Specifications
CPU
- CPU Frequency: Dual Core 1.066 GHz
- Floating Point: Yes
- Hardware Encryption Engine: Yes
Memory
- System Memory: 512 MB DDR3
Storage
- Drive Bay(s): 2
- Drive Type: 3.5" , 2.5"
- Max. Internal Capacity: 8 TB (4 TB HDD X 2) (Capacity may vary by RAID types)
- Hot Swappable Drive: Yes
External Ports
- USB 2.0 Port: 1
- USB 3.0 Port: 2
- USB/SD Copy: Yes
File System
- Internal Drives: EXT4
- External Drives: EXT4, EXT3, FAT, NTFS, HFS+
Others
- LAN Number (RJ45): Gigabit X 1
- Wake on LAN/WAN: Yes
- System Fan: 92 mm X 92 mm X 1 pcs
- Wireless Support (dongle): Yes
- Noise Level: 19.9 dB(A)
- Power Recovery: Yes
- Power Supply Unit / Adapter: 65W
- AC Input Power Voltage: 100V to 240V AC
- Power Frequency: 50/60 HZ, Single Phase
- Power Consumption: 22.64W (Access) , 9.12W (HDD Hibernation)
Temperature
- Operating Temperature: 5°C to 35°C (40°F to 95°F)
- Storage Temperature: -10°C to 70°C (15°F to 155°F)
- Relative Humidity: 5% to 95% RH
- Maximum Operating Altitude: 6500 feet
Certification
- FCC Class B
- CE Class B
- BSMI Class B
Warranty
- 2 Years
Packaging Content
- Main Unit X 1
- Installation Disc X 1
- Welcome Note X 1
- Accessory Pack X 1
- AC Power Adapter X 1
- AC Power Cord X 1
- RJ-45 LAN Cable X 1
Appearance
- Size: 165 mm x 108 mm x 233.2 mm
- Weight: 1.30 kg.
• Datasheet
• DS214
Specifications
CPU
- CPU Frequency: Dual Core 1.33 GHz
Memory
- System Memory: 1 GB DDR3
Storage
- Drive Bay(s): 2
External Ports
- USB 2.0 Port: 1
- USB 3.0 Port: 2
- eSATA Port: 1
- USB/SD Copy: Yes
File System
Others
- LAN Number (RJ45) Gigabit: X 2
- Link Aggregation: Yes
- System Fan: 92 x 92 mm X 1 pcs
- Noise Level: 19.2 dB(A)
- Power Supply Unit / Adapter: 72W
- Power Consumption: 27.62W (Access) / 9.26W (HDD Hibernation)
Temperature
Certification
- FCC Class B
- CE Class B
- BSMI Class B
Warranty
- 2 Years
Packaging Content
- Main Unit X 1
- Welcome Note X 1
- AC Power Cord X 1
- RJ-45 LAN Cable X 2
Appearance
- Size: 157 mm x 103.5 mm x 232 mm
- Weight: 1.65 kg.
• Datasheet
• DS214+
