Τεχνολογίες panel LCD-TFT
kostas5579
31 May 2010
1,827
THESSALONIKI/GREECE
Re: Τεχνολογιες panel LCD-TFT
Εδώ είμαστε. Παιδιά η δική μου tv έχει panel SQ02, είναι η Samsung LE32B551 παρεπιμπτόντως.
Σε γενικές γραμμές σε τί υπολείπεται του SQ01 που θεωρείται το κορυφαίο αν δε κάνω λάθος?
petasis
17,003
Δεν ξέρω να σου απαντήσω, αλλά διάβασα αυτό: http://www.avclub.gr/forum/showthread.php?p=1373542#post1373542
Yperion
21 June 2006
43,515
BVR (Beyond Visual Range)
36.5-inch flat panel TVs could arrive soon
LCD panels are manufactured on large factories from mother substrates that are cut into smaller LCD panels. Research firm DisplaySearch reports that some LCD manufacturers could benefit and see reduced costs by switching to 36.5-inch LCD panels.
36.5 inch flat panel TVs?
When you talk about LCD panel production you are also talking about LCD plant generations. An eight generation (8G) plant works with larger mother substrates than a 7G plant. These mother substrates are then cut into smaller LCD panels.
8G mother substrate – each box is a 46-inch panel
DisplaySearch says that most new 8G LCD plants can reduce costs by producing 36.5 inch LCD panels. A 36-5 inch panel is more cost efficient than 32, 40 and 42 inch LCD panels, DisplaySearch underlines.
LCD manufacturers such as Samsung, LG and Sharp all have huge LCD plants but have not commented on the matter at this point. However, DisplaySearch suggests that we might see the new size class in the future.
Just a few years ago took the 40-inch segment outgrew the 42-inch segment that was popular at that time. Samsung also recently changed their plasma sizes to 51” instead of 50” and 59” instead of 58” with their new 2011 plasma TVs.
http://www.flatpanelshd.com/news.php?subaction=showfull&id=1302852613
Και η ειδηση στα Ελληνικα...
http://www.fullhd.gr/news/eidiseis/technologia/7828-365-lcd-tvs-are-coming.html
evanfotis
26 March 2008
5,485
Απάντηση: Τεχνολογιες panel LCD-TFT
Ενα ενδιαφέρον άρθρο για την ιστορία των υγρών κρυστάλλων και λίγο για τη παρούσα φάση των πραγμάτων, με αρκετο μπλα μπλα. (το διάβασα πρόσφατα στο έντυπο, υπάρχει και διαδικτιακά ολόκληρο μόνο για συνδρομητές).
http://www.newyorker.com/reporting/2013/07/08/130708fa_fact_baker
petasis
17,003
Ενδιαφέρουσες οι φωτογραφίες, αισθητή η προπαγάνδα. Μου αρέσει που έβαλε και με πορτοκαλί μεγάλα γράμματα, ότι σε φωτεινό χώρο, η αντίθεση δεν παίζει ρόλο. Το ότι τα VA θα δείξουν κανονικά το shadow detail που από τα IPS πάνελ θα λείπει εντελώς, δεν παίζει καμιά σημασία, θα έρθει το φως σαν μαγικό ραβδί και θα τα σβήσει όλα... (Μα όλα;;; :flipout:)
Επίσης, οι γωνίες θέασης... Το μέγα "πλεονέκτημα" των IPS. Αν πρέπει να διαλέξεις ανάμεσα σε 2 τραγωδίες, ποια είναι πιο καλή; Αυτή που πεύτει η φωτεινότητα υπό γωνία (και τα χρώματα "ξεθωριάζουν" - VA) ή εκείνα που η φωτεινότητα πεύτει αισθητά λιγότερο, αλλά αρχίζουν οι χρωματικές μετακινήσεις και κιτρινίζει όλη η εικόνα;
Εγώ νομίζω και πάλι δύσκολα διαλέγεις το IPS...
papasouzakias
13 May 2009
4,523
Τριπλασιασμός ανάλυσης οθονών LCD χάρη σε πρωτοποριακή μέθοδο
Κάθε pixel σε μια οθόνη LCD περιλαμβάνει τρία subpixels. Το καθένα από αυτά ελέγχει ένα από τρία χρώματα: Κόκκινο, πράσινο ή μπλε. Ερευνητές του University of Central Florida ανέπτυξαν μια νέα επιφάνεια, η οποία επιτρέπει τη ρύθμιση/ χειρισμό μεμονωμένων subpixels σε μια οθόνη- ένα επίτευγμα το οποίο μπορεί να οδηγήσει σε τριπλασιασμό των αναλύσεων οθόνης σε οθόνες LCD, σχεδόν «εν μία νυκτί».
Οι ερευνητές παρουσίασαν τις τεχνικές λεπτομέρειες της μεθόδου αυτής σε μια νέα έρευνα, η οποία δημοσιεύτηκε στο Nature. Όπως επεξηγείται σε δημοσίευμα του Gizmodo, αυτό που έκαναν ήταν να βρουν μια μέθοδο ελέγχου subpixels μέσω τάσης.
Κάθε pixel σε μια οθόνη LCD περιλαμβάνει τρία subpixels. Το καθένα από αυτά ελέγχει ένα από τρία χρώματα: Κόκκινο, πράσινο ή μπλε. Ένα λευκό φως λάμπει πίσω από το pixel και το διάφραγμα της LCS ελέγχει ποια subpixels είανι ορατά- για παράδειγμα, εάν το pixel θα έπρεπε να είναι μπλε, το διάφραγμα καλύπτει το κόκκινο και το πράσινο subpixel. Για τη δημιουργία του μωβ, το διάφραγμα χρειάζεται να καλύψει μόνο το πράσινο subpixel, ενώ το λευκό φως καθορίζει το πόσο φωτεινό ή σκοτεινό θα είναι ένα χρώμα.
Η ομάδα των ερευνητών του NanoScience Technology Center του UCF επέδειξε έναν τρόπο χρήσης μιας ανάγλυφης επιφάνειας νανοδομής και αντανακλαστικού αλουμινίου που θα μπορούσε να αλλάξει δραστικά τα δεδομένα σε αυτόν τον τομέα. Σε μια συσκευή δοκιμών, οι ερευνητές ήταν σε θέση να ελέγξουν το χρώμα του κάθε subpixel μεμονωμένα: Αντί ένα subpixel να είναι «αφιερωμένο» στο μπλε, μπορεί να παράξει το πλήρες εύρος χρώματος που η τηλεόραση είναι ικανή να προβάλει. Με το κάθε subpixel να μπορεί να κάνει τη δουλειά τριών, η δυνατή ανάλυση της συσκευής τριπλασιάζεται- ενώ επιπρόσθετα κάθε subpixel έχει τη δυνατότητα να είναι «ενεργό», είτε προβάλλει κάποιο χρώμα είτε απλά λευκό- κάτι που θα μπορούσε να οδηγήσει σε κατά πολύ φωτεινότερες οθόνες.
Το επόμενο βήμα για τους ερευνητές θα ήταν να αυξήσουν την κλίμακα των πειραμάτων τους, ώστε να διαπιστωθεί κατά πόσον είναι δυνατή η χρήση αυτής της τεχνολογίας με τις σημερινές συσκευές, αναβαθμίζοντας την τεχνολογία LCD που υπάρχει εδώ και δεκαετίες.
Ολόκληρη η έρευνα δημοσιευμένη στο https://www.nature.com/articles/ncomms15209
xavito
29 October 2008
8,989
[flatpanelshd.com]...R&D in LCD tv panel tech has essentially stopped, says supplier
https://www.flatpanelshd.com/news.php?subaction=showfull&id=1686823020
Η έρευνα & ανάπτυξη στην τεχνολογία πάνελ τηλεοράσεων LCD ουσιαστικά έχει σταματήσει, λέει ο προμηθευτής.
The LCD monster has stopped evolving, notes longtime industry observer Bob Raikes, as Merck has confirmed that they no longer have any major R&D projects earmarked for LCD TV panels.
LCD TVs have for years been built on either VA or IPS panel types with very little development in the core – the liquid crystals.
Improvements to picture quality and performance in "QLED" and "miniLED" LCD TVs in recent years can instead be ascribed to other components such as the LED backlight. These are expected to continue to evolve for some time still.
Merck, which is the dominant supplier of liquid crystal (LC) materials for use in LCD panels, has confirmed that it no longer has any major R&D projects in the area.
The LCD monster​
The most recent development in LCD panel technology came with a refinement of IPS known as IPS Black, developed by Merck for LG Display and BOE.
The statement from Merck is not surprising considering that leading display manufacturers such as LG Display and Samsung Display already have, or are very close to having, abandoned production of LCD panels, leaving the Chinese to it who are also increasingly turning their attention to OLED in the near term and more exotic display technologies in the long term.
Bob Raikes likes to refer to it as "the LCD monster" as LCD has over the years completely eradicated cathode-ray tube (CRT), plasma, and even prospective display technologies such as SED.
LCD has had an amazing run but with OLED, QD-OLED, direct-view LED and other promising display technologies there is reason to be even more excited about the future of displays.
Το τέρας LCD έχει σταματήσει να εξελίσσεται, σημειώνει ο μακροχρόνιος παρατηρητής της βιομηχανίας Bob Raikes, καθώς η Merck επιβεβαίωσε ότι δεν έχουν πλέον κανένα σημαντικό έργο έρευνας και ανάπτυξης που προορίζεται για πάνελ τηλεοράσεων LCD.
Οι τηλεοράσεις LCD έχουν κατασκευαστεί εδώ και χρόνια σε τύπους πάνελ VA ή IPS με πολύ μικρή ανάπτυξη στον πυρήνα - τους υγρούς κρυστάλλους.
Οι βελτιώσεις στην ποιότητα και την απόδοση της εικόνας στις τηλεοράσεις LCD "QLED" και "miniLED" τα τελευταία χρόνια μπορούν να αποδοθούν σε άλλα εξαρτήματα όπως ο οπίσθιος φωτισμός LED.
Αυτά αναμένεται να συνεχίσουν να εξελίσσονται για αρκετό καιρό ακόμα.
Η Merck, η οποία είναι ο κυρίαρχος προμηθευτής υλικών υγρών κρυστάλλων (LC) για χρήση σε πάνελ LCD, επιβεβαίωσε ότι δεν διαθέτει πλέον μεγάλα έργα έρευνας και ανάπτυξης στον τομέα.
Το τέρας της LCDΗ πιο πρόσφατη εξέλιξη στην τεχνολογία πάνελ LCD ήρθε με μια τελειοποίηση του IPS, γνωστής ως IPS Black, που αναπτύχθηκε από τη Merck για LG Display και BOE.
Η δήλωση της Merck δεν προκαλεί έκπληξη, δεδομένου ότι κορυφαίοι κατασκευαστές οθονών όπως η LG Display και η Samsung Display έχουν ήδη ή είναι πολύ κοντά στο να έχουν εγκαταλείψει την παραγωγή οθονών LCD, αφήνοντας σε αυτήν τους Κινέζους που επίσης στρέφουν όλο και περισσότερο την προσοχή τους στην OLED στο βραχυπρόθεσμα και πιο εξωτικές τεχνολογίες προβολής μακροπρόθεσμα.
Ο Bob Raikes αρέσκεται να το αναφέρει ως "το τέρας της LCD", καθώς η LCD έχει με τα χρόνια εξαλείψει εντελώς τον σωλήνα καθοδικών ακτίνων (CRT), το πλάσμα, ακόμη και τις μελλοντικές τεχνολογίες οθόνης όπως το SED.
Η οθόνη LCD είχε εκπληκτική απόδοση, αλλά με τις WRGB WOLED,RGB QD-OLED, LED άμεσης προβολής και άλλες πολλά υποσχόμενες τεχνολογίες οθόνης, υπάρχει λόγος να είμαστε ακόμα πιο ενθουσιασμένοι για το μέλλον των οθονών.
-[displaydaily.com]...The LCD monster has stopped evolving.
https://displaydaily.com/the-lcd-monster-has-stopped-evolving/
