Re: ZYXEL NSA-310 NAS STORAGE 2TB
Παράδειγμα:
-- Physical Disk Information - Disk: #16: ST3000DM001-1CH166 --
Hard Disk Summary
Hard Disk Number. . . . . . . . . . . . . . . . . 16
Hard Disk Device. . . . . . . . . . . . . . . . . /dev/sdl
Interface . . . . . . . . . . . . . . . . . . . . S-ATA II
Hard Disk Model ID. . . . . . . . . . . . . . . . ST3000DM001-1CH166
Hard Disk Revision. . . . . . . . . . . . . . . . CC24
Hard Disk Serial Number . . . . . . . . . . . . . Z1F1P384
Hard Disk Total Size. . . . . . . . . . . . . . . 2861588 MB
Current Temperature . . . . . . . . . . . . . . . 35 °C (95 °F)
Maximum Temperature (during Entire Lifespan). . . 54 °C (129 °F)
Power On Time . . . . . . . . . . . . . . . . . . 88 days, 0 hours
Estimated Remaining Lifetime. . . . . . . . . . . more than 1000 days
Health. . . . . . . . . . . . . . . . . . . . . . #################### 100 % (Excellent)
Performance . . . . . . . . . . . . . . . . . . . #################### 100 % (Excellent)
The hard disk status is PERFECT. Problematic or weak sectors not found and there are no spin up or data transfer errors.
No actions needed.
ATA Information
Hard Disk Cylinders . . . . . . . . . . . . . . . 5814021
Hard Disk Heads . . . . . . . . . . . . . . . . . 16
Hard Disk Sectors . . . . . . . . . . . . . . . . 63
Total Sectors . . . . . . . . . . . . . . . . . . 5860533168
ATA Revision. . . . . . . . . . . . . . . . . . . 7
Bytes Per Sector. . . . . . . . . . . . . . . . . 512
Buffer Size . . . . . . . . . . . . . . . . . . . 0 KB
Multiple Sectors. . . . . . . . . . . . . . . . . 16
Error Correction Bytes. . . . . . . . . . . . . . 4
Unformatted Capacity. . . . . . . . . . . . . . . 2861588 MB
Maximum PIO Mode. . . . . . . . . . . . . . . . . 4
Maximum Multiword DMA Mode. . . . . . . . . . . . 2
Maximum UDMA Mode . . . . . . . . . . . . . . . . 150 MB/s (6)
Active UDMA Mode. . . . . . . . . . . . . . . . . 150 MB/s (5)
Minimum Multiword DMA Transfer Time . . . . . . . 120 ns
Recommended Multiword DMA Transfer Time . . . . . 120 ns
Minimum PIO Transfer Time Without IORDY . . . . . 120 ns
Minimum PIO Transfer Time With IORDY. . . . . . . 120 ns
ATA Control Byte. . . . . . . . . . . . . . . . . Valid
ATA Checksum Value. . . . . . . . . . . . . . . . Valid
Acoustic Management Configuration
Acoustic Management . . . . . . . . . . . . . . . Not supported
Acoustic Management . . . . . . . . . . . . . . . Disabled
Current Acoustic Level. . . . . . . . . . . . . . Default (00h)
Recommended Acoustic Level. . . . . . . . . . . . Balanced performance and volume (D0h)
EIDE Properties
Read Ahead Buffer . . . . . . . . . . . . . . . . Not supported
DMA . . . . . . . . . . . . . . . . . . . . . . . Supported
Ultra DMA . . . . . . . . . . . . . . . . . . . . Supported
S.M.A.R.T.. . . . . . . . . . . . . . . . . . . . Supported
Power Management. . . . . . . . . . . . . . . . . Supported
Write Cache . . . . . . . . . . . . . . . . . . . Supported
Host Protected Area . . . . . . . . . . . . . . . Supported
Advanced Power Management . . . . . . . . . . . . Supported
Power Up In Standby . . . . . . . . . . . . . . . Not supported
48-bit LBA Addressing . . . . . . . . . . . . . . Supported
Device Configuration Overlay. . . . . . . . . . . Supported
IORDY Support . . . . . . . . . . . . . . . . . . Supported
Read/Write DMA Queue. . . . . . . . . . . . . . . Not supported
NOP Command . . . . . . . . . . . . . . . . . . . Not supported
Trusted Computing . . . . . . . . . . . . . . . . Not supported
64-bit World Wide ID. . . . . . . . . . . . . . . 005000C5FD4ECA2A
Streaming . . . . . . . . . . . . . . . . . . . . Not supported
Media Card Pass Through . . . . . . . . . . . . . Not supported
General Purpose Logging . . . . . . . . . . . . . Supported
Error Logging . . . . . . . . . . . . . . . . . . Supported
CFA Feature Set . . . . . . . . . . . . . . . . . Not supported
Long Physical Sectors (8) . . . . . . . . . . . . Supported
Long Logical Sectors. . . . . . . . . . . . . . . Not supported
Write-Read-Verify . . . . . . . . . . . . . . . . Supported, Disabled
NV Cache Feature. . . . . . . . . . . . . . . . . Not supported
NV Cache Power Mode . . . . . . . . . . . . . . . Not supported
NV Cache Size . . . . . . . . . . . . . . . . . . Not supported
Free-fall Control . . . . . . . . . . . . . . . . Not supported
Free-fall Control Sensitivity . . . . . . . . . . Not supported
Nominal Media Rotation Rate . . . . . . . . . . . 7200 RPM
SSD Features
Data Set Management . . . . . . . . . . . . . . . Not supported
TRIM Command. . . . . . . . . . . . . . . . . . . Not supported
Deterministic Read After TRIM . . . . . . . . . . Not supported
S.M.A.R.T. Details
Off-line Data Collection Status . . . . . . . . . Never Started
Self Test Execution Status. . . . . . . . . . . . Successfully Completed
Total Time To Complete Off-line Data Collection . 592 seconds
Execute Off-line Immediate. . . . . . . . . . . . Supported
Abort/restart Off-line By Host. . . . . . . . . . Not supported
Off-line Read Scanning. . . . . . . . . . . . . . Not supported
Short Self-test . . . . . . . . . . . . . . . . . Supported
Extended Self-test. . . . . . . . . . . . . . . . Supported
Conveyance Self-test. . . . . . . . . . . . . . . Supported
Selective Self-Test . . . . . . . . . . . . . . . Supported
Save Data Before/After Power Saving Mode. . . . . Supported
Enable/Disable Attribute Autosave . . . . . . . . Supported
Error Logging Capability. . . . . . . . . . . . . Supported
Short Self-test Estimated Time. . . . . . . . . . 1 minutes
Extended Self-test Estimated Time . . . . . . . . 332 minutes
Conveyance Self-test Estimated Time . . . . . . . 2 minutes
Security Mode
Security Mode . . . . . . . . . . . . . . . . . . Supported
Security Erase. . . . . . . . . . . . . . . . . . Supported
Security Erase Time . . . . . . . . . . . . . . . 159 minutes
Security Enhanced Erase Feature . . . . . . . . . Supported
Security Enhanced Erase Time. . . . . . . . . . . 159 minutes
Security Enabled. . . . . . . . . . . . . . . . . No
Security Locked . . . . . . . . . . . . . . . . . No
Security Frozen . . . . . . . . . . . . . . . . . No
Security Counter Expired. . . . . . . . . . . . . No
Security Level. . . . . . . . . . . . . . . . . . High
Serial ATA Features
S-ATA Compliance. . . . . . . . . . . . . . . . . Yes
S-ATA I Signaling Speed (1.5 Gps) . . . . . . . . Supported
S-ATA II Signaling Speed (3 Gps). . . . . . . . . Supported
Receipt Of Power Management Requests From Host. . Not supported
PHY Event Counters. . . . . . . . . . . . . . . . Supported
Non-Zero Buffer Offsets In DMA Setup FIS. . . . . Not supported
DMA Setup Auto-Activate Optimization. . . . . . . Supported, Disabled
Device Initiating Interface Power Management. . . Supported, Disabled
In-Order Data Delivery. . . . . . . . . . . . . . Not supported
Asynchronous Notification . . . . . . . . . . . . Not supported
Software Settings Preservation. . . . . . . . . . Supported, Enabled
Native Command Queuing (NCQ). . . . . . . . . . . Supported
Queue Length. . . . . . . . . . . . . . . . . . . 32
S.M.A.R.T.
No. Attribute Thre.. Value Worst Data Status Flags
1 Raw Read Error Rate 6 117 99 0000091F0688 OK Error-Rate, Performance, Statistical, Critical
3 Spin Up Time 0 94 94 000000000000 OK (Always passing) Statistical, Critical
4 Start/Stop Count 20 99 99 000000000589 OK Self Preserving, Event Count, Statistical
5 Reallocated Sectors Co.. 10 100 100 000000000000 OK Self Preserving, Event Count, Statistical, Critical
7 Seek Error Rate 30 68 60 000000664D1D OK Error-Rate, Performance, Statistical, Critical
9 Power On Time Count 0 98 98 000000000840 OK (Always passing) Self Preserving, Event Count, Statistical
10 Spin Retry Count 97 100 100 000000000000 OK Event Count, Statistical, Critical
12 Drive Power Cycle Count 20 100 100 000000000012 OK Self Preserving, Event Count, Statistical
183 Vendor-specific 0 100 100 000000000000 OK (Always passing) Self Preserving, Event Count, Statistical
184 End-to-End Error Count 99 100 100 000000000000 OK Self Preserving, Event Count, Statistical
187 Reported Uncorrectable.. 0 100 100 000000000000 OK (Always passing) Self Preserving, Event Count, Statistical
188 Command Timeout 0 100 61 000002660268 OK (Always passing) Self Preserving, Event Count, Statistical
189 High Fly Writes 0 100 100 000000000000 OK (Always passing) Self Preserving, Event Count, Error-Rate, Statistical
190 Airflow Temperature 45 65 46 000028180023 OK Self Preserving, Statistical
191 G-Sense Error Rate 0 100 100 000000000000 OK (Always passing) Self Preserving, Event Count, Statistical
192 Power off Retract Cycl.. 0 100 100 00000000000B OK (Always passing) Self Preserving, Event Count, Statistical
193 Load/Unload Cycle Count 0 90 90 0000000052D0 OK (Always passing) Self Preserving, Event Count, Statistical
194 Disk Temperature 0 35 54 000E00000023 OK (Always passing) Self Preserving, Statistical
197 Current Pending Sector.. 0 100 100 000000000000 OK (Always passing) Event Count, Statistical
198 Off-Line Uncorrectable.. 0 100 100 000000000000 OK (Always passing) Event Count
199 Ultra ATA CRC Error Co.. 0 200 200 000000000000 OK (Always passing) Self Preserving, Event Count, Error-Rate, Performanc..
240 Head Flying Hours 0 100 253 85BF00000340 OK (Always passing)
241 Vendor-specific 0 100 253 000170501990 OK (Always passing)
242 Vendor-specific 0 100 253 000454564220 OK (Always passing)
