The "Cost No Object" Series, Pt. III: Berkeley Audio Alpha Dac
Gojakla
20 May 2009
5,856
Alpha DAC Reference Series
Official Site
1409254620496
1408744183764
We could, like many other manufacturers, convert 1-bit DSD to multi-bit within the Alpha DAC Reference Series and show "€DSD"€
in the front panel display. That would be the easiest approach from a marketing standpoint and would also be very simple and low in cost to implement.
But that approach would also mean increasing the amount of processing in the DAC during playback which would degrade audio quality,
and audio quality is the reason the Alpha DAC Reference Series exists.
Fortunately, virtually all reproduction of DSD files using external DAC’s is with a computer based music server as the source.
If 1-bit DSD to multi-bit conversion is done first in the computer it can be performed with extremely high precision and superior filtering that preserves
all of the content of the DSD file. Computer DSD to multi-bit conversion can be at least as good as that performed in a DAC and without adding
processing noise near or in the D/A converter chip. Also, conversion of DSD to 176.4 kHz, 24 bit AIFF or WAV files can be done ahead of time resulting
in no conversion processing occurring during playback. Another advantage of computer based DSD to PCM conversion is that if higher performance DSD versions
such as DSD 4X appear in the future, they can be easily supported with a software upgrade.
For all of these reasons, DSD capability for the Alpha DAC Reference Series is provided by a state of the art software application, JRiver Media Center,
that provides either real time conversion of DSD 1x and DSD 2x to 176.4 kHz, 24 bit PCM during playback or, for the best possible audio fidelity,
easy conversion to 176.4 kHz, 24 bit AIFF or WAV files prior to playback. The JRiver Media Center software application is included in the price of the
Alpha DAC Reference Series and either Windows OS or Mac OS versions are available.
Specifications
Input sampling rate: 32kHz to 192kHz
Input word length: 24-bit
Ultra low phase noise Precision Clocking at 44.1kHz, 48kHz, 88.2kHz, 96kHz, 176.4kHz and 192kHz sampling rates ± 100 ppm
Two channel analog stereo outputs: XLR balanced with pin 2 positive and RCA unbalanced
Digital Inputs: AES - XLR, 110Ω; SPDIF1 - BNC, 75Ω; SPDIF2 - BNC, 75Ω; TOSLINK - Toslink optical connector
HDCD decoding detects 16-bit flag at 44.1kHz or 24-bit flag at all sampling rates
Multiple digital filter options
Balanced analog output level: +18dBu (6.15Vrms) maximum, +12dBu (3.1Vrms) or lower recommended
Unbalanced analog output level: 3.25Vrms maximum, 2Vrms or lower recommended
Digital volume & balance control: 0.1dB/step with .05dB/step L/R gain trim, 60dB range
Frequency response at β‰ 88.2kHz sampling rates: ± 0.1dB from < 0.1Hz to 35 kHz, - 3dB at 59kHz for 176.4kHz and 192kHz sampling rates
Distortion at recommended levels: all products β‰ -120dBFS
THD+N at maximum level: < -110dBFS
Firmware upgradeable through signal inputs
Enclosure dimensions: 3.5”H X 17.5”W x 12.5”D
Weight: 30 lbs.
Mains power: 100/120/240VAC, 50/60Hz
Power consumption: 25W
Reviews
The Absolute Sound / Mono & Stereo
Panoramix
31 January 2012
11,457
Δεν κάνουμε dsd γιατί η επεξεργασία χαλάει τον ήχο. Καλυτερα να το κάνετε στο πισι wav (που δε χαλάει τον ήχο) με το elite πρόγραμμα jriver που σας κάνουμε δώρο.
Ε, γελάει ο κόσμος.
Dr Pan K
18 December 2010
9,067
Σιγα τα ωά.. Τα εχω ξαναγράψει και πιο παλια, οι ιδιοι (λιγο πολυ) ειχαν βγάλει το καλύτερο ισως PCM DAC ολων των εποχών, το οποίο κανει κορδέλες το "α". Aκομα σήμερα σπέρνει, το φιλτρο του το χρησιμοποιεί ο Vincent στο Total DAC ενω η Magico στα show κατεβαίνει σχεδόν αποκλειστικά με αυτο οταν θα μπορούσε να εχει όποιο σύγχρονο θελει. Το hardware ειχε κόστος 15Κ...
http://www.goodwinshighend.com/manufacturers/pacific_microsonics/pacific_microsonics_model_two.htm
DomieMic65
10 July 2006
9,692
Ο άλλος στο CA όμως το θεωρεί από τα καλύτερα ντακ κοστ νο ομπτζεκτ....
Από αυτά που διαβάζω με έχει πείσει πως εδώ κάτι γίνεται!! Δεδομένου πως αυτοι που είναι από πίσω έχουν παρελθόν στον χώρο
Επίσης βγάζουν έναν από τους πιο καλούς usb-spdif κονβέρτορες (από άποψη δεν έχουν usb ενσωματωμένη στον DAC από όσο θυμάμαι)
Ανθρακες ο θησαυρός Παναγιώτη;
sokmav
5 February 2012
14,227
Υπάρχει τόση φιλολογία για την συγκεκριμένη μετατροπή που είναι να χάνεται κανείς.
Υπάρχουν τα τσιπάκια που μετατρέπουν το DSD σε PCM εσωτερικά (και δεν μας το λένε)
Υπάρχουν τα τσιπάκια που μετατρέπουν το DSD σε PCM εσωτερικά (και μας το λένε)
Υπάρχουν τα τσιπάκια που δεν μετατρέπουν το DSD σε PCM εσωτερικά αλλά σου λένε κάντο στον υπολογιστή (όπως καλή ώρα)
Υπάρχουν κι αυτά που παίζουν χωρίς να μετατρέπουν.
Κι υπάρχουν κι αυτά που παίζουν DSD χωρίς καν τσιπάκι (με ένα φίλτρο στην έξοδο μόνο).
Βγάλε άκρη...
FragoulisNaval
4 November 2009
7,820
Δίπλα στον Pseiras.....
Κάπου είχε πάρει το μάτι μου ένα paper απο την playback designs οτι ένα sac παίζει καλά DSD μόνο αν έχει σχεδιαστεί εξαρχής για DSD. Διαφορετικά, PCM και ξερό ψωμί.
Dr Pan K
18 December 2010
9,067
Απο τα καλυτερα θα ελεγα ναι, σε τελικη αναλυση ποσα ντακ κοστιζουν πανω απο 15Κ $ ?
MSB
dCS
LH
Orpheus
Esoteric
Berkeley
EMM Meitner
Trinity
Total, Playback, Rockna κτλ βγάζουν ακριβα αλλα οχι τοσο, καποιοι παραδοσιακοί high end κατασκευαστές (Gryphon, Nagra, Boulder, CH, Constelation κτλ) εχουν πολύ ακριβα μοντελα αλλα δεν ειναι καθεαυτό ντακαδες. Θα ξεχναω και κανα δυο αλλα στο τελος το να πεις οτι το ταδε ντακιδιο των 15Κ ειναι απο τα καλυτερα δεν λεει και πολλα. Οφειλει να ειναι αν επαγγελματίες το εχουν κοστολογήσει εκεί. Σε σχεση με τα αλλα της κατηγοριας τι κανει?
Κανε μια έστω και οπτικη σύγκριση ανάμεσα στο PM2 και το "α"..
Sonus Naturalis
12 July 2009
9,103
Αθήνα, Ηλιούπολη
Μπαα δεν παίζει 768 δεν είναι καλό... Χε χε
Άμα μου βρείτε μία ηχογράφηση που να έχει γραφτεί σε ...768 KHz/24 Bits Native, ακόμα και πειραματική, σας κάνω το τραπέζι, όπου θέλετε!
Εδώ που τα λέμε δε γνωρίζω να υπάρχουν κάν A/D Converters, να γράφουν πάνω από 192/24, ή μάλλον υπάρχουν και δεν πρέπει να είναι περισσότεροι από δύο-τρείς!
Κι' αυτοί είναι προϊόν των δύο τελευταίων χρόνων, όχι παραπάνω! :cool:
Dr Pan K
18 December 2010
9,067
Η πιο διαδεδομένη και σοβαρή λυση ειναι αυτη της Merging, το σύστημα Pyramix με το σχετικό hardware (και κορυφαίους ADC με Ελβετικό "πυρίτιο" της Arda).
DomieMic65
10 July 2006
9,692
και έχουμε υλικό από αυτό το ADCακι;; :):)
DomieMic65
10 July 2006
9,692
Ε δώσε κανένα στοιχείο παραπάνω βρε παιδάκι μου... Με το τσιγκέλι στα βγάζουμε... Εδώ ο άλλος σου ετοιμάζει κέρασμα..
