triplex71
Re: Απάντηση: Zgemma H9S 4K UHD DVB-S2X Multistream
Επίσης υπάρχει καί το PurE2 γιά τούς Zgemma H9S τό οποίο έχει πολλά καλούδια καί μπαίνει στήν sd card τού δέκτη σου
http://pur-e2.club/OU/images/index.php?dir=6.2/airdigital/
0) Format your Micro SD card into EXT4. Anything from 4GB upwards, I guess - mine is 64GB and it worked. Do it in your laptop, say using Mini Tool Partition Wizard or Paragon freeware.
1) Put the MicroSD card in your Zgemma H9.
2) On your Zgemma remote press: MENU > pManager > Scripts > right arrow on the remote > User Scripts > Start script > h9_mmc.sh > OK > execute once.
It will take its time and you will see it all happening in front of you, on the TV screen, all of it being copied to the Micro SD card.
Once it stops and tells you how much it copied, at which speed etc. - it is over.
3) Go to PuTTy on your PC and log in, then write on your keyboard the following commands:
username > hit ENTER on your keyboard
password > ENTER
sync > ENTER
4) Go back to your H9 remote control > exit 'till you see Standby/Restart > Restart (not Restart enigma) > OK.
5) If you want to go back to your flash only - do the same, just execute h9_nand.sh script.
password > ENTER
sync > ENTER
