Class D
Βρε σεις,λίγα ειναι εκατό;
Με αλλα τέσσερα τέτοια πέρνω μεταχείρα άλλον ενα σαν τους δικούς μου και τριενισχύω χωρις σκοτούρες για ταιριάσματα!
(τσίπης_mode_off! )
ωχ, παιδιά, μας διαβάζουν!
[/url]crown! by stergioszx, on Flickr[/IMG]
ΧΑΧΑΧΑΧΑΧΑ
Σχετικά με όσα συζητάμε εδώ, σε αυτή την κριτική του σετ προ-τελικού της NAD M12/M22, γράφει μεταξύ άλλων (μετά από διάφορα εγκώμια της φυσικότητας και της δύναμης του αποτελέσματος):
Those familiar with my reviews might be surprised that I am praising a Hypex PWM amplifier, even though I often argue that this technology is wasted on me. So far, I've never been able to get used to PWM except in subwoofers. But improvements have been made over time, and the same sort of Hypex Ncore modules found in the Grimm Audio active speakers can be found inside the M22. Many other brands just adapt the Hypex technique, fit a power supply and put the result on the market. NAD is a little bit different. Tried and tested techniques from its own amplifiers are combined with Ncore to turn a technical solution into a musically capable one. [...]
Accustomed as I am to an all analogue class A Audia amplifier combination ranking the NAD M12 and M22 is pretty easy, by comparison they are clear in nature, but not in a nasty way. For example, the opposite of the Audia’s sound is Devialet with its ADH solution which is closer to the technically perfect end of the spectrum. Don't get me wrong, Devialet does great things and those who have heard their SAM system will undoubtedly have been just as impressed as me. Yet I cannot imagine myself switching from old fashioned class A(B) to any kind of PWM, not even when it bares the Devialet logo. I had an M2 integrated for several years but in the end it had to go, so why embrace the M22? Maybe because of the clean sound, the musicality, the boundless deep bass or the intense pleasure of looking deep into the recording process.
Συμπέρασμα: η υλοποίηση, όπως σε όλα τα πράγματα, μετράει πάρα πολύ, πολύ περισσότερο από τη "φύση" της τεχνολογίας --τουλάχιστον τώρα που αυτή έχει ωριμάσει αρκετά.
Παρόλα αυτά διάβασα κριτική όπου προτιμήθηκε ο NC400 (ίσως NC500) έναντι του Μ22. Άβυσσος το αυτί του audiophile, άβυσσος.
Απλά σ' αυτό το λήμμα υπερθεματίζουμε ότι πλέον αυτή η τεχνολογία κάνει αυτά που είχε υποσχεθεί : ικανότητα οδήγησης, έλεγχος στα χαμηλά και άριστα χαρακτηριστικά.
Τα υπόλοιπα πρέπει να αφεθούν στις ακροάσεις, που λόγω μη ύπαρξης εισαγωγέα πρέπει να γίνουν μεταξύ μας.
Να, εδώ πάνου κάτι κανονίστηκε, άντε και οι από κάτου.
Kαι γω τα ίδια. Επίσης κάποιος (για να το πάω λίγο παραπέρα), που ήταν κάτοχος και devialet γούσταρε πιο πολύ τα nord nc500 με το αλλαγμένο buffer board
Ηρθε, το φτιαξαμε με τον Αγγελο σε 3 ωρες απλα γιατι ημαστε καθυστερημενοι! Το κεντρικο παιζει τελεια ειμαι απολυτα ευχαριστημενος αντε με το καλο να ρθει και το δευτερο να δουμε τι κανει και με το teac.
Μεσα ειχε χάρτη με αναλυτικες οδηγιες! Εγω νομιζσ οτι θα επρεπε να το κανουμε στα τυφλα...
Sent from my GT-I9300 using Tapatalk
Όπως έχω πεί, τον εχω τον Μ22 και τον οδηγω με προενίσχυση Τσακιρίδη. Το αποτέλεσμα είναι ζεστος και στιβαρός ήχος. Παλαιότερα είχα τον Rοtel RB 1092 αυτόν με το ICE. Καμία σχέση τα δύο μηχανήματα, ο Μ22 μακράν πιό πετυχημένη υλοποίηση παρόλες τις αρετές του Ροτελ.
Μετα απο άφθονο γέλιο τα καταφέραμε με τον Θοδωρή , καλορίζικος! ncore και τα μυαλα στα κάγκελα! :music-smiley-005:
teddy743 πότε το παρήγγειλες; Μου φάνηκε ότι ήρθε πολύ γρήγορα... Καλοάκουστος
To κεντρικό μου ακούγεται πια πολύ καλύτερα από ότι με έναν 5καναλο rotel rb 985 που ειχα...τι εννοώ; Πολυ απλά, όταν μπαίνει το sountrack της μουσικής την ώρα που υπάρχει διάλογος καταλαβαίνω τι λένε και δεν μιλάνε μέσα στο στόμα τους οι ηθοποιοί οπως οταν το ειχα στον rotel...παρόλα αυτά δεν το προτείνω για κάποιον που δεν έχει av processor με xlr και τουλαχιστον 2Vrms στην pre out γιατι θα εχει ουσιαστικα την μιση οδηγηση απο οτι θα μπορουσε να δωσει το nc400.
Οταν με το καλο ερθει το 2ρο σε 1μηνα λογικα, θα το ακουσουμε με διαφορους προ που εχουν απο 2rms και πανω και με μουσικουλα σε stereo και εκει θα σας πω ουσιαστικα μια ολοκρηρομενη αποψη.
-bye-
Μεγιες, μεγιες καλοάκουστος.
Αν επιτρέπεται από που η αγορά, sory αν έχει ξανά ειπωθεί αλλά δεν το βρηκα κάπου.
Αυτό φαίνεται πολύ καλύτερο DIY από τα Video που είδαμε από ότι πρόσεξα είναι
τελείως plug 'n play ούτε κολλήσεις θέλει!
(το κάνατε μόνοι για να γλιτώσεις τις μπύρες ε?....)
