This is the full GH6 spec sheet:
Lens mount Micro Four Thirds mount Image Sensor Type Live MOS sensor (17.3 x 13.0 mm) Camera effective pixels / Total pixels 25.21 megapixels / 26.52 megapixels AR (Anti Reflection) coating Yes Aspect ratio / Color filter 4:3 / Primary color filter Dust reduction system Image sensor shift type Latitude Dynamic Range Boost ON: 13+ stops (V-Log) Dynamic Range Boost OFF: 12+ stops (V-Log) Still Image Recording file format JPEG (DCF, Exif 2.31), RAW Aspect ratio 4:3 / 3:2 / 16:9 / 1:1 File size (Pixels) 4:3: 5776x4336(L) / 4096x3072(M) / 2944x2208(S) / 11552x8672(XL) / 8192x6144(LL) 3:2: 5776x3848(L) / 4096x2728(M) / 2944x1960(S) / 11552x7696(XL) / 8192x5464(LL) 16:9: 5776x3248(L) / 4096x2304(M) / 2944x1656(S) / 11552x6496(XL) / 8192x4608(LL) 1:1: 4336x4336(L) / 3072x3072(M) / 2208x2208(S) / 8672x8672(XL) / 6144x6144(LL) Image quality RAW / RAW+Fine / RAW+Standard / Fine / Standard Color space sRGB, AdobeRGB Motion Picture Recording file format MOV: H.264/MPEG-4 AVC, H.265/HEVC, Apple ProRes MP4: H.264/MPEG-4 AVC, H.265/HEVC Audio format MOV: LPCM (2ch 48kHz/24-bit, 96kHz/24-bit) (4ch 48kHz/24-bit, 96kHz/24-bit) MP4: AAC (2ch 48kHz/16-bit) System frequency 59.94Hz / 50.00Hz / 24.00Hz Image area of video Full / Pixel by Pixel
Viewfinder Type OLED Live View Finder Pixels Approx. 3.68 million dotsField of view / Magnification Approx. 100% / Approx. 1.52x / 0.76x (35mm camera equivalent) with 50 mm lens at infinity; -1.0 m-1, when the aspect ratio is set to 4:3 Eye point / Diopter adjustment Approx. 21 mm at infinity; -1.0 m-1 / -4.0 - +3.0 (dpt) Eye sensor Yes Rear Monitor Type TFT LCD monitor with static touch control Monitor size Tilt free-angle, 3.0-inch, 3:2 aspect Pixels Approx. 1.84 million dots Field of view Approx. 100% Focus Type Contrast AF system DFD technology Yes Focus mode AFS (Single) / AFC (Continuous) / MF AF mode Tracking / Full Area AF / Zone (Horizontal/Vertical) / Zone / 1-Area+ / 1-Area / Pinpoint AF detective range EV -4 - 18 (F2.0, ISO100 equivalent, AFS) AF custom setting AF Sensitivity, AF Area Switching Sensitivity, Moving Object Prediction AF assist light Yes AF lock Set the Fn button in custom menu to AF lock Focus ring control Nonlinear / Linear (90 Degree / 120 Degree / 150 Degree / 180 Degree / 210 Degree / 240 Degree / 270 Degree / 300 Degree / 330 Degree / 360 Degree / 720 Degree / 1080 Degree / Maximum) Others AF-ON, AF-ON: Near Shift, AF-ON: Far Shift, Focus Limiter, Focus Peaking, 1-Area AF Moving Speed, Continuous AF (during motion picture recording), Focus/Shutter Priority, Focus Switching for Vert/Hor, AF/AE Lock Hold, AF+MF, MF Assist, MF Guide, Focus Ring Lock, Show/Hide AF Mode, Shutter AF, Half Press Shutter, Quick AF, Eye Sensor AF, Loop Focus Frame, Enlarged Live Display (Video), Touch Shutter, Touch AF/AE Function, Touch Pad AF, Lens Focus Resume
Light metering system 1,728-zone multi-pattern sensing system Light metering mode Multiple / Center Weighted / Spot / Highlight Weighted Metering range EV0-18 (F2.0 lens, ISO100 equivalent) Mode dial Program AE (P) / Aperture Priority AE (A) / Shutter Priority AE (S) / Manual Exposure (M) / Creative Video (P/A/S/M) / Custom 1, 2, 3, 4 / Intelligent Auto Exposure compensation 1/3 EV step +/-5EV ( +/-3EV for motion picture) Dynamic Range Boost ON / OFF ISO sensitivity Still image: [Normal]: Auto / 50 (Extended ISO) / 100-25600 [V-Log]: Auto / 125 (Extended ISO) / 250-12800 Motion picture: [Normal]: Dynamic Range Boost OFF (Base ISO 100): Auto / 50 (Extended ISO) / 100-12800 Dynamic Range Boost ON (Creative Video Mode) (Base ISO 800): Auto / 800-12800 [V-Log]: Dynamic Range Boost OFF (Base ISO 250): Auto / 125 (Extended ISO) / 250-12800 Dynamic Range Boost ON (Creative Video Mode) (Base ISO 2000): Auto / 2000-12800 [Hybrid Log Gamma]: Dynamic Range Boost OFF (Base ISO 250): Auto / 250-12800 Dynamic Range Boost ON (Creative Video Mode) (Base ISO 2000): Auto / 2000-12800 (Standard output sensitivity) AE lock Set the Fn button in custom menu to AE lock Image Stabilization System B.I.S. (5-axis / 7.5-stop) Dual I.S. 2 (7.5-stop) White balance AWB / AWBc / AWBw / Daylight / Cloudy / Shade / Incandescent / Flash / White Set 1, 2, 3, 4 / Color temperature setting 1, 2, 3, 4
White balance adjustment Blue/Amber bias, Magenta/Green bias Color temperature setting 2500-10000K in 100K Type Focal-plane shutter Shutter speed Still image: Bulb (Max. 30 minutes), 1/8,000 - 60 Electronic front curtain shutter: Bulb (Max. 30 minutes), 1/2,000 - 60 Electronic shutter: Bulb (Max. 60 sec), 1/32,000 - 60 Motion picture: 1/25,000 - 1/25 Creative Video M mode / MF mode: 1/25,000 - 1/8 Self timer 10sec, 3 images / 2sec / 10sec / Custom Time Remote control Remote control by DMW-RS2 Silent mode / Shutter type Yes / Yes (Auto / Mechanical / Electronic front curtain / Electronic / Electronic+NR) AE bracket 3, 5, 7 images in 1/3, 2/3 or 1 EV step, max. +/-3 EV, single/burst Aperture bracket 3, 5 or all positions Focus bracket 1 to 999 images, focus steps can be set in 10 levels White balance bracket 3 images in blue/amber axis or in magenta/green axis, color temperature setting Burst speed Mechanical shutter / Electronic front curtain shutter H: 14 frames/sec (AFS/MF), 8 frames/sec (AFC) (with Live View) M: 6 frames/sec (AFS/MF) (with Live View), 5 frames/sec (AFC) (with Live View) L: 2 frames/sec (AFS/MF/AFC) (with Live View) Electronic shutter SH75: 75 frames/sec (AFS/MF) SH60: 60 frames/sec (AFS/MF) SH20: 20 frames/sec (AFS/MF) H: 14 frames/sec (AFS/MF), 7 frames/sec (AFC) (with Live View) M: 6 frames/sec (AFS/MF) (with Live View), 5 frames/sec (AFC) (with Live View) L: 2 frames/sec (AFS/MF/AFC) (with Live View) Number of recordable images H/M/L RAW+JPEG: More than 40 images RAW: More than 65 images, More than 50 images JPEG: More than 95 images, More than 90 images SH RAW / RAW+JPEG / JPEG: 200 images
Time Lapse Shot Yes Stop Motion Animation Yes Flash type TTL External Flash Flash mode Auto / Auto/Red-eye Reduction / Forced On / Forced On/Red-eye Reduction / Slow Sync. / Slow Sync./Red-eye Reduction / Forced Off Flash synchronization 1st Curtain Sync, 2nd Curtain Sync. Flash output adjustment 1/3EV step +/-3EV Synchronization speed Less than 1/250 second Wireless control Yes (When using DMW-FL200L / FL360L / FL580L), Wireless Channel: 1ch/2ch/3ch/4ch Flash sync socket Yes Extra Tele Conversion 2.0x (EX S), 1.4x (EX M) Photo Style Standard / Vivid / Natural / L. Classic Neo / Flat / Landscape / Portrait / Monochrome / L. Monochrome / L. Monochrome D / L. Monochrome S / Cinelike D2 / Cinelike V2 / Like709 / V-Log / Hybrid Log Gamma / My Photo Style 1-10 Picture adjustment Contrast / Highlight / Shadow / Saturation / Color Tone / Hue / Filter Effect / Grain Effect / Color Noise / Sharpness / Noise Reduction / ISO / WB Filter Expressive / Retro / Old Days / High Key / Low Key / Sepia / Cross Process / Bleach Bypass Master pedestal level 31 steps Luminance level 8-bit: 0-255 / 16-235 / 16-255 10-bit: 0f'1023 / 64f'940 / 64f'1023 Wave form monitor / Vectorscope Selectable LUT view assist Supported file types: .vlt, .cube Monitor / HDMI HLG view assist Monitor (MODE1 / MODE2 / OFF) / HDMI (AUTO / MODE1 / MODE2 / OFF)
Anamorphic desqueeze display 2.0x / 1.8x / 1.5x / 1.33x / 1.30x / OFF Synchro scan Yes SS/Gain operation Shutter Duration/ISO / Angle/ISO / Shutter Duration/dB Color bars / 1kHz test tone Yes (SMPTE / EBU / ARIB) / Yes Knee control Yes (in Like709 mode) Red REC frame indicator ON / OFF Vertical Position Information Still image / Motion picture (ON/OFF) Level Gauge Yes Print PictBridge compatible USB USB Type-C (SuperSpeed USB 10Gbps (USB 3.2 Gen2)) HDMI HDMI TypeA Audio: ON / OFF, MP4: 2ch, MOV: 2ch (When [4ch Mic Input] is set to OFF.), 4ch (When [4ch Mic Input] is set to ON.) Monitor-through 4:2:2 10bit (When [Rec Quality] is set to [4:2:2 10bit] or [4:2:0 10bit].) 4:2:2 8bit (When [Rec Quality] is set to [4:2:0 8bit].) Down Convert: Auto / C4K/4K / 1080p / 1080i / OFF Remote input 2.5mm (Dia.) Build-in microphone Stereo External microphone/audio device input 3.5mm for external microphone / external audio device (Dia.) MIC (Plug-in Power) / MIC / LINE Wind Cut: OFF / Low / Standard / High Special Mic: Stereo / Shotgun XLR microphone Yes with DMW-XLR1 4ch mic input Yes with DMW-XLR1
Speaker Monaural Headphone output 3.5mm (Dia.) Card slot Slot 1: CFexpress Card (CFexpress Type B) Slot 2: SD Memory Card / SDHC Memory Card / SDXC Memory Card TC In/Out Yes with BNC Converter Cable (bundled) Count up Rec Run / Free Run Time code mode Drop Frame / Non-Drop Frame (When system frequency [59.94Hz] is selected.) HDMI time code output ON / OFF External TC setting TC Synchronization / TC Output Reference Fan Auto1 / Auto2 / Fast / Normal / Slow / OFF Lamp Tally Lamp (front/rear) / Card Access Light / Power Indicator / Charging Light/Network Connection Light Wi-Fi 2.4GHz (STA/AP) (IEEE802.11b/g/n) 5GHz (STA) (IEEE 802.11a/n/ac) Security: WPA/WPA2/WPA3 Bluetooth Bluetooth v5.0 (Bluetooth Low Energy (BLE)) Dust and Splash Resistant Yes Battery life (CIPA standard) When using CFexpress Card: Approx. 330 images, 750 images (Power Save LVF mode) with H-ES12060 / DMW-BLK22 Approx. 350 images, 800 images (Power Save LVF mode) with H-FS12060 / DMW-BLK22 When using SD memory card: Approx. 360 images, 850 images (Power Save LVF mode) with H-ES12060 / DMW-BLK22 Approx. 380 images, 900 images (Power Save LVF mode) with H-FS12060 / DMW-BLK22 Continuous recordable time When using CFexpress Card: MP4 [4K/60p]: Approx. 80 min with H-ES12060 / H-FS12060 MP4 [FHD/60p]: Approx. 90 min with H-ES12060 / H-FS12060
When using SD memory card: MP4 [4K/60p]: Approx. 90 min with H-ES12060 / H-FS12060 MP4 [FHD/60p]: Approx. 100 min with H-ES12060 / H-FS12060 (Motion picture) Actual recordable time (Motion picture) When using CFexpress Card: MP4 [4K/60p]: Approx. 40 min with H-ES12060 / H-FS12060 MP4 [FHD/60p]: Approx. 45 min with H-ES12060 / H-FS12060 When using SD memory card: MP4 [4K/60p]: Approx. 45 min with H-ES12060 / H-FS12060 MP4 [FHD/60p]: Approx. 50 min with H-ES12060 / H-FS12060 Operating temperature -10 Degree C to 40 Degree C Operating humidity
10%RH to 80¼RH Battery Info Optional, included Battery Material Lithium ion Battery Type non-universal Battery Quantity 1 Dimensions (W x H x D) 138.4 x 100.3 x 99.6mm (excluding protrusions) Weight 823g (SD Memory Card x 1, Battery, Body), 739g (Body only)
