AZBox Elite/Premium, part II
που μπορώ να προμηθευτώ ένα tuner dvb-t mpeg 4 για τον elite? κ πόσο κοστίζει περίπου?
Καλημέρα παιδιά...υπάρχει περίπτωση να μπορεί στο μέλλον να δεχτεί ο Premium + μοντούλα secure silicon?
οσο και οι αλλοι δεκτες της αγορας (dream-duo-και λοιποι συγγενεις.....τοσο και αυτος.......................... μαλλον οχι !!!!!!!!!!!!!!!!!!
Code:
[B]RTi Core v1.1 Enigma 2 				[/B]
What is changed:
[INDENT]
- back to linux 2.6.22
- Overall stability is better
- Faster zapping
- Media Center should support many files and formats
 - new filter handling code, should be fixed D+ channels
- default EPG okey
-  recording okey , when playing recorded material over VLC no breaks in sound
 - 1080p font should be okey
 - faster video mode changes
 - grab fix for HD ch.
 - P+ 2'nd tuner fix and decription
 - usbserial and ftdi.ko (USB Card readers and other usb hw should work)
- New Bootlogo - thanx to Daconi
and many more fixes/features
What (still) doesnt work:
 - MyTube - only first video work without problem
 - TS (recorded from e2) doesnt play in MC , but play in internal E2 TS player (press guide button)
 - Some TS (recorded frome2) doesnt play in internal TS player
 - DVD player in MC doesnt work and when start and want to exit - get only spinner and receiver doesnt responding / crash
RTi E2 project is really maded for all users which really wants something more from their lovely AzBox.
RTi E2 is mentioned mean people, which are full of frustrations or which  are paid to spread lies and bad words about AzBox or to act like that,  or people which really dont have an elementary knowledge about Linux  systems which doesnt know anything more than Format App area, we really  recommend them to buy some FTA Receiver and to stop torturing themselves  with modern technologies, and to cure their frustration with help of  professional psychiatrists, as also psychiatrists need to live and earn  from something [IMG]http://www.azbox-enigma.eu/RTi/forum/images/smilies/wink.png[/IMG].
Unfortunately, there is one small group which is working against AzBox  and anything related to it, especially after new models was announced on  Anga Cable Show in Germany. Please be aware that this group will make  their activities against AzBox even stronger when new models soon come  to the market, and because of this we want to let You know, all normal  users about their intentions and to stay cool and to dont react on their  provocations.
For us, there is only one mission, just to make YOU, all normal users  happy with their lovely AzBox, and to listen Your wishes to make our  enigma 2 better as much is possible, and in same time to ignore bad and  mean voices.
For Flashing Your AzBox with this latest Enigma 2, to avoid any problems  in that process, please be carefull and use latest AzUP which is  attached with RTi Enigma 2 v1.1, as we cant guarantee how Your AzBox  will work if You flash it with other tools which are not maded in  cooperation with our team.
We also want to say Thanks to all our Beta testers which tested in BETA  Section almost 2 weeks this new Enigma 2, and which helped us to fix as  much as possible things inside of it.
Also we want to let you know, that RTi Team is in every day connection  and talks with SPAZE Team, and we make big and good cooperation with  them, so You can also expect new SPAZE Images for AzBox with latest  updates and so on.
RTi Team also decided to open some parts of drivers, like Tuner drivers,  kernel and so on, so people can do as much as possible modifications [IMG]http://www.azbox-enigma.eu/RTi/forum/images/smilies/wink.png[/IMG].
Download RTi Core v1.1. Enigma 2:
[URL="http://www.filesonic.com/file/1454301624/RTi_Core_1.1.rar"]RTi Core v1.1[/URL]
Patched tuners source code from linux kernel and source code by the_ripper for MXL201RF
[URL]http://www.megaupload.com/?d=MNEM2W87[/URL]
Linux kernel source
[URL]http://www.megaupload.com/?d=EHK6PGJZ[/URL]
Linux INIT RAMFS rootfs
[URL]http://www.megaupload.com/?d=4OF2USTB[/URL][/INDENT]
Γεια χαρά
Σήμερα γύρισα στο oroginal και μέσα στο folder Download υπάρχει το αρχείο dpatch.cramfs 46MB.Χρειάζετε η να το σβήσω;
2011.07.07
azbox-0.9.5308-patch.bin
45.39 MB1084e1fe5f7e16a50ad0705aeb1cde2b
DVBS.dat is now split between ku and c band ( to use this new file, after install perform a factory restore ) | fixed the dutch iso369 string | added 2 new dvbc countries : dutch and ukraine ( testing ) | fixed the epg detail scrolling | fixed the number of audio streams available at audio list window (euronews)
http://www.multiupload.com/CL6PV5Q2KU
γιαυτο το 5308 λετε η ειναι αλλο?
Για το ιδιο λεμε απλα το δικο μας ειναι μαλλον για να τρεχη μεσα απο usb οταν ο δεκτης φοραει ε2 ,αν εχω καταλαβει καλα .............
καλησπέρα παιδιά, μια βοήθεια θα ήθελα αν μπορείτε,
ίσως έχει απαντηθεί στο παρελθόν αλλά δεν βρήκα κάτι.
Εδώ και μερικές μέρες ο δέκτης έχει μείνει στο update menu με το μήνυμα
«Last Updating is Fail (error=1)”.
Το έπαθα προσπαθώντας να γυρίσω το σύστημα από ε2 v1.1 σε official.
Το μπέρδεμα είναι ότι παρόλο που βλέπω την οθόνη του upgrade όταν προσπαθώ αναβάθμιση από usb δεν αναγνωρίζει καμία συσκευή.
έχω δοκιμάσει αρκετά στικάκια αλλά φώς δεν είδα..
Καλησπέρα φίλε μου,
αν απαντάς στο δικό μου ερώτημα, δυστυχώς ο οδηγός παύει να ισχύει από το πρώτο βήμα μιας και δεν αναγνωρίζει κανένα usb stick ....πόσο μάλλον να μπεί σε recovery.
επίσης προϋποθέτει ότι είσαι σε recovery mode ε2. Και όχι σε official όπως ο δικός μου…
γενικά νομίζω ότι την έχω πατήσει, έχω δοκιμάσει τα πάντα… και το ultrex δεν βοηθάει..
ευχαριστώ :)
ΥΓ. σήμερα βρήκα ένα αρχαίο stick 256μβ να δοκιμάσω μπας και...
Καλησπέρα φίλε μου,
επίσης προϋποθέτει ότι είσαι σε recoverymode ε2. Και όχι σε officialόπως ο δικός μου…
ευχαριστώ :)
εχεις μήνυμα
εχεις μήνυμα
έβαλα έναν εσωτερικό σκληρό 1 τέρα με ταινίες ,αλλα στο boot δεν μου το βρίσκει πρέπει να κάνω κάτι έξτρα ??
έχω βάλει το τελευταίο 1.1 rti.
thanks m8!
για να δει ο δεκτης εσωτερικο δισκο ο δισκος πρεπει να ειναι φορμαρισμενος σε λινουξ φορματ (ext)δηλαδη φορμαρισμενος απο τον δεκτη η απο λινουξατο υπολογιστη,οποτε μαλλον αδικα προσπαθεις
