ΠΩΛΗΣΗ Crystal Acoustics THX-D-BLA THX Surround Speakers
8 June 2007
1,018
ΜΕΣΟΛΟΓΓΙ
Πωλούνται (1 ζευγος) σε άριστη λειτουργική και εμφανισιακη κατάσταση τα Βραβευμένα περιφερειακά ηχεία THX-D-BLA της Crystal audio Piano Black
Τιμη 280
Product Description:
Create the real cinematic "in-the-action" sound, for your Home Cinema setup
  • Awarded THX Select Certified Dipoles
  • Dipole design for immersing effects
  • Electronic protection at the tweeters for safe function at high levels
  • Balanced sound reproduction for realistic effects and ambient sounds
  • Wall mounting system attached on the speaker
  • Luxurious combination of high gloss and black ash finish
Specifications:
  • Bass Reflex PortsYes
  • Crossover Type2-way
  • Dimensions WxHxD (in)12.2 ? 12.2 ? 5.8
  • Dimensions WxHxD (mm)310 x 310 x 147
  • Frequency Response (Hz)45 - 22k
  • Gold Plated Binding Post / Bi-WireYes / No
  • Impedance (Ohm)8
  • Magnetically ShieldedYes
  • Maximum Power (Watt)200
  • Minimum Impedance (Ohm)6.4
  • Power (Wrms)100
  • Sensitivity (dB/2.83V/m)88
  • Tweeter Electronic ProtectionYes
  • Weight (kg)7
  • Woofer 7'' Crystal FibreYes
  • Woofer ChambersYes
