[1.1.4] iPlus+International Pack! Downgrade to 3.9FakeBlank, unlock, activate, JB!
nikolis9
2 November 2007
889
Announcing iPlus 1.1
A *fully automatic* tool for downgrading the BL, unlocking, jailbreaking and activating, with a custom payload for installing other packages.
** Bootloader downgrading use BL 3.9FakeBlank
http://r a p i d s h a r e.com/files...us1.1.zip.html
Tutorial: http://www.iclarified.com/entry/index.php?enid=760
It will:
1-Unlock and if required automatically downgrade the bootloader to 3.9FakeBlank
2-Jailbreak
3-Activate
4-Install AFC2
5-Add the following packages:
- Installer
- Community Services
- BSD subsystem
- OpenSSH
- VT-100
Plus:
- BSD Fix
- VT100 Fix
- Summerboard themes directory fix
- Relocates Fonts and Ringtones (More than 120MB free)
The actual packages payload can be easily modified to add new features
Optional payload packs:
Brazil Payload Pack: http://r a p i d s h a r e.com/files...ad_BR.zip.html
International Payload Pack: http://r a p i d s h a r e.com/files/97324521/payload-int.zip.html
- Just rename the file to payload.zip and replace on the iPlus directory and you are ready to use it!
NOTE: at this time it's for Windows only. I will add a MacOS X version later.
CREDITS: This code is major patchwork of bits and pieces written by several people. I do not take credit for the works of others. So many thanks to:
GeoHot, cRACKn, MuscleNerd, BaalBeck, acujo, Zibri, George Zhu, Tim Schuerewegen, and many others. And the DEV TEAM.
If I forgot someone, please let me know!
Also, >>> DONATE TO THE DEV TEAM! <<<
New update more safe than ever nowAnnouncing iPlus 2.0 for iPhone firmware 1.1.4 *only*
NOW SAFER THAN EVER!
A *fully automatic* tool for setting up your iPhone! For Windows and Mac OS X (intel/PPC)
It will downgrade the bootloader, unlock, jailbreak and activate the iPhone. And even better, it will also install the most important and common packages as well as several fixes.
Bootloader downgrading uses BL 3.9FakeBlank, so it is fully reversible.
Thanks for the Dev Team for the help with the ramdisk issues that made me revise the unlocking/downgrading scheme and lead to this new version. This should take care of the "Repaid Needed" issues.
What's new in 2.0
- Unlock/downgrade strategy rework: Now safer than ever!
- New Interface on the iPhone (using iPipe from MCA)
- Fix for the "Repair Needed" problem reported by some users
- iPlus will always reboot twice (and not 2 or 3 times)
- Pass 2 visual feedback. Now users know what is going on
- PC/Mac program will not end until everything is really done
- Support for PPC
What next
- GUI (minor problem)
- iTouch
Features:
1-Unlock and, if required, automatically downgrade the bootloader from 4.6 to 3.9FakeBlank
2-Jailbreak
3-Activate
4-Install AFC2
- Installer
- Community Sources
- BSD subsystem
- OpenSSH
- VT-100
Plus:
- BSD Fix (backspace)
- VT100 Fix (can't login)
- Summerboard themes directory fix (installation issues)
- Relocates Fonts and Ringtones (Allows for more than 120MB free for Apps!)
- Customizable payloads!
Optional payload packages allow even further customization. Currently the following packs are available:
- Brazil - Adds all you need to use your phone in Brazil
- International - fix problems to allow your phone to be used (almost) worldwide
Just rename the payload file to payload.zip and place it on the iPlus directory and you are ready to use it! Removing the payload file from the iPlus directory can be used to perform a simple jailbreak/activation/unlock (Installer will not be included). Other packages may be later using any tool that rely on the AFC2 interface (ex: iBrickr and iNdependence)
Download links:
iPlus 2.0: http://r a p i d s h a r e.com/files...us2.0.zip.html
Brazil Pack: http://r a p i d s h a r e.com/files...ad_br.zip.html
International Pack: http://r a p i d s h a r e.com/files...ional.zip.html
MacOS users may need libreadline:
Download it here: http://r a p i d s h a r e.com/files/61509655/opt.zip
Other Payloads:
Custom payloads, prepared by others, are starting to show up:
- Payload with Telesphoreo and Cydia instead of BSD Subsystems.
. Cydia Packager (apt-get front-end)
. Telesphoreo (open-source community based BSD Subsystem replacement)
. Installer
. Community Sources
. Fake BSD subsystem (to allow other packages to install)
. OpenSSH
. VT-100
. Summerboard themes directory fix (installation issues)
. Relocates Directories
Download: Not yet updated to 2.0
Tutorials (some may be still on 1.2 level)
Windows:
Add different payload:http://www.iclarified.com/entry/index.php?enid=766
and
http://www.hackthatphone.com/114/iph...k_windows.html
Mac OS X:
Add different payload: http://www.iclarified.com/entry/index.php?enid=766
http://coolblog.profit42.com/2008/03...osx-ith-iplus/
http://www.iclarified.com/entry/index.php?enid=765
Need to go back to 4.6BL?
http://www.hackint0sh.org/forum/show...t=33050&page=2
CREDITS:
GeoHot, cRACKn, MuscleNerd, Pumpkin, SoLoR, BaalBeck, aCujo, George Zhu, Tim Schuerewegen, Marcio Almeida, N_41, Zibri and many others.
and the DEV TEAM.
Σε ΕΛΛΗΝΙΚΗ ΜΕΤΑΡΦΑΣΗ
Σημαντικό! Η εφαρμογή iPlus είναι η απόλυτη μέθοδος ξεκλειδώματος αυτή τη στιγμή. Επιτρέπει activare/jailbreak/unlock σε συσκευές 1.1.4 είτε έχουν bootloader 3.9 ή 4.6 και, ταυτόχρονα με το jailbreak, παρέχει τη δυνατότητα για εγκατάσταση των πιο χρήσιμων πακέτων και διορθώσεων. Στις συσκευές με bootloader 4.6, πραγματοποιεί unlock υποβαθμίζοντας το bootloader σε μια τροποποιημένη έκδοση 3.9 (3.9FakeBlank) η οποία μπορεί να επανέλθει μέσω software σε 4.6. Έτσι, μπορείτε να επαναφέρετε πλήρως τη συσκευή σε εργοστασιακή κατάσταση εάν θελήσετε, χωρίς να χρειαστεί να την ανοίξετε και να ακυρώσετε την εγγύηση σας! Επίσης, όσοι επιλέξετε να υποβαθμίσετε το bootloader σας σε 3.9Fakeblank αποφύγετε τη χρήση του ZiPhone 2.4+ για ξεκλείδωμα διότι, υπάρχει αυτή τη στιγμή μια υποψία ότι, στην προσπάθεια να υποβαθμίσει το 3.9FakeBlank σε εργοστασιακό 3.9 δημιουργείται πρόβλημα από το οποίο προκύπτει έκδοση bootloader 3.8 (συνήθως μη λειτουργική - επανέρχεται αλλά απαιτεί hardware μέθοδο)!
Δεν υπάρχει κανένας λόγος και δεν χρειάζεται να χρησιμοποιείτε ZiPhone για ξεκλείδωμα εάν επιλέξετε να ακολουθήσετε τη μέθοδο του iPlus!
Ένα πολύ ενδιαφέρον στοιχείο είναι κοινό όσον αφορά στις παρακάτω εφαρμογές: Χρησιμοποιούν μια τροποποιημένη έκδοση του ramdisk, διαφορετική από αυτή την οποία χρησιμοποιεί το ZiPhone. Οι συγκεκριμένες εκδόσεις, φέρονται να είναι βελτιωμένες σε σύγκριση με εκείνη του ZiPhone.
Μετά την κυκλοφορία της καινούριας αναβάθμισης, οι συσκευές έπειτα από update/restore μέσω itunes θα έχουν πλέον firmware 1.1.4 και baseband 4.04.05. Για activate/jailbreak/unlock υπάρχουν οι ακόλουθες, εναλλακτικές, επιλογές:
Χρήστες Mac
(α) Χρησιμοποιήστε το independence 1.4 beta 5 και επιλέξτε Activate/Jailbreak/SIM unlock. Το independence χρησιμοποιεί μια τροποποίηση της μεθόδου gunlock για το ξεκλείδωμα και για το λόγο αυτό οι συσκευές με bootloader 4.6 καταλήγουν με baseband 4.02.13. Το independence δεν εγκαθιστά το installer.app, θα πρέπει να το περάσετε χειροκίνητα (σημείωση Ι).
Οδηγός: http://www.hackthatphone.com/114/iph...nlock_mac.html
Όσοι έχετε συσκευή η οποία έχει ξεκλειδωθεί με ipsf δεν χρειάζεται να ξεκλειδώσετε εκ νέου τη συσκευή σας. Μπορείτε, απλά, να εγκαταστήσετε το signal.app ώστε να θέσετε το ipsf εν ενεργεία. Για να το κάνετε αυτό μπορείτε να χρησιμοποιήσετε τον οδηγό που ακολουθεί ή να χρησιμοποιήσετε το iphone-tools (σημείωση ΙΙΙ) το οποίο αυτοματοποιεί τη διαδικασία.
Οδηγός: http://www.hackthatphone.com/114/iph..._39bl_mac.html
(β) Χρησιμοποιήστε την εφαρμογή iPlus. Για τη μέθοδο αυτή απαιτείται να έχετε στη συσκευή σας firmware 1.1.4 γι' αυτό πριν την χρησιμοποιήσετε προχωρήστε σε restore 1.1.4 μέσω itunes.
Οδηγοί:
How to Unlock 1.1.4 and Downgrade to 3.9-fakeblank iPhone Bootloader (Mac): http://www.iclarified.com/entry/index.php?enid=765
How to activate, jailbreak and unlock 1.1.4 firmware with iPlus (3.9 / 4.6 bootloader): http://www.hackthatphone.com/114/iph...946bl_mac.html
*Για να αποφύγετε κάθε είδους προβλήματα, πριν το restore σε 1.1.4 διαγράψτε το backup από το itunes (preferences->syncing->remove backup) κι έπειτα πραγματοποιήστε setup as a new iphone. Χρησιμοποιήστε την επιλογή sync για να ανακτήσετε τις επαφές και άλλα δεδομένα.
*Όσοι χρησιμοποιείτε Leopard θα πρέπει να έχετε το αρχείο libreadline.5.2.dylib στην τοποθεσία /opt/local/lib. Αν δεν έχετε το αρχείο μπορείτε να το κατεβάσετε από τον παρακάτω σύνδεσμο
Κώδικας:
http://rapidshare.com/files/61509655/opt.zip
Χρήστες Windows
(α) Χρησιμοποιήστε την εφαρμογή iPlus. Για τη μέθοδο αυτή απαιτείται να έχετε στη συσκευή σας firmware 1.1.4 γι' αυτό πριν την χρησιμοποιήσετε προχωρήστε σε restore 1.1.4 μέσω itunes.
Οδηγοί:
How to Unlock 1.1.4 and Downgrade to 3.9-fakeblank iPhone Bootloader: http://www.iclarified.com/entry/index.php?enid=760
How to activate, jailbreak and unlock 1.1.4 firmware with iPlus (3.9 / 4.6 bootloader): http://www.hackthatphone.com/114/iph...k_windows.html
iPlus
Χαρακτηριστικά
Βασικά
1. Εάν χρειαστεί, θα υποβαθμίσει το bootloader, όταν δωθεί εντολή για ξεκλείδωμα. Το bootloader θα υποβαθμιστεί σε μια έκδοση 3.9 η οποία είναι τροποποιημένη (το ZiPhone υποβαθμίζει στην εργοστασιακή). Η έκδοση αυτή προσφέρει το σημαντικό πλεονέκτημα της μελλοντικής αναβάθμισης σε bootloader 4.6 (εργοστασιακό ή άλλο) αποκλειστικά με software μέθοδο. Προς το παρόν, η εργοστασιακή έκδοση 3.9 μπορεί να αναβαθμιστεί μόνο με hardware μέθοδο.
2. Κάνει jailbreak της firmware 1.1.4, χρησιμοποιώντας το exploit στο ramdisk. Ο λόγος που ισχύει μόνο για τη συγκεκριμένη έκδοση firmware είναι διότι πραγματοποιεί περισσότερες λειτουργίες από το ZiPhone (χρησιμοποιεί διαφορετικό ramdisk) και το μέγεθος της ramdisk είναι πεπερασμένο.
3. Πραγματοποιεί Activate της συσκευής και του YouTube.
4. Υποστήριξη AFC2 (για να μπορείτε να χρησιμοποιήσετε το iBrickr και το iPhuc ώστε να έχετε πρόσβαση στο rootfs).
Προηγμένα
1. Υποστήριξη custom payload.
(α) Custom payload international.
(β) Custom payload για συγκεκριμένη χώρα υπάρχει, προς το παρόν, μόνο για Βραζιλία. Δεν εγκαθίσταται by default και αφορά σε full customization για Βραζιλία (το customization περιλαμβάνει διορθώσεις called id, call data, διεθνή πληκτρολόγια, διορθωμένη εμφάνιση των αριθμών στις κλήσεις, διορθωμένες πληροφορίες βασισμένες στο δίκτυο τηλεφωνίας, regional settings, δυνατότητα enable/disable auto correction feature, πληροφορίες δικτύων για Βραζιλία, ρυθμίσεις EDGE/GPRS Βραζιλίας, εικονίδιο GPRS - αντί του τετραγώνου, διορθωμένες πληροφορίες timezone Βραζιλίας, μετάφραση σε πορτογαλλικά).
3. Εγκατάσταση της τελευταίας έκδοσης installer.
4. Εγκατάσταση του πιο πρόσφατου πακέτου Community Sources.
5. Προ-εγκατάσταση των πακέτων: BSD-Subsystem, Open SSh, Term VT-100.
6. Μεταφορά των ringtones και fonts στην τοποθεσία /dev/disk0s2 (γνωστή και ως /private/var) ελευθερώνοντας περίπου 100MB από το System partition.
7. Ειδικές διορθώσεις:
(α) Εγκατάσταση SUID/Lib και VT100 Fix (πρόβλημα με το login) για το VT-100
(β) Διόρθωση του backspace στο BSD.
(γ) Τοποθεσία summerboard themes.
Δημιουργία custom payloads
Τα payloads μπορούν εύκολα να επεκταθούν ή να τροποποιηθούν ώστε να περιλάβουν οποιοδήποτε άλλο αυτόματο customization. Μπορείτε να προσθαφαιρέσετε πακέτα εγκατάστασης προγραμμάτων στο αρχείο payload.zip και στη συνέχεια να προσθέσετε/αφαιρέσετε τις κατάλληλες οδηγίες για την εγκατάσταση, μέσω του do_payload.sh (βρίσκεται εντός του payload.zip). Το do_payload.sh αποτελεί shell script και τα αρχεία zip έχουν συμπιεστεί ώστε να είναι συμβατά με το λειτουργικό σύστημα Mac OS X. Η διαδικασία χρειάζεται να γίνει με τρόπο ώστε να υπάρχει συμβατότητα με σύστημα Unix (Linux, FreeBSD ή MacOSX).
Το αρχείο payload.zip πρέπει να έχει την ακόλουθη δομή:
1. Να περιέχει payload directory (folder).
2. Εντός του directory πρέπει να βρίσκεται το shell script do_payload.sh το οποίο θα διεκπεραιώσει την εγκατάσταση των προγραμμάτων τα οποία βρίσκονται στο payload.
3. Να περιέχει όλα τα υπόλοιπα αρχεία τα οποία χρειάζεται το do_payload.sh.
Μπορείτε να χρησιμοποιήσετε τα υφιστάμενα payloads ως παραδείγματα.
Αν δεν θέλετε να εγκατασταθεί στη συσκευή σας το payload, απλά αφαιρέστε το αρχείο payload.zip από το folder iPlus. Σε αυτή την περίπτωση θα πρέπει να εγκαταστήσετε τον installer χειροκίνητα (σημείωση Ι).
Λειτουργία
Δεν είναι απαραίτητο να τερματίσετε το itunes. Ωστόσο, εάν η συσκευή δώσει error "Repair Needed" τότε τερματίστε το itunes και ξανατρέξτε το iPlus (συνήθως αυτό γίνεται μετά την υποβάθμιση, όταν έχει διαγραφεί το baseband). Αν θέλετε να είστε σίγουροι ότι το itunes δεν θα εμπλακεί στη διαδικασία τερματίστε το και επιπλέον τερματίστε και το ituneshelper. Επίσης, το σφάλμα "cannot change ownership" κατά την εγκατάσταση των πακέτων είναι φυσιολογικό, αγνοήστε το.
Μπορείτε να δώσετε τις ακόλουθες εντολές μέσω command line:
Χρήστες Windows
iplus για Activate/Jailbreak
iplus [-u] για Activate/Jailbreak/Unlock (και υποβάθμιση του bootloader από την έκδοση 4.6 σε 3.9FB)
Χρήστες Mac
./iplus για Activate/Jailbreak
./iplus [-u] για Activate/Jailbreak/Unlock (και υποβάθμιση του bootloader από την έκδοση 4.6 se 3.9FB)
Επανεκκινήσεις της συσκευής
Τα πάντα γίνοντα αυτόματα.
Αφού μπει σε recovery mode για την εγκατάσταση της ramdisk image, η συσκευή θα επανεκκινήσει 2 φορές. Η πρώτη ακολουθεί την επεξεργασία του ramdisk και η δεύτερη την επεξεργασία του payload (μπορεί να κρατήσει μερικά λεπτά μετά την ολοκλήρωση της επανεκκίνησης).
iPlus (βεβαιωθείτε ότι χρησιμοποιείτε την τελευταία έκδοση):
http://www.hackint0sh.org/forum/showthread.php?t=32926
International Payload Pack (μετονομάστε το αρχείο σε payload.zip και αντικαταστήστε αυτό στο iPlus directory για να το χρησιμοποιήσετε):
How to Add the International Payload to iPlus: http://www.iclarified.com/entry/index.php?enid=766
iNdependence
Χαρακτηριστικά
Βασικά
1. Activate και Jailbreak σε όλες τις εκδόσεις firmware και unlock baseband μέχρι και την έκδοση 4.04.05 για bootloader 3.9 ή 4.02.13 για bootloader 4.6. ΔΕΝ υποβαθμίζει το bootloader.
2. Υποστηρίζει PPC και Intel Μac OS X. Δεν υπάρχει έκδοση για χρήστες Windows.
Προηγμένα
1. Εγκατάσταση βελτιωμένης έκδοσης SSH.
2. Customization εφαρμογών, ringtones, wallpapers.
3. Παροχή λεπτομερών πληροφοριών για την κατάσταση της συσκευής
iNdependence (βεβαιωθείτε ότι χρησιμοποιείτε την τελευταία έκδοση):
http://code.google.com/p/independence/
Σημείωση I. Για να εγκαταστήσετε τον installer μετά από activate/jailbreak με independence:
1. Kατεβάστε το πακέτο installer.app από http://repository.apptapp.com/packag.../Installer.zip
2. Aποσυμπιέστε το αρχείο zip στο desktop.
3. Προσθέστε το αρχείο installer.app στο tab customize του independence.
4. Ενωθείτε στο τηλέφωνο σας μέσω SSH και δώστε τις ακόλουθες εντολές μέσω terminal:
chmod 777 /Applications
chmod 777 /Applications/Installer.app
chmod 777 /Applications/Installer.app/Installer
Οδηγός: http://www.hackthatphone.com/114/iph...9bl_mac_2.html
Σημείωση II-α. Υπάρχει εναλλακτική πρόταση τόσο για τον installer όσο και για το BSD Subsystem. Ονομάζεται Cydia Packager και μπορείτε να το εγκαταστήσετε μέσω installer από την κατηγορία system αφού προσθέσετε το source http://apptapp.saurik.com/. Μετά την εγκατάσταση της συγκεκριμένης εφαρμογής δεν χρειάζεται (και δεν πρέπει) να εγκαταστήσετε ή να αναβαθμίσετε το BSD Subsystem από τον installer. Μέσω του Cydia Packager θα μπορείτε να εγκαταστήσετε τις περισσότερες από τις εφαρμογές που θα βρείτε και στον installer ενώ οι δύο εφαρμογές (Cydia και Installer) μπορούν να βρίσκονται ταυτόχρονα εγκατεστημένες στη συσκευή χωρίς η μία να επηρεάζει τη λειτουργία της άλλης (δεδομένου ότι δεν θα "πειράξετε" την έκδοση του BSD Subsystem που εγκαθιστά το Cydia). Θα πρέπει να έχετε υπόψιν ότι το Cydia χρειάζεται αρκετό χρόνο για να εγκατασταθεί (περίπου 5 λεπτά) και γι' αυτό θα πρέπει να επιλέξετε Auto lock -> Never πριν προχωρήσετε με την εγκατάσταση. Επίσης, κατά την εγκατάσταση θα μεταφέρει το σύνολο των wallpapers, fonts, ringtones, shared data και applications στο μεγάλο partition της συσκευής σας. Λεπτομέρειες για τη συγκεκριμένη εφαρμογή μπορείτε να βρείτε στο θέμα για το Cydia Packager (http://www.myphone.gr/forum/showthread.php?t=200831) και στην ιστοσελίδα του δημιουργού: http://www.saurik.com/id/1
Οδηγός: http://www.hackthatphone.com/114/iphone_cydia.html
Σημείωση II-β. Custom payload Cydia Packager
Το συγκεκριμένο payload προορίζεται για χρήση με την εφαρμογή iPlus και πραγματοποιεί αυτοματοποιημένη εγκατάσταση, κατά το jailbreak, των ακόλουθων εφαρμογών και διορθώσεων: Telesphoreo και Cydia αντί της εφαρμογής BSD Subsystems, Cydia Packager (apt-get front-end), Telesphoreo (open-source community based BSD Subsystem replacement), Installer, Community Sources, Fake BSD subsystem (για τις εφαρμογές που απαιτούν την παλιά έκδοση BSD Subsystems για να εγκατασταθούν), OpenSSH, VT-100, Summerboard themes directory fix (installation issues), Μετακίνηση directories (wallpapers, fonts, apps κλπ).
http://www.hackint0sh.org/forum/showthread.php?t=33613
Σημείωση III. Iphone-tools1.1.4
Όσοι επιθυμούν να μεταβάλουν την έκδοση 4.6 του bootloader σε κάποια από τις τροποποιημένες εκδόσεις (3.9FakeBlank και 4.6FakeBlank) μπορούν να χρησιμοποιήσουν το iphone-tools1.1.4 το οποίο, αυτή τη στιγμή, παρέχει περισσότερες επιλογές (όσον αφορά στα bootloaders) από το iPlus.
Με τη συγκεκριμένη εφαρμογή μπορείτε, επιπλέον, να κάνετε activate/jailbreak (χρησιμοποιεί το ramdisk από ziphone) και να ξεκλειδώσετε τη συσκευή (χρησιμοποιεί το unlock114). Αυτό γίνεται αυτόματα, δίνοντας τις κατάλληλες εντολές. Όσοι θέλετε πληροφορίες για τα αρχεία που χρησιμοποιούνται (μόνο για τα αρχεία!) μπορείτε να δείτε τον παρακάτω οδηγό.
How to Unlock a 1.1.4 iPhone (ZiPhone + Installer) (Windows): http://www.iclarified.com/entry/index.php?enid=740
Μέσω command line, μπορείτε να δώσετε τις παρακάτω εντολές:
Εντολές (windows):
iphone-tools [-b]: Downgrade bootloader (4.6orig.-3.9fb)
iphone-tools [-B]: Upgrade bootloader (3.9fb-4.6orig.)
iphone-tools [-3]: Downgrade bootloader (4.6fb-3.9fb)
iphone-tools [-4]: Upgrade bootloader (3.9fb-4.6fb)
iphone-tools [-u]: Unlock (τελευταίο baseband)
iphone-tools [-a]: Activate (όλες οι firmware)
iphone-tools [-j]: Jailbreak (όλες οι firmware)
iphone-tools [-s]: Install signal.app (για IPSF)
iphone-tools [-e]: Erase baseband (για BL 3.9)
iphone-tools [-r]: Reflash baseband (για BL 3.9)
iphone-tools [-D]: Enter DFU mode
iphone-tools [-R]: Enter Recovery mode
iphone-tools [-N]: Exit Recovery mode
iphone-tools [-I]: Show bootloader and baseband info
Iphonet-tools 1.1.4a:
Κώδικας:
http://rapidshare.com/files/97596489/iphone-tools1.1.4a.rar
Όσοι δεν είστε εξοικειωμένοι με το command line υπάρχει και έκδοση GUI για windows: Ονομάζεται eZiphone tools και βρίσκεται στο πακέτο iphone-tools.
ZiPhoneTools 1.1.4 GUI: http://www.hackint0sh.org/forum/showthread.php?t=32668
Περισσότερα για bootloaders στο σχετικό θέμα: http://www.myphone.gr/forum/showthread.php?t=198968
Υ.Γ. 1: Φαίνεται ότι ο geohot κάτι καινούριο μαγειρεύει και σε λίγες ημέρες θα έχουμε εξελίξεις στον bootloader 4.6 (http://iphonejtag.blogspot.com/)
Υ.Γ. 2: Αναμένεται σύντομα η κυκλοφορία του Pwnage από τη dev team. Το project θα περιλαμβάνει εργαλεία (iPwner και IPSW Builder) για την εγκατάσταση custom IPWSs στη συσκευή.
iPlus 1.2 works only with 1.1.4 fw. That means you have to restore phone to 1.1.4 before using it.
ZiPhone works with 1.1.2, 1.1.3 and 1.1.4 - If you really really want to use ziphone, you have to be very careful not to "Do it All". You have to be careful not to let ziphone downgrade your bootloader. With version 2.5 of ziphone & 1.1.4, if you use -u (unlock), it will automatically downgrade bootloader, so don't do it.
With ziphone unlock, you end up with a hybrid phone; meaning OS fw and baseband fw does not match (unless you downgrade bootloader).
So what's the best choice?
- Iplus all the way. Just restore your phone to 1.1.4 and use iPlus.
Why is it the best choice at the moment?
- because it downgrades your BL from 4.6 to 3.9FB which means you can go back to original 4.6 or 4.6FB if you want to.
note: ziphone downgrades BL to 3.9 original which means you cannot go back at the moment via software.
- OS firmware and Baseband firmware matches so you're right on the money. Plus iPlus is safe !!!
