Ρυθμίσεις εικόνας για KDL-W8xxB series.
hdtvtest.co.uk
[Scene Select] Cinema
[Cinema 1]
[Gamma]-2
[Live Colour] “Off”
[Motionflow]
• “Off”: Doesn’t apply any motion-boosting technology. Motion resolution 300 as determined via the horizontally scrolling lines pattern in Chapter 31 of the FPD Benchmark Software disc.
• “True Cinema”: Ensures native 24p playback for 1080p/24 material such as Blu-ray movies. Motion resolution stays the same at 300, since there’s no MCFI/ BFI involved.
• “Standard”: Pure MCFI. Doubles motion resolution to 600. Not advised.
• “Smooth”: Pure MCFI with stronger intensity, which introduces more interpolation artefacts even though motion resolution did not increase beyond 600. Avoid.
• “Clear”: MCFI with a small component of BFI. Few interpolation artefacts with a mild decrease in on-screen luminance. Motion resolution 1080. Good for daytime general use.
• “Clear Plus”: MCFI with a higher proportion of BFI. Even less interpolation artefacts, but picture is darker than “Clear“. Motion resolution 1080. Suitable for night-time general viewing.
• “Impulse”: Pure BFI. Motion resolution 1080. May be too dim for most usage.
A quick paragraph on [Motionflow] “Impulse“, whose black frame insertion algorithm we found to be less aggressive and more user-friendly than the [LED Motion Mode] implemented on the lower-end W705 series. The KDL50W829′s [Impulse] mode evinced less flicker and double image ghosting than the KDL42W705′s [LED Motion Mode], and we managed to extract a higher light output of 49 cd/m2 with [Backlight] and [Contrast] cranked up to “Max“. Sure, it’s still quite dim, but it’s usable for viewers who crave the clearest/ sharpest motion from an LCD.
[Film Mode] “Auto“
avforums.com
Scene Select: Cinema
Picture Mode: Cinema 1
Backlight: 3 (Make sure you turn the Light Sensor off in System Settings/Eco)
Contrast: 80
Brightness: 50
Colour: 50
Hue: 0
Colour Temperature: Warm 2
Sharpness: 50
Noise Reduction: Off
MPEG Noise Reduction: Off
Dot Noise Reduction: Off
Reality Creation: Manual
Video Area Detection: Off
Resolution: Low 0 - 20 (play with it depending on compression)
Smooth Gradation: Low
Motionflow: Off/True Cinema
Film Mode: Auto
Advanced Settings
Black Corrector: Off
Advanced Contrast Enhancer: Off, ‛Low’
If you do want some improvement on all, or nearly all, black screens you could set the Adv Contrast Enhancer to Mid but it will come at the cost of some luminance flashes on frame transitions, albeit only fleeting ones.
Gamma: -1
Auto Light Limiter: Off
Clear White: Off
Live Colour: Off
White Balance: Red Gain -3, Green Gain -8, Blue Gain 0, Red Bias 0, Green Bias 0, Blue Bias 0
Detail Enhancer: Off
Edge Enhancer: Off
Skin Naturaliser: Off
hdfever.fr
Blu-ray
• Mode image : Cinema 1
• Retroeclairage : 4
• Contraste : 90
• Luminosite: 49
• Couleurs : 55
• Teinte : 0
• Temperature : CHAUD 2
• Nettete : 50 (largement suffisant)
• Motionflow : au choix, soit le mode standard qui conserve la meme luminosite, mais offre un rendu legerement plus fluide et typee video, soit le Mode Net (c’est le plus naturel sur les contenu 24p a mon gout, chacun fait comme il le sent, mais le mode Cinema saccade un peu dans les travellings, et les autres affichent un effet un peu camescope, le Net+ assombrit un peu l’image)
• Mode film : Auto
• Correction des noirs : Off (a tendance a boucher les noirs)
• Amelioration de Contraste : Off (contraste dynamique, a eviter, car ca brule les blancs)
• Gamma : -2
• Limiteur d’intensite : Off
• Correction Blanc : Off
• Couleur Naturelle : Off
• Balance des Blancs :
o GAIN Rouge : 0
o GAIN Vert : -4
o GAIN Bleu : 0
o Polarisation Rouge : 0
o Polarisation Vert : 0
o Polarisation Bleu : -1
Pour le traitement video, si vous avez un OPPO ou un Panasonic BDT500, laissez lui le travail et desactivez le Reality Creation et les ameliorations de contours ou de details, sinon si vous n’avez pas de traitement video sur le lecteur Blu-ray, vous pouvez appliquer ca, mais ce n’est pas une obligation, seulement si vous trouvez l’image trop douce, pas assez nette et pas assez de relief :
Reality Creation
• Controle par zone : on
• Resolution : +35
• Reducteur de bruit : 0
• Lissage des degrades : bas
Reglages Avance :
• Accentuation des contours : Bas
• Amelioration des details : Bas
Settings TNT
• Mode image : Standard
• Retroeclairage : 6
• Contraste : 90
• Luminosite : 50
• Couleurs : 50
• Teinte : 0
• Temperature : Chaud 1
• Nettete : 55
• Tous les filtres reducteurs de bruit sur Auto
• Reality Creation : Auto
• Lissage des degrade : Bas
• Motionflow : Mode Standard
• Mode film : Auto
• Correction des noirs : Bas
• Amelioration de Contraste : Bas
• Gamma : 0
• Couleur Naturelle : Bas
• Balance des Blancs : tout sur 0 (par defaut)
• Rendu Naturel des tons chair : Oui
flatpanelshd.com
Viewing mode: Cinema 1
Backlight 10
Contrast 90
Brightness: 50
Color: 50
Hue: 0
Color temperature Warm2
Sharpness 50
Noise reduction Off
Dot/mpeg noise reduction Off
Reality Creation Off
Smooth gradation Off
Motionflow True Cinema
Film mode Auto
Black corrector Off
Adv. Contrast Enhancer Off
Gamma -1
Auto Light Limiter Off
Clear White Off
Live Color Off
Detail Enhancer Off
Edge enhancer Off
R Gain -3
G Gain -13
B Gain 0
R Bias 0
G Bias -1
B Bias 0
Eco (light sensor) On/Off
