Yamaha 2011 A/V Receivers
kblachos
18 February 2009
17,132
ΑΓΙΟΙ ΑΝΑΡΓΥΡΟΙ
Νέοι ενισχυτές για το 2011 και για την Yamaha. Τα νέα μοντέλα RX-V έχουν την κατάληξη -71. Αρχικά κυκλοφορούν οι RX-V371, 471, 571 και 671.
YAMAHA RX-V371
5-channel powerful Surround sound (105W per Channel)
HD Audio Format decoding: Dolby TrueHD and DTS-HD Master Audio; Dolby Digital Plus and DTS-HD High Resolution Audio
Burr Brown 192 kHz/24-bit DACs for all channels
Direct Mode for high quality sound reproduction
Low jitter PLL circuitry helps optimize sound imaging
Auto power down function with variable time setting
Low Standby Power Consumption
Inputs: 4 HDMI, 1 USB, 2 Radio Antenna, 1 Dock Terminal, 2 Optical Digital, 2 Coaxial Digital, 4 Analog Audio, 2 Component Video, 5 Composite Video, Audio Mini Jack
Outputs: 1 HDMI, 1 Analog Audio, 1 Component Video, 1 Composite AV, 5ch Speaker, 1 Subwoofer, 1 Headphone Jack
Dimensions (W x H x D): 17-1/9 x 6 x 14-5/16 in.
Weight: 19.1 lbs
YAMAHA RX-V471
Auto power down function with variable time setting\
Weight: 19.1 lbs.
http://www.hd-motion.com/2011/03/17/yamaha-amplis-gamme-2011-rx-v371-rx-v471-rx-v571-rx-v671/
kblachos
18 February 2009
17,132
ΑΓΙΟΙ ΑΝΑΡΓΥΡΟΙ
Re: YAMAHA 2011 A/V RECEIVERS
YAMAHA RX-V571
7-channel powerful Surround sound (105W per Channel)
Assignable amplifiers for bi-amp connection
Inputs: 6 HDMI, 1 USB, 2 Radio Antenna, 1 Dock Terminal, 2 Optical Digital, 2 Coaxial Digital, 4 Analog Audio, 2 Component Video, 5 Composite Video, Audio Mini Jack
Outputs: 1 HDMI, 1 Analog Audio, 1 Component Video, 1 Composite AV, 7ch Speaker, 1 Subwoofer, 1 Headphone Jack
Dimensions (W x H x D): 17-1/9 x 6 x 14-1/4 in.
Weight: 19.3 lbs.
YAMAHA RX-V671
7-channel powerful Surround sound (125W per Channel)
Discrete amp configuration
Pure Direct for high quality audio playback
Inputs: 6 HDMI, 1 Network, 1 SIRIUS, 1 USB, 2 Radio Antenna, 1 Dock Terminal, 2 Optical Digital, 2 Coaxial Digital, 5 Analog Audio, 2 Component Video, 5 Composite Video, Audio Mini Jack
Outputs: 1 HDMI, 1 Analog Audio, 1 Analog AV, 1 Component Video, 1 Composite AV, 7ch Speaker, 2 Zone 2 Speaker, 1 Subwoofer, 1 Headphone Jack
Dimensions (W x H x D): 17-1/8 x 6-3/8 x 14-1/4 in.
Weight: 23.1 lbs.
JIMBOAthens
4 February 2008
222
Aνακοινώθηκαν αλλά πότε θα κυκλοφορήσουν?
thankin
17 April 2009
5,923
thessaloniki
παντως δεν καταλαβαινω αυτη την εμμονη των εταιρειων να βγαζουν καθε χρονο νεες σειρες με τοσο λιγες διαφορες σε σχεση με την προηγουμενη χρονια
THEOJJ
3 September 2008
376
Χαλάστρα
(Front panel USB Digital Connection for iPod and iPhone)
Η ποιο συμαντικη διαφορα απ'οτι βλεπω,ο ανταγωνισμος εκανε τη γιαμι να υποκυψει.
Οσο για τις ψιλοδιαφορες και τα συνεχομενα νεα μοντελα..κατι πρεπει να κανουν να αφυπνισουν την αγορα.
JIMBOAthens
4 February 2008
222
Λέτε να κυκλοφορήσουν Ελλάδα τέλη Απριλίου?
thankin
17 April 2009
5,923
thessaloniki
o πρωτος που θα κυκλοφορησει ειναι ο 371 , εξω σε καποια μαγαζια ηδη κυκλοφορει, οι 471 και 571 αρχες Μαη παλι εξω. Οποτε εδω πιστευω ο μικρος να κυκλοφορησει κατα τον Ιουνιο οι αλλοι μετα τον Ιουλιο
tasanto
31 August 2006
1,720
Athens
ενω στην εταιρεια σιγουρα θα εχει αρχισει ο σχεδιασμος της σειρας rx-vx72....
thankin
17 April 2009
5,923
thessaloniki
καλα αυτο ειναι εκ των ουκ ανευ ετσι κι αλλιως τα τρικακια των αναβαθμισεων ειναι τοσο μικρα και οι αλλαγες τοσο μικρες που δεν χρειαζεται και πολυ φαντασια....
lykman
29 June 2006
5,798
Aθήνα
Απάντηση: YAMAHA 2011 A/V RECEIVERS
ξεκίνησαν τα listings στους *71 ενισχυτές, και άρχισε και το σκώτωμα στους *67... Βλέπω στο technickdirect τον 767 με 482 και πάω να σκάσω...
garfield
5 August 2006
437
ΛΑΡΙΣΑ
απο τους νεους την παρασταση φαινεται να κλεβει ο αντικαταστατης του 767, δηλαδη ο 771 αφου σε διαταξη 7,2 εχει πλεον και θυρα εθερνετ ,κατι που ελειπε απο τον προκατοχο του...
Yamaha RX-V771 replaces RX-V767 and is an advanced 7.2 channel networked AV Receiver with 6 in/2 out HDMI (3D and ARC compatibility), iPhone app compatibility, USB connection, HD Audio decoding with CINEMA DSP 3D, YPAO Multipoint functionality, and 1080p upscaling. It decodes the latest sound modes including Dolby TrueHD, Dolby Digital Plus, DTS-HD Master Audio and High Resolution Audio formats for amazing sounding Blu Ray soundtracks, in addition to standard Dolby Digital and DTS sound modes for DVD.
Set-up is easy thanks to Yamaha's YPAO automatic sound optimisation. This involves placing an included microphone in several places around the room as instructed and it will set the level of each channel perfectly. You'll be enjoying stunning sounding home cinema soundtracks in no time.
In addition to HD sound modes, compatibility with Yamaha iPod/iPhone docks, Bluetooth compatibility, 7.2 channels, 6 HDMI inputs, 3D DSP sound modes, an advanced on-screen GUI display, "Dialogue Lift" (a handy feature if you're using front and center speakers below the screen that "lifts" part of the sound so you hear the dialogue more clearly), the RX-V771 adds many new features over the outgoing RX-V767.
Key Features
- 7-channel 160W/ch (max); 7 channel 665W (95W x 7, RMS)
- Discrete amp configuration
- Access to Internet Radio, Streaming Service and music files on PC
- AV Controller app for operating various functions from an iPhone, etc.
- Front panel USB Digital Connection for iPod and iPhone
- Advanced multi-language GUI on-screen display with album art
- 1080p-compatible HDMI: 6 in (1 front), 2 out (simultaneous), 3D and Audio Return Channel
- HDMI front panel input for devices such as camcorders and digital cameras
- HDMI CEC with versatile control from AV Receiver remote control
- YPAO sound optimisation with multi-point measurement
- HD Audio decoding with CINEMA DSP 3D (17 DSP programmes)
- Versatile Zone control with Party mode
Full Specifications
- Channel: 7.2
- CINEMA DSP: Yes (3D)
- DSP Programs: 17
- Compressed Music Enhancer: Yes
- Virtual Presence Speaker: Yes
- Dialogue Lift: Yes
- SILENT CINEMA / Virtual CINEMA DSP: Yes
- Dolby TrueHD: Yes
- Dolby Digital Plus: Yes
- Dolby Pro Logic IIx: Yes
- DTS-HD Master Audio: Yes
- Pure Direct: Yes (with video on mode)
- YPAO sound optimization: Yes
- YPAO multi-point measurement: Yes
- Adaptive DRC (Dynamic Range Control): Yes
- Initial Volume & Maximum Volume Setting: Yes
- Bi-amp capability: Yes
- Audio Delay: Yes (0-250 ms)
- 192kHz/24-bit DACs for all channels: Yes (Burr-Brown)
- HDMI 3D passthrough: Yes
- HDMI Audio Return Channel: Yes
- Component upconversion: Yes
- HDMI upscaling: Yes (Analog to HDMI / HDMI to HDMI)
- Deep Color/x.v.Color/24Hz Refresh Rate /Auto Lip-Sync: Yes
- HDMI Input/Output: 6 (front 1) / 2 (Simultaneous)
- HDMI CEC: Yes (SCENE, Device Control)
- USB Input: iPod/iPhone, USB Memory, Portable Audio Player
- Network Port: Napster / vTuner Internet Radio
- Dock Port: 1 (YDS-12, YID-W10, YBA-10)
- Front AV Input: HDMI/USB/Analog Audio/Composite
- Digital Audio Input/Output: Optical: 2 / 0
- Digital Audio Input/Output: Coaxial: 2 / 0
- Analog Audio Input/Output: 6 (front 1) / 1
- Phono Input: Yes
- Component Video Input/Output: 2 / 1
- S-Video Input/Output: 1 / 0
- Composite Video Input/Output: 5 (front 1) / 1
- Preout: 7.2ch
- Headphone Output: 1
- FM/AM Tuner: Yes
- On-screen display: Graphical User Interface
- SCENE: SCENE (4 sets)
- iPhone App Control: Yes
- Web Browser Control: Yes
- Remote Control Unit: Yes (Preset, Learning)
- Zone 2 Audio Output: Line output
- Powered Zone: Zone 2
- +12V Trigger Output: 1
- Remote (IR) Input/Output: 1 / 1
- Party Mode: Yes
- Standby Power Consumption (IR only): ≤0.1W
- Auto Power Down: Yes
- Dimensions (W x H x D): 435 x 171 x 368 mm
- Weight: 11.2 kg
http://europe.yamaha.com/en/product...s-amps/rx-v771_g/?mode=model#page=1&selected=
καπου στην Αγγλια, τιμαται στις 650 λιρες (740ε δηλαδη)...
βαλτε και αλλες 40 να ερθει,και με 785ε εχετε ενα πληρεστατο ραδιοενισχυτη...
Δυστυχως για τους φιλους του αναλογικου ηχου και τους κατοχους πολλων πηγων ηχου, καθε νεο μοντελο ειναι ολο και πιο φτωχο σε αναλογικες εισοδους & εξοδους στο πισω πανελ. Αρα παμε ολοταχως σε πληρη διαχωρισμο των συστηματων ηχου & εικονας.
thankin
17 April 2009
5,923
thessaloniki
Εκτος απο αγγλια που κυκλοφορει οι 671-771 (και εχουν τσιμπημενες τιμες ), στην υπολοιπη ευρωπη για τον 671 ανανεωνουν διαρκως την διαθεσιμοτητα σε 2 βδαμαδες για τον 771 δεν δινουν καμια προβλεψη, οταν ολος ο ανταγωνισμος κυκλοφορει τα νεα μεσαια μοντελα εδω και 1 με 2 μηνες.
thankin
17 April 2009
5,923
thessaloniki
Καλα τα ζωα μου αργα για τους 671-771. Συνεχώς έχουν διαθεσιμοτητα εδω και 10-15 μέρες ότι θα κυκλοφορήσει ο 671 σε 2 βδομαδες , για δε τον 771 ουτε φωνη ουτε ακροαση. Στο μεταξυ η ονκυο εχει γεμισει ολη την ευρωπαικη αγορα με τον νεο και φθηνο 609. Εγκληματα μαρκετιγκ! Και κριμα γιατι προκειται για εξαιρετικα μηχανηματα και τα 2. Δεν μπορω να καταλαβω δεν τους ενδιαφερει ο ανταγωνισμος εκει στην yamaha? Το 70-80 % των καταναλωτων της μικρομεσαιας κατηγοριας πολυκαναλων που σκεφονταν να ψωνισουν φετος νεο το έκαναν ηδη (με λιγότερο απο 500 ευρω έρχεται στην ελλαδα ο 609!), να δουμε ποιοι θα παρουν τους νέους γιαμι στα μεσα ιουλιου που θα τους σπρώξουν στην αγορα!
gzoun
8 March 2008
1,959
Αθήνα-Μενίδι
UK pricing announced for the first of Yamaha's 2011 receivers
Yamaha has announced UK pricing for the first of its new '71 series receivers for 2011, first seen when they were launched in the States in April.....
http://www.whathifi.com/news/update-uk-pricing-announced-for-the-first-of-yamahas-2011-receivers
Τιμές skroutz(για την ώρα μόνο από το Pixmania):
http://www.skroutz.gr/s/338359/Yamaha-RX-V371.html
http://www.skroutz.gr/s/342668/Yamaha-RX-V471.html
http://www.skroutz.gr/s/343242/Yamaha-RX-V671.html
http://www.skroutz.gr/s/343238/Yamaha-RX-V771.html
vadergr
17 August 2007
27,889
Μεταμορφωση
Ετσι ειναι συνηθως οι πρωτες τιμες που ανακοινωνονται.
Θα πεσουν λογικα μετα τον πρωτο μηνα.
