Β&W Zeppelin Air
philips : DS3800W/10
AD7000W/12
η ARCAM rCube με airport express ?
Τα Philips είναι αστεία μπροστά στο Zeppelin Air.
Το Arcam rCube θεωρήθηκε από κάποιους σφετεριστής του θρόνου το 2010, που συνεχόμενα κατείχε το αρχικό μοντέλο Zeppelin, αλλά μια έρευνα στο νετ για σύγκριση με το νέο Zeppelin Air αποδεικνύει και πάλι το προβάδισμα του Zeppelin Air.
π.χ. από πραγματικούς χρήστες εδώ: http://www.whathifi.com/forum/hi-fi/b-w-zeppelin-air-or-arcam-rcube
"Having now listened to the Air and rCube at some extent I would personally put my own money into the B&W. The sound is bigger, more open, more musical and I know it's not the be all and end all but the Air does go louder. I also love the AirPlay functionality which in my mind is easier that having to put a dongle in your iPod/iPad to stream the music to it."
ή από άλλον χρήστη:
"Went down to Audio T with a view to purchasing the R cube as I wanted the portability of the Arcam but more importantly was looking for the detail that the Arcam was known to produce. They set up the Arcam and Zeppelin Air in a listening room for me. I was there for over an hour switching my ipod between the two. The first difference you notice is the zeppelin's base, it is deep and powerfull without being overpowering. The Arcam did show a bit more detail on certain tracks but the zeppelin was impressing me more, it seemed to draw you into the songs and envelope you in the music, it was just a more enjoyable listening experience. I was trying different types of music hoping that the Arcam would impress me more as I really wanted the smaller dock and portability of the Arcam but after an hour I admitted defeat and went home with the Zeppelin as the listening experience was to enjoyable not too. One thing I would say in the Arcam's Defence was that Arcam say being a cube it sounds best placed in a corner where the sound can bounce of the walls which I wasn't able to do."
Αν θέλεις μόνο dock και δε σε νοιάζει το AirPlay, και το θέλεις και φορητό να έχει ενσωματωμένη μπαταρία όταν το βγάζεις από το ρεύμα, ή αν θέλεις να το τοποθετήσεις σε καμιά γωνία, και ο ήχος να ανακλάται στο δωμάτιο, πάρε το Arcam rCube, αλλιώς Zeppelin Air.
....εχει δυνατό ήχο για τα δεδομένα του;θα χρησιμοποιηθεί σε σαλόνι και γενικώς ακούω πολλά soundtracks και χαλαρή μουσική.
Θα εκπλαγείς! Ειδικά οι μεσαίες του για μένα ήταν αποκάλυψη, από θέμα όγκου και έντασης. Δεν παραμορφώνει ακόμη και σε πολύ υψηλές εντάσεις. Για τη χρήση και τη μουσική που θέλεις είναι άριστη επιλογή.
με πείσατε. απο που μπορουμε να το αγοράσουμε? Ελλάδα ή εξωτερικό?
κανένα site αξιόπιστο?
ευχαριστώ για την βοήθεια
Στα public που ρωτησα ειχαν το παλιο. Ο πωλητης με ενημερωσε οτι το air θα το φερουν πριν τις γιορτες και μαλλον στην ιδια τιμη με το παλιο (δηλ. 609ε) Με πιστωτικη γινονται και ατοκες δοσεις. Αλλιως απο amazon.de
Να κάνω 2 ερωτήσεις
Το airplay (στο zeppelin) παίζει μόνο με wifi ή παίζει και με ethernet?
To dock αφαιρείται με κάποιο τρόπο?
Να κάνω 2 ερωτήσεις
Εγώ με ethernet το παίζω, γιατί έχω περάσει παντού ενσύρματο δίκτυο στο σπίτι.
To dock υπάρχει τρόπος να αφαιρεθεί από τον χρήστη, αλλά χάνεται η εγγύηση, γιατί είναι δύσκολο να επανατοποθετηθεί ώστε να σταλεί στο σέρβις εντός εγγύησης.
Δεν βρισκω τις ακριβεις διαστασεις του. Μπορει να μου τις πει καποιος ?
@tzo, ποσο χρονο πηρε να σου ερθει η βαση απο Αγγλια?
Το εχεις δοκιμασει με wifi ? λειτουργει κανονικα ? (δεν εχω ethernet εκει που σκεφτομαι να το βαλω)
Edit. βρηκα τις διαστασει του: H17.3 x W64 x 20.8cm
Μια βδομάδα περίπου.
Φυσικά και λειτουργεί κανονικά με wi-fi, το τέσταρα μέχρι δύο ορόφους απόσταση από το router, όπου ήταν και το όριό του, με κάποιες διακοπές στον ήχο. Σε νορμάλ αποστάσεις από το ρούτερ, κανένα πρόβλημα.
Γίνεται να συνδέσεις οποιαδήποτε αναλογική πηγή στο aux-in του Zeppelin. Απλά θα χρειαστείς έναν αντάπτορα διπλού rca σε στερεοφωνικό mini-jack.
απο το review για το zeppelin air
However, given the expectations users will have for both AirPlay and the $600 price, Zeppelin Air really could have benefitted from some additional development time before release. Apple’s “it just works” AirPlay technology isn’t quite as magical when you have to tether a new speaker to an Ethernet wire and computer, then go through a web-based setup process to get everything working—complete with some awkward pauses and input-switching issues when it’s all set up properly. And the speakers, while undeniably powerful, could really benefit from both guaranteed identical balance in both wired and wireless modes, and an initial setup feature with, say, three or five different predefined audio balance offerings the user could choose from. All of this could be handled with an iOS app or iTunes-integrated AirPlay setup process, and going forward, it probably should be. Based on its past track record with Zeppelin firmware updates, our hope is that B&W will step up to the plate and make some of the post-release tweaks that would enable Zeppelin Air to live up to its full potential. It’s obvious that this unit has under-tapped abilities under the hood, and if they’re unlocked, we’ll be happy to take another extended listen.
διορθωθηκαν αυτα τα μικροπροβληματα;
αυτο τι λεει;
JBL OnBeat Xtreme Bluetooth Speaker Dock
αναφερει οτι παιζει καλυτερα απο το zeppelin air και ειναι και με χαμηλοτερη τιμη...
αυτο δυστυχως δεν εχει airplay αλλα bluetooth. μολις διαβασα oλο το review...
δεν γνωριζω βεβαια αμα υπαρχει καποιος τροπος να εχω προσβασει στην μουσικη που εχω στο nas (μεσω bluetooth) μιας και εκει εχω ολη μου την μουσικη συλλογη.
τελος το zeppelin air σε σχεση με ενα ζευγαρι focal cms 40 ή 50 (σε συνδυασμό με ενα squeezebox touch που υπαρχει ηδη) ποιο θα αποδώσει καλύτερα και θα εχει μεγαλυτερη ενταση χωρις να παραμορφωνει;
Όταν τρεχεις το imdb app ή το YouTube app στο iPad μπορείς να έχεις ήχο στο zeppelin air;
Γενικά το να στέλνεις ηχο στο zeppelin είναι δεσμευμένο σε ορισμένες εφαρμογές ή μπορείς να το έχεις αντι για το ηχειο του iPad;
