Zebralight H31 review
astanapane_10
4 May 2010
1,654
Καλησπερα σας,
εδω εχουμε ενα μικρο πολυ μικρο φακο κεφαλής.
ερχετε απο μια εταιρια Zebralight που ειναι αμερικανικη.
Οι σχεδιαστες, οι μηχανικοι και ολο το προσωπικο ειναι Αμερικανοι.
Το αρνητικο, Δεν ξερω αν ειναι ή όχι αλλα το production line γινεται στην Κινα.
Μιλαμε για τον Zebralight H31. http://www.zebralight.com/H31-Headlamp-CR123-220Lm_p_25.html
Παρακατω όπως έχουν αντιγραφεί απο την κεντρικη σελιδα της εταιριας.
Description
Main Features and Specifications
LED: Cree XP-G Cool White (color temperature 6100-6500 K)
User Selectable Modes: 3 (High, Medium and Low). Each mode can be configured to one of the two sub-levels.
Light Output
High: H1 220 Lm (0.9 hrs) or H2 120 Lm (2 hrs)
Medium: M1 43 Lm (12 hrs) or M2 24 Lm (23 hrs)
Low: L1 5 Lm (3.7 days) or L2 0.5 Lm (21 days)
Light output are out the front (OTF) values. Runtime tests are done using Panasonic CR123A lithium batteries. Runtimes are usually much shorter with rechargeable RCR123 (16340) batteries, especially with protected 16340s that have higher discharge cut off voltage.
Battery: One CR123A lithium primary or RCR123 Li-ion rechargeable. Batteries are not included in the package.
Battery Shelf Life: Over 3 years under parasitic drain
Dimensions
Diameter: 0.90 inch (23 mm)
Length: 2.57 inch (65 mm)
Weight
0.97 oz (27.6 gram) without battery or headband
Features
Electronic soft-touch switch, with a 200,000 cycle operating life
Smart user interface provides fast and easy access to all brightness levels
Precision machined casing from premium grade Alcoa aluminum bar stock
Durable natural hard anodized finish (Type III Class I)
SCHOTT ultra clear lens with anti-reflection coatings on both sides
Orange peel textured reflector
Glow In The Dark (GITD) silicone ring near the tail cap
Battery power can be locked out by slightly unscrewing the tailcap to prevent unwanted activations
Waterproof to IPX8
Operations
From Off
Short click turns on the light to High (H2) instantly. Click again quickly to cycle from High to Medium, and Low.
Press and hold to cycle through Low, Medium and High, release to set.
When On
Short click turns off the light.
Press and hold to cycle from Low to High, release to set. The light always cycle from Low to High regardless which level you are currently in.
Double click at any level to toggle and select between the two sub-levels for that level. Medium and Low selections are memorized after the light is turned off and through battery changes. H1 is not memorized.
Λοιπον και τωρα αρχιζουμε την παρουσιαση.
Ο μικρος αυτος φακος ειναι λιγο μεγαλυτερος απο μια μπαταρια 123. Η κεφαλη του αποτελειτε απο ενα σχεδιασμο που προσφερει την ανεση να χωρεσουν το LED, το διακοπτης, τα ηλεκτρονικα και το συστημα ψυξης.
Αυτο που δεν μου αρεσε πολυ οπως και σε καθε Zebraligth, ειναι οτι στην εισοδο που θα μπει ο θετικος πολος της μπαταριας, τα ηλεκτρονικα ειναι εμφανη και λογικα θα εχουν μια μικρη επαφη με την μπαταρια.
Μπορει να εχουν προβλεψει για αυτο και να μην υπαρχει προβλημα θερμοκρασιας στην πλακετα που βλεπω καποια transistors εκει. (πολυ ευαισθητα θα ελεγα τα εχω δουλεψει).
Χρησημοποιει την τελευταια τεχνολογια tiny LED XP-G, και ανεβαζει την φωτεινοτητα στα 220 lumens OTF παρακαλω. Επισης ο κατασευαστης λεει οτι με τις καινουργιες μπαραριες LiFePO μπορεις να εχεις περισσοτερα OTF απο τα 220 lumens.(να το δω και να μην το πιστεψω)
Παμε τωρα στο σχεδιασμο και χειρισμο της φωτεινοτητας. Οσοι εχουν ενα φακο της zebralight θα εχουν μαθει πως να δουλευουν τα 3x2 modes που εχει.
Με βαση τις αναγκες μπορεις να περασεις απο την μια διαβαθμιση στην αλλη με ευκολο τροπο. Φυσικα μπορεις οταν ο φακος ειναι κλειστος να περασεις κατευθειαν απο τα 0.5 στα 220 lumens αναλογα τα δευτερα που θα πατησεις το διακοπτακι.
Παμε λιγο στο reflector που εχει. Ειναι 90 μοιρες texture και σε προδιαθετει θελεις και μη να τον χρησημοποιησεις για εσωτερικους, εξωτερικους χωρους για κοντινες αποστασεις. Θα μου πεις τωρα βγαζει 220lumens OTF και θα τον εχω μονο για μεσα και για κοντα; η απαντηση μου ειναι οτι θα εχεις αλλον για μακρυνες αποστασεις χεχεχεχεχε.
Απο την zebralight εχω και τον SC30 που ειναι περιπου το ιδιο μεγεθος με τον H31 απλα ο ενας ειναι flashlight και ο αλλος ειναι headligth.
learner
15 January 2010
697
Ωραια φαση. :SFGSFGSF: Αλλα παλι ξεχασες φωτο με τον φακο στο χερι χεχε
astanapane_10
4 May 2010
1,654
χαχαχα,
ελα ρε εχω βαλει εναν κανονα διπλα για να μπορειτε να δειτε το μεγεθος. Εχω βαλει και μια μπαταρια 18650.
Στο χερι χανετε πραγματικα ειναι πολυ μικρος.:hmmmm:
learner
15 January 2010
697
Ποιο ωραια ειναι να βλεπουμε πως καθεται στο χερι. χχεχε Βασικα δεν εχω δει απο κοντα 18650 για να καταλαβω και πολλα.
Ο SC30 φαινεται αρκετα πιο μεγαλος.
Περιμενουμε και καμια φωτο απο το απεναντι ντουβαρι του μπαλκονιου σου χεχε
Ετσι που τον κοβω πρεπει να εχει και μικρο βαθος reflector.
astanapane_10
4 May 2010
1,654
ο sc30 δεν ειναι μεγαλος απλα ετσι φαινεται στην φωτο. θα ανεβασω αυριο βραδυ φωτογραφιες. Reflector εχει μικρο και οχι πολυ βαθυ. Ειναι ομως πολυ καλος οπως ειπα για μικρες αποστασεις.
ergotelis
6 January 2010
2,018
Ηράκλειο Κρήτης
Ήθελα να παραγγείλω και εγώ τον Η31 αλλά τον έχουν κάμποσο καιρό οut of stock...
Είδα σήμερα στο dx φρέσκο φρέσκο αυτό
http://www.dealextreme.com/details.dx/sku.39671
Το παρήγγειλα!
Χαχα θα κάνουμε γέλια μου φαίνεται, ελπίζω να πλησιάζει έστω και λίγο τις δυνατότητες του zebralight!
ergotelis
6 January 2010
2,018
Ηράκλειο Κρήτης
:bang::adore::hahaha: τι ειναι αυτο που εχει μπροστα το κεφαλι????
είναι κάπως,δεν έχουν όλοι τη τεχνολογία της zebralight! Αυτό που πετύχανε είναι μια κακή αντιγραφή θα έλεγα, αλλά ένταξει, 15 ευρά πιστεύω δε θα πάνε χαμένα, το πολύ πολύ να το κάνω δώρο σε κανένα.
astanapane_10
4 May 2010
1,654
ναι ρε μια χαρα ειναι για 15 ευρουλινια. Αν δεις οτι δεν ζεστενεται τοτε θα ειναι καλο εργαλειο.
ergotelis
6 January 2010
2,018
Ηράκλειο Κρήτης
Εντομεταξύ φίλε μου πρόσεξα ότι έχει Low mode 300mA! Έλεος! Με μια rcr123 ζήτημα να κρατάει 2 ώρες! Άσε που είναι πολύ δυνατό! Μάλλον θα πάει για μόντα να αποκτήσει κανένα ultra low mode.
Το high είναι 1300ma...έλεος... Για να κρατάει το πολύ κανά μισαωράκι...Τι να το κάνω?
Πάει για μόντα με τα 10000!
ergotelis
6 January 2010
2,018
Ηράκλειο Κρήτης
Κώστα τις είχα δει, αλλά δεν εστιάζουν, που για μένα μετράει, και είναι και πολύ ακριβές! Ε αν είναι να δώσεις 35-40 δολλάρια για μια μούφα δώσε κανά 20άρικο παραπάνω και πάρε το καλό!
kospap
31 July 2009
8,404
σωστα.....ισως για μοντα και μονο να αξιζει? αλλα ποιος ξερει πως ειναι φτιαγμενα/πακτωμενα τα πραγματα εκει μεσα.....
οποτε ουτε το σκεφτηκα παραπανω
astanapane_10
4 May 2010
1,654
περιμενω κατι αντιστοιχο σε 18650 απο την Zebraligth.
σε καμια περισπτωση flood βεβαια.
