επίσημη ανακοίνωση της ΕΕ:
Γιατί η Επιτροπή αλλάζει σε μία μόνο ενεργειακή ετικέτα κλίμακας A σε G;
Από το 1995, το σήμα ενεργειακής απόδοσης της ΕΕ έχει αποδειχθεί πλήρως: 85% Ευρωπαίοι καταναλωτές το χρησιμοποιούν όταν αγοράζουν.
Έχει επίσης γίνει κινητήρια δύναμη για καινοτόμες αλλαγές στη βιομηχανία και τον ανταγωνισμό λόγω της σταδιακής εισαγωγής στην αγορά νέων προϊόντων με ολοένα και υψηλότερες ενεργειακές κατηγορίες.
Αν και αρχικά τα περισσότερα μοντέλα ήταν στις χαμηλότερες βαθμολογίες (π.χ. E, F, G), τα νέα μοντέλα κατατάχθηκαν υψηλότερα και υψηλότερα έως ότου έφτασε στην τρέχουσα κατάσταση όπου τα περισσότερα προϊόντα βρίσκονται στις υψηλότερες βαθμολογίες (A +++, A ++, A +) και κανένα προϊόν δεν είναι επί του παρόντος στους χαμηλότερους βαθμούς (σε ορισμένες περιπτώσεις ακόμη και A).
Παραδόξως, αυτή η επιτυχία κάνει επί του παρόντος δύσκολο για τους καταναλωτές να κάνουν διάκριση μεταξύ των πιο αποδοτικών προϊόντων: πιστεύουν ότι όταν αγοράζουν ένα προϊόν Α +, επιλέγουν από τα πιο αποτελεσματικά προϊόντα στην αγορά, ενώ στην πραγματικότητα αγοράζουν μερικές φορές ένα μέσο προϊόν ή ακόμη και ένα από τα λιγότερο αποτελεσματικά.
Προκειμένου να αυξηθεί η ευαισθητοποίηση των καταναλωτών και να διευκολυνθούν οι συγκρίσεις προϊόντων, η ΕΕ αποφάσισε να επανέλθει στην κλίμακα Α έως G στο μέλλον.
πηγή:[geex.x-kom.pl]
85"...[athinorama.gr]...Sony Bravia KD-85ZH8 παρουσίαση...https://www.athinorama.gr/digital/homecinema/article/sony_bravia_85zh8-2547700.html
xavito
29 October 2008
8,988
Sony: Redesigned Android TV homescreen coming to 2016-2020 models...https://www.flatpanelshd.com/news.php?subaction=showfull&id=1619767413
Sony Android TVs getting the new UI
US model names listed below. To get the EU model name move the last letter to second position, i.e. X90H = XH90.
2021: W800
2020: Z9H, Z8H, A9S, A8H, X95H, X92H, X91H, X90H, X85H, X81H, X80H, X75H
2019: Z9G, A9G, A8G, X95G, X90G, X87G, X85G, X83G, X81G, X80G, W80G
2018: A9F, Z9F, A8F, X90F, X87F, X85F, X83F, X80F, X78F, X75F, W80F
2017: A1, X95E, X94E, X93E, X90E, X85E, X82E, X80E, X75E
2016: Z9D, X83D, X80D, S80D, X75D, X70D
πηγή: flatpanelshd.com
xavito
29 October 2008
8,988
Ενημέρωση υλικολογισμικού στην έκδοση v6.5076 (PKG6.5076)...https://www.sony.gr/electronics/sup...eries-55-65-75-/kd-55xh9505/software/00267389
Επιλύει ένα πρόβλημα κατά το οποίο δεν υπήρχε εικόνα ή/και ήχος κατά τη μετάβαση σε επίγεια είσοδο
Αυτές οι πληροφορίες αφορούν τα παρακάτω μοντέλα:
KD/KE-A8
KD-AF9
KD-ZF9
KD-48A9
KD-XG85
KD-XG95
KD-AG9
KD-ZG9
KD/KE-XH80/XH81
KD-XH85
KD-XH95
KD-ZH8
